E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
55k miles what should be done???
So i've got a 2001 325i with 5 spd steptronic
well....not really mine (my ex-wife's) but long story short what needs to be done at 55k miles tranny fluid i suppose??? since i KNOW they are not life time....the question is that i have hear stories about how you HAVE to bring it back to the dealer caz theyhave to plug in the computer to do it rite (which i doubt) is that true??.......if not what kind of fluid should i use??? Mobil 1 ATF or Redline ATF?? because i aint gonna buy the BMW $21/L stuff and also what should the rear diff. use??? Redline GL5+ (with the limited slip additive) or GL4 will do a coolant flush with BMW coolant....... what else needs to be done?? TIA
Now -'12 VW Golf MK-VI 2.5 & 09' BMW M6 SUVs-'08 Acura RDX Tech -'04 BMW X3 3.0 2 doors -'01 Audi TT QC 6 spd -'01 Toyota MR-S - '06 BMW M Roadster 4 doors -'01 BMW 325i E46 -'96 MBZ C280 Sport no doors- 00' Suki GS500 |
You are getting real close to time for Inspection II normally performed at 60,000 miles. See below:
BMW Service Maintenance Checklist BMW Engine Oil Service Required Change oil and oil filter while engine is at normal operating temperature. Change oil in rear axle while at normal operating temperature (only at 1st engine oil service) Reset Service Indicator Note: Do not reset Service indicator when additional oil changes (between the normal intervals) are requested by the customer. BMW Oxygen Sensor Replacement Required at intervals of 100,000 miles BMW Inspection I Undercarriage Change engine oil and oil filter while engine is at normal operating temperature. Check transmission for leaks. Check rear axle for leaks. Visually check fuel tank, lines and connections for leaks Check condition, position and mounting of exhaust system. Examine for leaks. Check power steering system for leaks Remove and install front and rear disc brake pads, check overall thickness. Examine brake disc surfaces. Clean brake pad contact points in calipers. Grease wheel centering hubs. Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage and joint disc. Check brake and clutch system connections and lines for leaks, damage and incorrect positioning. Check for free movement of the parking brake cables. Adjust parking brake if necessary. Check all tie pressures (including spare). Correct if necessary. Check condition of tires (outer surfaces [left/right]), tread wear and pattern; in case of uneven tread wear readjust wheel alignment if requested (to be invoiced separately). Note: If requested, rotate all four road wheels as instructed and rebalance (invoice separately). Engine Compartment Read out diagnostic system. Check engine cooling system/heater hose connections for leaks. Check coolant level and antifreeze protection level; add coolant if necessary. Note: Coolant must be replaced every 2 years (time interval begins from vehicle's production date). Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary. Check air conditioner for operation. Reset Service Indicator. Body/Electrical Equipment Check battery electrolyte level and add distilled water if required. Perform battery load test. Body/Electrical Equipment (continued) Checking lighting system, I.e., headlights, fog lights, parking, back-up, license plate, interior (including map reading lights0, glove box, flash- light, illuminated make-up mirrors, luggage compartment/area lights. Check instrument panel and dashboard illumination. Check all warning/indicator lights, check control. Check turn signals, hazard warning flashers, brake lights, horns, head- light dimmer and flasher switch. Check wipers and washer system(s); wiper blades, washer jet positions. Check rear window washer level and antifreeze protection. Fill up and/ or correct. Check condition and function of safety belts. Oil hood, trunk/tailgate and door hinges. Grease hood, trunk/tailgate and door latches. Check operations of all latches. Check central locking/double lock. Replace micro filter. Note: Reduce replacement interval in dusty operating conditions. Check heater/air conditioner blower, rear window defogger. Check rear view mirrors. Visually examine the SRS airbag units for torn cover, obvious damage or attachment of decals, decorations or accessories. Activate automatic roll-over protection system 9if equipped) via diagnostic link. Note: First remove hardtop/lower top. Final Inspection Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission. BMW Inspection II Includes all items listed under Inspection I and the following checks and maintenance operations: Engine Compartment Replace spark plugs. Replace intake air cleaner element. Note: Reduce replacement interval in dusty operating conditions. Check condition of all drive belts. Undercarriage Change ATF in automatic transmission while at normal operating temperature. Change oil in manual transmission while at normal operating temperature. Change oil in rear axle while at normal operating temperature. Check thickness of parking brake linings. Half-shafts: Check for leaks at flexible boots. Replace fuel filters. Recommended in California, required in all other states. Note: Reduce replacement interval if fuel contamination is encountered or prevalent. Inspect entire body according to terms of rust perforation limited warranty (must be performed at least every two years). At Every Second Inspection II: Change oil in manual transmission while at normal operating temperature. Check clutch disc for wear. |
Not saying you are wrong but where did you get this info?
I have never read about a 2001 e46 325/330 having the following 4 services done during a Inspection II with 55,000 miles on the car. 1. Replace spark plugs. 2. Change oil in manual transmission while at normal operating temperature. 3. Change oil in rear axle while at normal operating temperature. 4. Replace fuel filter |
Your car is 5 years old. If you have not done these items, I would strongly suggest you do them. You can wait longer to do spark plugs, but they get more difficult to remove over time and mileage.
Jeff is correct about the things that should be done, but the list of items is not a current one. The dealer can give you the current inspection II worklist or you can download it from the Owners circle at bmwusa.com.
Get the work done at an independent BMW mechanic. |
i agree with all the work mention above
PLUS i want to change out the tranny fluid...(and the diff fluid) what fluid should i be using for those??? (instead of the BMW OEM stuff that cost $24/L) platnium 4s for the plugs?? and also do i need the o2 sensors to be replaced???
I do not think a BMW servce center will do these following things on your first Inspection II. 1. Replace spark plugs. 2. Change oil in manual transmission . 3. Change oil in rear axle . 4. Replace fuel filter Last edited by Artslinger; 02-17-2006 at 10:44 AM. |
Haven't replaced O2 sensors yet. For ATF, I went with BMW fluid. Have read on other boards that folks with manual transmissions had clutch issues after changing out to aftermarket fluid which went away after switching back to OEM fluid - I have not seen anything like this yet for the step transmission. Just played it safe although yeah it's pricey. Last edited by milobloom242; 02-18-2006 at 09:32 AM. |
You are correct, A BMW dealer will not do the above mentioned jobs. I meant to say that all the work listed should be done. My recommendation was that it should be done at an independent BMW mechanic. The following is the Inspection II checklist for a 2001 325i: Undercarriage Change oil and oil filter while engine is at operating temperature. We recommend BMW High Performance 5W-30 Synthetic oil, p/n 07 51 0 017 866 Check transmission for leaks. Check rear axle for leaks. Half shafts: Check for leaks at flexible boots. Visually check fuel tank, lines and connections for leaks. Check condition, positioning, and mounting of exhaust system. Examine for leaks. Check power steering system for leaks. Check p/s fluid level; add fluid if necessary. Check overall thickness of front and rear disc brake pads using special tool. Record results. If replacement is necessary*: Examine brake disc surfaces. Clean brake pad contact points in calipers. Grease wheel centering hubs. Check thickness of parking brake linings only when replacing rear pads. Record results. Check brake and clutch system connections and lines for leaks, damage, and incorrect positioning. Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage and joint disc. Check parking brake actuation. Adjust if necessary. Check all tire pressures (including spare - except M3, M5, Z8 and Alpina). Correct if necessary. Check condition of tires (outer surfaces [left/right]), tread wear and pattern; in case of uneven tread wear readjust wheel alignment if requested.* Note:If requested rotate all four road wheels as instructed and rebalance.* Inspect entire body according to terms of rust perforation limited warranty (must be performed at least every two years). Engine Compartment Read out diagnostic system. Check engine cooling system/heater hose connections for leaks. Check coolant level and antifreeze protection level; add coolant if necessary. Note: Coolant must be replaced every 4 years (time interval begins from vehicle's production date). Check level of brake and clutch fluid in reservoir. Add fluid if required. Replace brake fluid every 2 years (timing interval begins from vehicle's production date).* Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary. Check air conditioner operation. Replace microfilter. Note: reduce replacement interval in dusty operating conditions. Reset Service Indicator. Replace intake air cleaner element. Note: Reduce replace interval in dusty operating conditions. Body/Electrical Equipment Check battery state-of-charge, and charge if required.* Check lighting system, i.e., headlights, foglights, parking, back-up, license-plate, interior (including map reading lights), glove box, flashlight, illuminated make-up mirrors, luggage compartment lights. Check instrument panel and dashboard illumination. Check all warning/indicator lights, check control. Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch. Check wipers and washer system(s);wiper blades, washer jet positions. Check condition and function of safety belts. Recharge or replace batteries for remote controls in all vehicle master keys. Check central locking/double lock. Check operation of all latches. Check heater/air conditioner blower fan, rear window defogger. Check rear view mirrors. Visually examine the SRS airbag units for torn covers, obvious damage or attachment of decals, decorations or accessories. Activate automatic roll-over protection system (if equipped) via diagnostic link. Note:First remove hardtop/lower top. Final Inspection Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission (except M3, M5, and Z8). |
I would add changing the hoses and belts at 55k no matter how good they look.
Whats the going rate for the replacement of hoses and belts? I hate this, because the hoses are off I might as well just change out the water pump, and the radiator... right? Or am I crazy?
i would add, trade the sucker in for a Yugo
Sorry to say, but if you are going to change the belts, you should really change the tensioners too.
A Yugo.... PRICELESS!
But seriously, should I consider a trade? This looks like $3k+ in Maint/Repairs. Although all vehicles reach this point at some time... I guess its a question of how long do I want to drive the vehicle? |
ooops
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| FS: Modded BMW 2000 E46 323Ci 45K miles - Excellent | ///ACS-3 | Classifieds | 0 | 12-26-2004 11:20 PM |
| Impressions of First 1250 Miles | mwette | 3 Series / 4 Series | 11 | 01-06-2003 02:42 PM |
| FS: 1991 BMW 318i, 92k miles! | DrBimmer | Classifieds | 4 | 08-21-2002 07:30 AM |
| 20 miles of country road | Dr. Phil | General BMW | 25 | 08-01-2002 06:54 AM |
