Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 03-19-2006, 05:44 PM
stream's Avatar
stream stream is offline
Mein Auto: '05 545i
Update on DVD playback.
After reading a post in the E63 forum from cobradav where he had success with a DVD burned in iTunes, I decided to see if iTunes would work for me, and it does. I put 3.8 GB on a DVD--worked fine including folders with artist/album/track.
When that worked, I was curious why Nero didn't work, so I reviewed all the settings and found that the default is to burn a multi-session disc, so I unchecked that option and burned a DVD, and it worked. Attached are the settings I used in Nero.
Now I'm going to buy some double layer DVDs, to see if I can get 8+ GB on a disc! If I can, with 3 of those I'll have more than my 20 GB iPod, and iDrive integration!
ID:	70971   Click image for larger version
Name:	Nero no multi.JPG
ID:	70973   Click image for larger version
2005 545i - sold
Old 03-20-2006, 04:13 PM
stream's Avatar
Mein Auto: '05 545i
Finally got around to buying some double layer DVDs, and I'm hapy to report that they work in the DVD drive. I burned 2 DVDs (using the settings in Nero from my post above), each with just over 8GB, and they work great.
After doing some research, it seemed that Verbatim DVD+R DL DVDs were getting the best reviews, so I got these (got them at Best Buy):
http://www.newegg.com/Product/Produc...82E16817131163
2005 545i - sold
Old 03-24-2006, 09:23 AM
E60orBust's Avatar
E60orBust E60orBust is offline
Registered lunatic.
Mein Auto: M-Sport twins.
Stream's production date was 11/04. Mine is 9/04 and my dealer attempted the retrofit. Didn't work with my production month/year so it looks like Stream's date is the earliest that would work, either that or his is just an anomaly.
Dealer said over the phone that based on my vehicle's VIN number and production date it was not likely to work but they would attempt it anyway. Took my E60 (09/04) in for the service and after about 5 hours my SA called me and said the computer recognizes the MP3 update but the MP3 discs still won't play. So software is updated but the hardware is not capable to decode it. I made a point to ask if they attempted the retrofit and it failed or if they just didn't attempt at all based on the production date. SA said they attempted but it failed, and given that all my radio presets/memory settings were blanked, I'm thinking he's truthful. Software CIP (22.XX) won't be out until April so there 'might' still be hope for me.
On a related note, I had them activate the AUX input kit I installed and although AUX is now listed in the Entertainment sources of the iDrive, no audio comes out when connected. Time to get my butter knife out again...
Team 1 'Brothers M'
Team 2 'Black & Blue'
Old 03-24-2006, 09:49 AM
stream's Avatar
Mein Auto: '05 545i
On MP3--have you tried playing a MP3 CD? Perhaps the dealer had an inferior quality CD (apparently not all MP3 CDs will play)
On aux input--did you switch the connector leads (see bottom of page 6 of instructions below)? I've heard of many times when dealer didn't, and car had to be brought back.
aux input install instructions
2005 545i - sold
Old 03-24-2006, 10:02 AM
E60orBust's Avatar
Registered lunatic.
I'm pretty sure I switched the connector plugs. With SAT and a CD changer already taking up both spots I figured I had to combine the plugs on my initial install - BUT the SA did mention the service tech opened the dash up to "double-check" my work. I'm about to dive back in to double-check his work to make sure everything was put back securely.
With the MP3 disc, I have an MP3 cd-player in my JEEP that has a disc in it that was previously burned with single-session setting and I'm going to try that disc in the dash to see for myself.
I'll be out in the garage for a while now. Wish me luck.
::Edit::
Update. Just finished some oil changes and some other misc maintenance on my other vehicles, but back to the bimmer.
I ordered the aux kit from bavauto.com and just did a direct plug in, using the BAVAUTO harness instead of the Car's original harness. That's where I goofed. I assumed Bavauto already had the plugs in the right spots. Instead of being in Pin's 7, 2 and 8, I was in pin 8, 9 and 5. Re-wired in at sweet, sweet music started playing. I probably did the same error the BMW mechanics do that causes a return visit by the customer, i.e. Car wires into AUX harness into Radio unit (and assuming the pins are correct) instead of AUX wires into Car harness into Radio unit and making SURE the pins are correct.
Team 1 'Brothers M'
Old 04-11-2006, 03:54 PM
Rick545i Rick545i is offline
Mein Auto: 545i 2005
I am going to pick up my car from the dealer after the mp3 retrofit today. Unfortunately after two programming attempts it does not work. My car does not have the navigation and he said it was needed for it to work.
Jet Black on Black - Steptronic, Premium, Cold Weather, & PDC.
2004 Yukon XL Denali
Old 04-11-2006, 05:30 PM
stream's Avatar
Mein Auto: '05 545i
If you check the attachment called MP3 drives in the first post of this thread, unfortunately it confirms what your dealer said:
(M-ASK, MY06 only)
M-ASK refers to non-nav cars. Since the 545i didn't change to MY06 in March '05 like the rest of the US E60 cars, looks like it won't work on your car.
2005 545i - sold
Old 04-12-2006, 08:24 AM
I was aware of the specifics on the update but I still had to give it a shot since there were only theories floating around and no one knew for certain if the retrofit would work. But now with the help of a lab rat we all know. I had them put in the aux input while it was in so now I can enjoy mp3 music. Thanks everyone for your help.
Old 06-04-2006, 10:07 PM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator, 5-Series
Mein Auto: Trek 6500 MTB
bump
2001 530i/5 (E39), Topaz Blue/Stone Green/Black (sold) *very rare interior/exterior color combo*
2005 545i/SMG (E60), ED Order, Titanium Grey/Grey (lease over)
2014 335i/8-spd, Mineral Grey/Black (lease take over)
Old 06-05-2006, 04:24 PM
E60orBust's Avatar
Registered lunatic.
Originally Posted by Ågent99
bump
Not to question one of your sizeable post count, but isn't this thread a Sticky, and therefore not in need of being "bumped"?
Team 1 'Brothers M'
Old 06-26-2006, 02:05 PM
tonmonde tonmonde is offline
Mein Auto: 2011 135
Hi, my local dealers have no clue about the MP3 retrofit. Can anyone is Southern CA recommend any dealers? I tried Southbay, Long Beach and uhm Santa Monica (<- bad choice i know:P)
Old 06-26-2006, 03:03 PM
stream's Avatar
Mein Auto: '05 545i
I'd suggest bringing them copies of the SIBs I attached to my first post.
2005 545i - sold
Old 06-27-2006, 10:48 AM
Mein Auto: 2011 135
Thanks i will try taking the print outs. I gave the service guys the SIB #s over the phone, but they still didn't have a clue...
Old 07-07-2006, 02:20 PM
Mein Auto: 2011 135
Hey thanks Stream, i took the print outs to my dealer and now my MP3 CDs work great!!!
Old 07-07-2006, 02:29 PM
stream's Avatar
Mein Auto: '05 545i
My pleasure!
Now burn some double layer DVDs w/ 8GB each!
2005 545i - sold
Old 07-15-2006, 04:17 PM
igord igord is offline
Mein Auto: '08 550
CD Changer mp3?
Picked up my car from the dealer yesterday with the update (had to bring SIB printouts).
Thank you stream for the info!!!
Just one question: has anyone tried playing mp3 cds from the changer?
Since the update I can play them through the in-dash player but not the changer.
Has anyone tried this?
Thanks.
Igor
Old 07-15-2006, 06:29 PM
stream's Avatar
Mein Auto: '05 545i
Thanks.
Igor
The CD changer won't play MP3 files. The in dash CD player will, as will the in dash DVD (nav) player. Burn a few 8GB double layer DVDs and you're all set.
2005 545i - sold
Old 07-15-2006, 07:39 PM
Me530's Avatar
Me530 Me530 is offline
Happily Driving
Mein Auto: 2014 550i M Sport
I hope to have my car updated this week. I will definitely bring the SIB with me.
2014 550i M Sport, European Delivery May 2014
2013 X3 35i, Dealer Delivery July 2012
Gone, but not forgotten:
2006 530i
, European Delivery June 2005
2008 335i Coupe 6MT, PCD November 2007
2011 550i M Sport, European Delivery May 2011
BMWCCA #350568
Old 07-19-2006, 08:26 PM
Mein Auto: '08 550
ah cool, thanks.
i kinda like the nav part, i'm ok with 1 mp3 cd + 6 regular
Old 07-20-2006, 06:39 PM
Me530's Avatar
Happily Driving
Success!
2006 530i
BMWCCA #350568
Old 07-20-2006, 06:55 PM
stream's Avatar
Mein Auto: '05 545i
Originally Posted by Me530
Success!
Congrats!
2005 545i - sold
Old 08-01-2006, 07:20 AM
Ågent99's Avatar
Moderator, 5-Series
bump
Old 09-29-2006, 06:33 PM
DotBalm DotBalm is offline
Send a message via Yahoo to DotBalm
Mein Auto: '04 545
Has the status changed at all wrt MP3 CD playback capability for:
-'04 E60 545
-build date 4/04 as I recall
-non-nav
-CD in dash + Logic7 6 CD Changer
...meaning has this been enabled by ensuing sw updates? I take it that it wasn't capable as of the pdf doc being written which is disappointing.
Or must I go another route (suggestions welcome), including but not ltd to giving up hope? TIA
________________
2004 545 Black Sapphire Metallic, Black Leather, Anthracite Trim, Sport Pkg, Premium Sound. Window Tint.
Delivered: 6/1/04
Old 10-18-2006, 07:07 PM
cdp1276 cdp1276 is offline
Send a message via AIM to cdp1276
Mein Auto: 2014 550i xDrive Sedan
I know this is a 5 series thread but does anyone know if there is a fix for a 2006 E90 330i that would allow me to play DVD's or data CD's (burned with MP3 files) in my car with iDrive / Nav system?
Old 04-09-2007, 03:17 PM
mxxmikexx mxxmikexx is offline
Mein Auto: supra
in case anyone is looking for a good price on dual layer DVD's , office max has 10 packs of dual layer verbatim's for $15 or 15 packs of memorex for $19, by far the cheapest ive found so far
Similar Threads
MP3 and CD/CDC Bulletins cobradav E63 / E64 6 Series (2004 - 2010) 27 08-31-2009 02:09 PM
Thanks to Hack to hosting TS 6.0.1 (E46 Tow Hitch Retrofit a Success!) Mr Paddle.Shift Do-It-Yourself H.Q. 89 03-18-2007 03:17 PM
Can anyone verify if these Bluetooth Retrofit Kit Part numbers are available? m3evolution General BMW Questions 25 06-22-2005 08:21 PM
Back from e90 test drive - MP3 CD playback issues? xspeedy E90/E91/E92/E93 (2006 - 2013) 17 05-04-2005 03:34 AM
E60 Head Unit and MP3 Playback yycF30MPerf Car Navigation, Audio & Electronics by BAVSOUND 1 12-13-2004 01:26 PM
