E46 (1999 - 2006)
Old 03-05-2006, 02:06 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
EML Warning Light
Anyone knows what EML warning light is for... this moorning the light was on when I was driving and suddenly the car got no power at all
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 03-07-2006, 10:28 AM
ChargedBMW ChargedBMW is offline
Mein Auto: Supercharged 330i, E38+31
I wish I could tell you....I've had the same problem for nearly 8 months. My EML light will go on when I am coasting in gear. I pulled the codes and it said that my idle air control valve was stuck open.
Yesterday, I pulled the idle air control valve out (after about an hour of wrestling) and sure enough, the valve was stuck. It was covered in dirt and grease. I cleaned it up and it moved freely. I put the valve back in and I'm still having trouble!!!!
I'm at a complete loss now....sorry I can't be more of a help
Old 03-08-2006, 03:18 PM
SilverX3's Avatar
It's a short circuit somewhere in Valtronic electronic system and was told $2,500 repair job.... I am very shocked...
hu hu hu
Job - Captain
MY11.5 X1 Xdrive25i
Old 12-28-2008, 05:16 AM
darran darran is offline
Mein Auto: e46 compact
Idle vaule
How do you check if its stuck is it easy to get at and check
Old 12-28-2008, 07:45 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
hu hu hu
I'd get a second opinion......that is insane.
Old 12-29-2008, 12:20 AM
kunal_D's Avatar
kunal_D kunal_D is offline
Mein Auto: 2008 335i Sport 6MT
hu hu hu
Valtronic electronic system??, Did they tell you your Johnson rod needs replacing as well?? j/k
08' E90 335i, Sport, Premium, Logic 7, 6-spd
01' 330i TiAG, ZSP, ZPP, ZCW, 5spd - R.I.P 04/12- gone but not forgotten.
Old 12-29-2008, 06:10 AM
toddkageals toddkageals is offline
Mein Auto: 2012 335i Sport
I don't know about "valvetronic" but it is possible that if you have an 2000/2001 E46 that it's a short in either the engine wiring harness and/or the throttle body. I am having the same problem on and off for over a year and have done a lot of research. There is a service bulletin that calls for replacing the harness ($250.00 from Tischer) due to faulty crimping at the factory. There is also a bulletin for replacing the throttle body for the same reason (faulty internal crimping on the motor). On my 2001, I get the EML and Traction Control lights about every 3 months or so. The car idles rough and the throttle acts strange (hard to describe). Usually a "reboot" clears the light and the car runs normally for a few months after that. The last time this happened the SES light also came on and later cleared by itself. I have ordered "Carsoft" to help investigate the codes. The generic code that was returned was a P0175 "system too rich". I suppose it could be a problem with the MAF or maybe a short in the harness. I'm intersted to see if Carsoft can pull anything other than the P0175. I'll let you know if I find anything. Our local dealer charges $65.00 for the "diagnosis" so that's my next step if Carsoft can't help. I'll update if I find anything out. Please let us know if you find your problem.
Todd
Todd
2008 335i
Similar Threads
Update on S54 EML light and Service engine soon light gbrown E36/7 Z3 (1996-2002) 6 10-17-2012 09:17 PM
How many message board members does it take to change a light bulb? Guest84 Off-Topic 16 07-05-2009 05:24 PM
warning light 2001 bmw 330i E46 (1999 - 2006) 6 11-01-2005 08:56 PM
Restraint system failure warning light drbmw BMW Dealer Ratings and Feedback Forum 3 05-11-2004 04:28 PM
Anyone get a warning light for "open gas cap"? Will_325i 3 Series & 4 Series 10 04-16-2004 05:23 AM
