E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008)
Coupe and Roadster talk with our gurus here... |
#101
Oil change how often?
How often do you change the oil in a z42005 ?
#102
Z4 Door Remove
Where can I get a battery for my Z4 3osi. Can I change it myself?
#104
Dealership. Changing your battery is fairly easy to do.
#105
Don't buy one at the dealer unless they discount. You should be able to get one at O-Reilly Auto Parts for much less. There are many other places as well. Simple to change out. Just did one myself.
#106
Part of removing storage compartment
Tool better than what they show. Following better, now at $11.90 retail.
. . Last edited by Ron Stygar; 11-22-2011 at 11:13 PM. |
#107
Z4 CD Changer
Removal of signal and trim on the front fenders
Main Groups
Main groups are in the TIS (repair) , EPC (parts), WDS (electrical) etc.
If you purchase the cover trim it starts with 51 13 If you purchase the Signal lamp it starts with 63 13 #3 http://www.penskeparts.com/DiagramsR...iagram=51_6112 #1 http://www.penskeparts.com/DiagramsR...iagram=63_0759 If you have the part number you can find the TIS. Notice the 13 in the middle of the trim and signal trim.
. . Last edited by Ron Stygar; 02-05-2012 at 04:58 PM. |
#110
Z4 Fuel Pump Bulletin
SI B 16 02 06 October 2006
01/10/06 up 09/08/06 Z4 M roadster LE89047 - LE89999 ----------------LY52002 - LY52816 Z4 M coupe LL93008 - LL93334 Wiring harness may have been pinched. Reroute away where it's pinched with tape.
Link to installation of Duralast Platinum H6-AGM battery in place of stock BMW 61 21 7 553 951 in 2007 M Roadster.
2007 Z4 M Roadster Sepang/Sepang-X/Black, Premium, Nav, BMW Strut Bar, Stubby Antenna, Dice, UUC clutch stop, Star Specs, and the rest joyfully stock. |
#112
Pass Key
TCU
Triple blink for pre-facelift cars - Komfortblinker, http://www.jalt.de. I added one to an 02 330Ci, and it worked perfectly. It helps to speak German, but English instructions are available.
#114
34 00 ... General Information
Part of 34 00 ...
FYI.
MZ3 coupe was formally (ie: OE window sticker) called "M coupe" MZ4 coupe is formally called "M Coupe" Not sure if roadster/Roadster is in the same boat or not.
Jon Maddux 10 S1000RR | 09 F650GS | 08 E90 M3 | 07 R1200RT | 06 M Coupe | 01 M coupe |
#116
Hey
I bought recently a 2005 bmw z4 3.0i but the problem is the bluetooth pairing I searched so many videos but nothing specific for the z4....i press the pairing button on the steering wheels but nothing happens after ignition and before ignition i have tried everything...the navigation does not have bluetooth settings im starting to get confused ALL I NEED ARE EASY STEPS TO BLUETOOTH PAIRING THANK U FOR UR TIME |
#117
just made a video on how to change a xenon low beam light for 2006 bmw z4. not sure where to post the info but this spot seems like a good start.
http://www.youtube.com/watch?feature...&v=Ooh16mEY3hQ |
#118
New member here. Good thread lots of good info.
Are the manufacture numbers correct in post #22? Those numbers seem very low to me. |
#119
NA includes Canada.
Brake calipers
anywho, does anyone know if project mu calipers will fit on a BMW z4 2007 3.0 si coupe? Thanks in advance
#121
Z4M Bluetooth Paring
I have a 2006 Z4M Roadster, I would like to pair it to my Motorola Droid Maxx HD. My phone finds the BMW Bluetooth but I can't get the car to even get to the point where it asks for the Pin, which I don't know. I would like to know where / how I find out if it is even going to work before I remove the trunk lining to find the Pin, or go to the dealer and have them hook up analyzer to get me the pin. Can someone tell me where I might find this out, I would really like to use this feature.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
