Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Classic Bimmers
Classic Bimmers
Discussions pertaining to vintage and classic BMW models here...
Old 02-07-2006, 05:41 PM
Ety Ety is offline
Mein Auto: '72 3.0CS
Question Getting a '72 3.0CS running again
My Dad has a 1972 3.0CS Auto that's been sitting for about 5 years now. Last time it was drivable it had some ignition(Basically hot-wiring it to start it) and tranny problems. The last time it was started some tranny fluid leaked onto the exhaust, but it did start. I hate seeing such a nice car rust away, last summer I toke care of most of the surface rust I found. I would like to try getting it running again, but I wasn't sure how safe it is with the bigger rust issues it has. Can you guys see anything potentially hazardous, I have pics more pics I can put up of any problem areas. If it going to stay together, I would like to try getting it running, the carbs and gas pedal are frozen and I was wondering how to fix that and what to do before I try and start it. Thanks alot
Pics: http://www.flickr.com/photos/ety/set...7594060995213/
Old 02-09-2006, 05:34 PM
Tex Tex is offline
Mein Auto: My 2 feet!
Hello Ety,
Well, that 3.0cs for sure needs a some TLC.
To answer your questions, I would not attempt starting this car: Tranny fluid on exhaust is one of the most common ways car do catch fire.
Now, as to bring this car back to life, there are a few things you need to know:
- the E9 chassis was built by Karman for BMW, and is built like a steel honeycomb structure. Which means water sits or condensates in the "cells" of the structure and creates rust. Looking at the pics, you can bet that the visible rust on the outside is the least of your concerns, the lower chassis/body is likely having a lot of hidden rust. Now, this is not impossible to fix, especialy if you can do some of the bodywork yourself, but is time consumming (very time consumming). If you decide to have it restored, it will be the biggest expense
- the engine is a fairly sturdy one, so you should not have many problems with it. Since the car has been sitting for 5 years, gaskets and seals will probably have to be changed, but otherwise, the internals should be fine.
- electrical / electronics: the electrical system is fairly simple, no major problem to expect here. Lucky you, the car is carburated, so no problems with the injection system and its electronics.
- transmission: will need to be rebuilt
- Interior: well, evidently a good upholstery job. But the interior looks in great shape (dash and plastics) which is great since these parts are impossible to find and pricey to duplicate or repair.
Similar Threads
Daytime running lights? Can I turn them on somehow? Plupp 7 Series - E38 (1995 - 2001) 4 08-19-2011 10:48 AM
Fender Flares Required for Alum. Running Board chefwong X5 E53 (1999 - 2006) 1 02-04-2005 02:56 PM
325xi running rough black325xi 3 Series / 4 Series 1 12-05-2004 12:05 AM
Cant install BMW riverts for running boards! coolesnce X5 E53 (1999 - 2006) 5 11-22-2004 05:48 AM
Running board install Qs for 4.8is LeMansX5 X5 E53 (1999 - 2006) 4 11-21-2004 11:21 AM
