Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > General BMW Questions
Use this forum to ask general question about the BMW ownership and keep up on the latest BMW news. Direct all model specific questions to model specific forums below.
Old 02-22-2006, 01:37 PM
typenews typenews is offline
Mein Auto: 2005 3 BMW Convertible
2005 330 convertible
Purchased a 330ci conv. w'sports pkg. The tires almost look flat and it drags bottom on speed bumps and my driveway. The BMW dealership said this was normal for 3 series. I don't want to damage the bottom of the vehicle and feel over time it will. Thanks for any suggestions or do I just live with hitting bottom????
Old 02-22-2006, 01:45 PM
jillyjellyroll's Avatar
jillyjellyroll jillyjellyroll is offline
I run gentoo. You?
Mein Auto: '15 335ix
check your tire pressure and report back to us w/ results.
Old 02-22-2006, 01:59 PM
Tanning machine's Avatar
Tanning machine Tanning machine is offline
Using SPF 45
Mein Auto: 2004 330Cic
There's not a lot of ground clearance. The tires shouldn't look flat, but they are low profile.
Tanning Machine I: 1989 325iC (Salmon Silver/Black, Heated Seats, LSD). 7/26/1989-11/1/2003.
Tanning Machine II: 2004 330Cic (Silver Gray/Natural Brown, SP, PP, Heated Seats, Xenons). 8/29/2003-present.
Old 02-22-2006, 05:43 PM
JonathanIT's Avatar
JonathanIT JonathanIT is offline
Padawan
Location: L.A., but I'd rather be on Brokeback Mountain
Mein Auto: 2004 330ci Convertible
That doesn't sound right. There isn't a LOT of ground clearance, but my car is over 2 years old now and I've never scraped the underside on anything, although I have been very careful in driveways. It definitely shouldn't scrape on speed bumps.
--J.
2004|330ci|Convertible|Silver Grey Metallic|Sport Package|Premium Package|Steptronic|NAV|Xenon Adaptive Headlights|Heated Seats|Black Montana Leather|Aluminum Brushed Column Trim|SSR/GT3 19" Rims (original 18" Style 71's in storage)
Old 02-23-2006, 04:29 AM
Bart001's Avatar
Bart001 Bart001 is offline
Hofmeister kink ftw!1!!1!
Mein Auto: 2012 X5 35i Premium
Not all speedbumps are created equal. Some are very high and steep. My 1994 E36 has bottomed on those.
Either the tire pressure is proper, or it isn't. If tire pressure is proper and the suspension is at spec, the problem is the speedbump and not the car.
Old 02-23-2006, 06:05 AM
2005 330 conv
I was told at the service dept my tires were correct pressure and they were supposed to look like that b'c they were low profile. I bought the vehicle w'12,000 miles on it but was sold as a new vehicle b'c it was a reps vehicle (it isn't brand new). My first question was why are the tires so low and why do I hit bottom driving into my driveway. I was told by service, I should back out of my driveway at an angle so I don't hit bottom??????! That was the answer service dept gave me. I'm bringing it in b'c I want e'thing checked under there. Thanks.
Old 02-23-2006, 07:26 AM
kyfdx's Avatar
kyfdx kyfdx is offline
Who, me?
Mein Auto: 2006 330Ci ZHP
If you haven't driven anything similar to this.. you'll just have to learn to slow down, going in and out of driveways, etc... The angle thing is correct, as well... The car just sits very low... Most likely, you are scraping the front spoiler..
Once you adjust, it will be all gravy...
Old 02-23-2006, 08:29 AM
I run gentoo. You?
and you believed what the service dept told you? go get a tire gauge and measure them yourself! takes you like 2 minutes, tops. you can even get the nifty digital ones.
how steep is your driveway? if you have a really steep driveway, or a driveway with a very high curb, it's possible that you could scrape the bottom of your car if you aren't careful.
Old 02-23-2006, 08:54 AM
Using SPF 45
Yeah, any quick changes in elevation can do it. For example, even a little dip for a gutter in front of a driveway could be enough.
Also the scrape is just plastic, not metal. Isn't there also a second air dam below and behind the front air dam?
Similar Threads
Urgent reco: Trying to close a deal on 2005 330 jamesbond911 E46 (1999 - 2006) 9 01-18-2006 09:06 PM
Ride: 2005 ZHP/ZPP vs ZPP/ZSP (330i vs 330i) madmax1 E46 (1999 - 2006) 25 12-21-2005 10:40 AM
2005 Eurotuner-SuperStreet Time Attack Challenge MCSL General Automotive Forum 1 11-19-2005 08:31 PM
2004 330 Ci Convertible Mic Confirmation r1man1963 Car Navigation, Audio & Electronics by BAVSOUND 1 08-17-2004 08:48 AM
330 no zhp or 2005 G35 BMWKLR 3 Series & 4 Series 9 07-01-2004 08:44 PM
