E36 (1991 - 1999)
Old 02-03-2006, 02:25 PM
cleoburyp cleoburyp is offline
Mein Auto: 5351 1998
Exclamation What to buy?
Wife just gave permission to spend 10K on a car!
Like the idea of a 1997 328iC
What do i look for in buying one - can I get someting for 10K thats any good?
Any links to specification and what the options on the car are.
What are the MUST haves on the car - Id like manual trans!
Any reviews on the WWW?
Old 02-03-2006, 07:26 PM
fun2drive's Avatar
BMWCCA 149159
Convertible
First of all for the amount you are looking to spend you will be looking at the 96 year range maybe a 97. What to look for in the vert that should keep you out of trouble. 5 spd hightly recommended as it is pretty bulletproof.
The 96 on models have a fully auto top which means you push the button and hold it and the top will open and close with no actions by you. Be sure it works that way as tops are cloth in BMWs and very expensive. Areas that cause issues are the tensioning straps that run along the length of the top. They are there to help keep the top tight when it is up. Bat wings, yeah really batwings. These are the plastic pieces that are right behind the rear window. They are there to keep the top from flapping in the wind when the top is up and all the windows are down. This is a common issue with cars that are used often. There is a repair kit that will allow new plastic batwings to be installed and strings with some lead seals that will allow the right tension on the bat wings to keep the top inside liner tight up against the inside where it belongs rather then flapping in the wind. Rear window, look to see if the zipper is still attached to the window, that means it is an original BMW plastic window. If the window is slightly foggy meaning you can kind of see through it then it can be ploished with some plastic polish or just car wax to get the oxidation layer off. If really bad you will need to replace it. That is at least a couple hundred bucks. Rubber seals, they shrink on these cars and you will eventully get a leak around the window frame at the top where the frame and top come together. Seal replacement is about 180 bucks for parts which is just one rubber seal and you can install it yourself with patience.
Remember the vert is 300-400 pounds heavier then a regular coupe or sedan so don't expect it to be as fast. Also most BMW issues with an e36 apply, water pump being the prine one with radiator and t-stat t-stat housing the other two.
Also the car is going to flex some which is due to the body not being as stiff due to no top. Expect that, it is normal. I have always eventually bought the hardtop as it makes the car really tight and gives great protection in all weather conditions.
I am making the assumption you are already familar with the normal e36 3 series cars. If not then do a search. The 328 vert is a nice car and fun to drive even if it was an auto. I have owned both manual and auto and the manual is more fun, way more fun but then if you don't care to shift or your wife doesn't drive a stick then the auto is ok. Be sure that the auto shifts smoothly and if so be sure that you get all the fluids changed in this car. Be careful with how the auto tranny fluid is exchanged because you can induce a slippage in transmission 1 out of 3 times doing this. Ask me how I know. If you just suck out what is in the pan and only put the same amount back in and do that a few times you can exchange the fluid with little risk of causing this problem.
If you want to know specifics just PM me or reply back here and I will try to get you an answer....
Old 02-04-2006, 12:48 PM
Sproles Sproles is offline
Hubby of 1, Daddy of 2
Mein Auto: 1998 328i 5-speed
In July I bought a 1998 328i with 96k in GREAT shape from autotrader.com
There were PLENTY to choose from in the 9-11K range in the 1998 328s. Look at eBay and autotrader. I was pretty picky on mine and it took me a week or so to find the exact one that I bought - but it was exactly what I wanted and could afford. My self given limit was also $10K
Good luck and keep us posted.
Sproles
Old 02-04-2006, 10:00 PM
DEFKON99 DEFKON99 is offline
man with the plan
Send a message via AIM to DEFKON99
Mein Auto: bmw e36
just go with an M3 e36
...When you get a blackeye from trying to change the shift knob.
Old 02-05-2006, 07:46 AM
dzrocks_11 dzrocks_11 is offline
Mein Auto: 1996 328is coupe
i think your ten grand would be wisely spend on a bmw, however if you step away from your convertable idea there will not only be more cars availible but also the pice for a car with similer milage will be down compared to a convertable EI: 10,000 might by you a 97 328ic with 100,000 miles whereas the same 10,000 will by you a 98 328i with 75,000 miles
Behold the power of 3
Old 06-23-2007, 07:16 AM
irish189 irish189 is offline
Mein Auto: 98 328ic
I have just become the proud owner of a 98 328ic and love it. $11k and its in perfect condition. Hope you can find one.
Question fun2drive. Where would i find a hardtop? Sounds like it might be worth the cash.
Old 06-23-2007, 10:22 AM
Blake99 Blake99 is offline
Send a message via Yahoo to Blake99
Mein Auto: 2007 750LI
i got my 99 323is for $6500. has some milage but please dont fear milage. milage means a car was driven and was important to the owners. you take care of important things. cars with low milage means the owners didnt drive them and most likely didnt do normal repairs. only fixed it if it broke and no preventive maintence. trust me
blake
Old 06-23-2007, 10:30 AM
lochness lochness is offline
Mein Auto: e46 M3 Dinan / e70 X5 35
Take your time and look around a lot as my friend picked up a 1995 325ic auto, sport, triple black, loaded w/ 36k in perfect condition for $13,500 2 years ago.
Old 06-23-2007, 11:06 AM
Vornado's Avatar
Vornado Vornado is offline
Protect your (lug) nuts
Mein Auto: '97 BMW 328i
Get a brand new kio rio and hang a flower wreath from the mirror.
If you have built castles in the air, your work need not be lost; that is where they should be. Now put the foundations under them.
-- Henry David Thoreau
Old 06-23-2007, 02:28 PM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
Check this thread out mate - http://www.bimmerfest.com/forums/sho...d.php?t=191293
I know it looks a lot, but ALL cars have their problems.
The E36 is an amazing car and the 328iC is awesome
2001 Mini Cooper R50
Edirty6 for life
Old 06-23-2007, 07:44 PM
jh1328's Avatar
jh1328 jh1328 is offline
<----MY girl....
Send a message via AIM to jh1328
Mein Auto: e36 325i
+1 go with the m3...theyre available for around that price range
im josh...this is what i drive.
Old 06-24-2007, 07:08 AM
jason_recliner's Avatar
jason_recliner jason_recliner is offline
Don't ask me, I'm a sofa.
Mein Auto: Bostongrün 1995 320i
E36 M3 for ~$10k???? I wish.
Sadly, even with AUD$1.00 = US$0.84, not around here they're not. You're looking at $40k+
I paid AUD$11k for my 1995 320i, and thought it a bargain. Took one week before I wanted a 325i.
Cleobury, I'd buy the biggest engine you can find for the dollars. You can always improve / repair your trim / body / engine. But going from 320 to 325/328 is only done with change of car.
Old 06-24-2007, 08:39 AM
Conehead Conehead is offline
Go you Good Thing
Mein Auto: e36 316I M
If we all ignore him, will he just go away.........
The best predictor for future behaviour, is past behaviour. ALSO, IT SHOULD BE NOTED:......AMATURES BUILT THE ARK..AND PROFESSIONALS BUILT THE TITANIC..................QUOTE FOR THE DAY.. Good drivers know how to get out of trouble, and better drivers know how to avoid it.....The Cone 2006 & 2007
Old 06-24-2007, 08:45 AM
Still here
Mein Auto: M3
Edirty6 for life
Old 06-24-2007, 10:05 AM
Vornado's Avatar
Think again!
Similar Threads
If BMW is selling My07 535i, would you now buy a 525i or 530i? BMWDoug E60 / E61 (2004 - 2010) 22 02-03-2006 03:56 PM
OT Lidartek LE-30 Group buy!! beewang European Delivery 2 04-15-2004 02:10 AM
Group Buy of replica CSL truck lid and rear diffuser LandShark Classifieds 0 02-26-2004 12:53 PM
ZHP for me maybe Dr. Phil 3 Series & 4 Series 117 05-01-2003 08:34 AM
