Balance / Vibratioin issue - Bimmerfest - BMW Forums
Old 02-11-2006, 07:04 AM
Chris Carmen Chris Carmen is offline
cuc42
Mein Auto: Indianapolis
Unhappy Balance / Vibratioin issue
I have a 02' E65 that developed, what I thought to be a balance problem in one or both of the rear wheels. I've been through two sets of tires and repeated balances and yet, the issue remains. The dealer now believes me and put out a PUMA on the problem. The dealer first replaced the undercarriage bushings, test drove the car, and the vibration remians. They are now replacing the differential bushings. BMW has the dealer doing a trial and error diagnosis, which is not bad, since I am driving a 06' 325 loaner. However, I may never see my 7 again.
The dealer mentioned that they have seen this on other 02' & 03' 7's, but have not been able to completely solve the problem. Has anyone seen this problem?
Old 02-11-2006, 07:56 AM
2006_750Li_ED's Avatar
2006_750Li_ED 2006_750Li_ED is offline
Officially Welcomed to the 'Fest!
Mein Auto: 2006 750Li Euro Delivery
Don't worry, you will get your car back in no time, and the problem will most likely not be solved.
A good allignment helps, however make sure that your tire pressure is not too low, 40 PSI per tire, not like they say on the door.
Similar Threads
On Board Computer & Avg Miles per Gallon Indicator Issue Flex 3 Series & 4 Series 3 11-07-2004 08:22 PM
Unresolved Safety Issue e46_325xi 3 Series & 4 Series 19 07-22-2003 02:50 PM
Moonroof Issue... CtrlAltDel 3 Series & 4 Series 8 06-06-2003 10:21 AM
