Inner front tire wear - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 02-20-2006, 11:30 AM
Tex Tex is offline
Mein Auto: 2010 535i
Hello everyone,
Last week, I had the rear tires (RE040) replaced on my 330i ZHP. Got 22k miles out of them, I has pretty glad.
The shop where I took the car told me my front tires were not too worn (7/32 average depth) but wearing unevenly, more on the inner side than center or outer edge. So the question is:
- Do you think my alignment is just bad (too much camber or toe)
- OR, do you think it is just because the ZHP has a little extra negative camber (-0.5 deg IIRC) and I don't drive super aggressively? I mean, I drive fast, but it's not like you can load your front end in turns all that much on open roads.
PJA
Old 02-20-2006, 11:35 AM
#5880's Avatar
#5880 #5880 is offline
Analyst + Therapist = ...
Mein Auto: people crazy
The rears have more neg camber cuz they can. You can see it looking fron the back of the car along the side.
Makes it fun! I get 20k max (read max) out of summer tires. Just kill them both at the end.
"Those who do not learn from history,
are doomed to repeat it."
George Santayana
Old 02-20-2006, 11:47 AM
Tex Tex is offline
Hey lao270,
The rear tires are wearing fine, it's up front that I have a problem. How are your wearing in the front?
Old 02-20-2006, 03:57 PM
LDV330i LDV330i is offline
Mein Auto: 2014 335i M-Sport EB
Last week I also replaced my rear tires with RE040's to match OEM at 20,200 miles. My front ones have plenty of tread and are wearing evenly. You may want to have your alignment checked.
Old 02-20-2006, 04:43 PM
jpr jpr is offline
Mein Auto: '99 323i
As a general rule, the inner part of the tire on the E46 will always wear faster even at factory alignment settings. This is caused by a combination of the toe (which affects how much your tires will wear) and the negative camber (which affects where your tires will wear) Resucing either or both will prolong your tire life, but at some trade off in handling, particularly at higher speeds.
That being said, you should go get your alignment checked. While the inners may wear somewhat quicker even when correctly aligned, they might end up wearing entirely too quickly when improperly aligned.
Similar Threads
E65 V12 debuts nate General BMW Questions 22 06-09-2016 12:44 AM
weird tire wear Jeff_DML Tire Rack's Tires, Wheels, Brakes & Suspension 6 05-10-2005 10:38 PM
Why does the E46 M3 have a 225 front tire? Moderato E46 M3 (2001-2006) 10 04-27-2005 02:45 AM
Tire wear, alignment and warranty on new 325XiT...? steve dunham 3 Series & 4 Series 2 06-17-2002 01:07 PM
