Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 10-05-2002, 07:45 PM
jordanLINY jordanLINY is offline
Rapidly depleting neurons
Send a message via AIM to jordanLINY
Mein Auto: 1993 325i 4dr manual
Another e36 tranny question -- poor cold shifting into 3rd
hi,
Yet another tranny question relating to my aging e36.
Recently (very recently, like the past week) my car refuses to shift into 3rd for the first few minutes of operation. I am not double-clutching when this happens (I think I should.) This is after the car has been sitting in the driveway overnight in 40 -- 50 degrees F. I'm well aware that the tranny will be stiff for the first few miles, and I plan for that (slow deliberate shifting, a little double-clutching.) After getting all warmed up 3rd and all other gears work reasonably well with some notch, no grind. I replaced the tranny fluid with redline atf two months ago.
Being that I'm a college student I'm willing to live with character defects (lack of funds kinda does that.) Anything to do, besides being gentle with the car, to keep from wearing the car down?
I've already begun to collect my pennies for repairs :-(
thanks
jordan
Old 10-06-2002, 08:17 AM
The HACK's Avatar
The HACK The HACK is offline
Rest in peace, Coach
Mein Auto: '06 MZ4C, '09 WRX Wagon
Before you start skipping lunch and dinner to save up for a new transmission, you may want to try swapping your transmission fluids for ATF Manual Transmission Fluid. ATF's fluid is suppose to aid cold starts, and if the symptoms go away after the transmission warms up then the ATF MTL can and will address the cold start problems.
Give it a try. Transmission fluid changes are like .5 hour job.
"Bench racing" about track times driven by professionals are like a bunch of nerds arguing which Princess Leia is hotter, the slave Leia or the no-bra jail-bait Leia. No matter how compelling your argument is, the plain and simple fact is, none of you will EVER get to hit that.
Old 10-06-2002, 09:00 PM
scottn2retro's Avatar
scottn2retro scottn2retro is offline
into things retro
Mein Auto: '02 M3 SMG & '08 135i
Fairly common e36 'feature'
My '95 e36 M3 did not want to go into 1st gear until warmed up a little. Try making sure you depress the clutch pedal as far as it will go until she's warmed up. It helped with mine.
facebook.com/sctsracing
02 M3 SMG Coupe - prepared class BMW Club racer
08 135i 6sp - stock class BMW Club racer
Photo gallery
Old 06-17-2006, 12:24 AM
gpasky gpasky is offline
Mein Auto: m3
where is the tranny fluid replaced at? wheres it located to replace the fluids in the engine compartment?
thanks
Old 07-09-2006, 04:42 PM
dba007 dba007 is offline
Mein Auto: 85 635CSI
hi , the problem could also be resolved by using slick 50 gear oil. in a worn tranny this stuff works pretty good due to its teflon ingridients. this is just a temporary fix however if the tranny reqs atf fluid or if the syncros are worn. in the future when you do start with a fresh tranny it would be a major investment to use synthetic fluids. it will prolong the life of many internal parts and premature wear and tear.
Old 07-10-2006, 06:28 PM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
You mean the same Slick 50 that has paid offMANY claims due to damage caused by their product?
For best perforamnce, use BMW MTF LTF2 fluid, but it is EXPENSIVE> Othewise use Mobil 1 gear lube, or Royal Purplae. Some people swear by RedLine, some people swear AT RedLine. You choice.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
