E46 M3 (2001-2006)
Old 03-06-2006, 06:57 PM
gr8330 gr8330 is offline
Mein Auto: For fun
!st time SMG
I drove my first Competition Package M3 with SMG Sunday. I found the SMG was very easy to drive like a regular manual...pull lever, lift than back on throttle, I also drove in auto mode and it wasn't as bad as I've heard people complain about on this forum. I truly was amazed at how easy it was to adapt too.
550i Blk/Blk
M3 Imola/Blk
Mike
Old 03-06-2006, 10:15 PM
Cowboy Bebop's Avatar
Cowboy Bebop Cowboy Bebop is offline
Mein Auto: M3
weird, you shouldn't be lifting off the throttle on the shifts, it confuses the computer which bases it's shift program partly on the throttle position!
the smooth shifts occure when you just feather or lift slightly on the throttle, not get off like you would shifting a 3 pedal car.
Life is like a B Movie, you wouldn't want to sit through it twice, but you'd hate to leave it in the middle!
Old 03-07-2006, 05:28 PM
WILLIA///M's Avatar
WILLIA///M WILLIA///M is offline
95NU>*
Mein Auto: '04 Imola/Cinn M3
Same thing as I've found. Playing around with it I've also experienced completely smooth shifts with no lift whatsoever if you shift at the point where the computer apparently thinks you should for the rate of acceleration and RPMS.
I'm not a race car driver, but I play one on my TV.
Old 03-07-2006, 06:23 PM
e36M3r's Avatar
e36M3r e36M3r is offline
Mein Auto: e46 M3
Sounds like he's got it right. Hard to tell the difference between his "lift than back on throttle" and your "lift slightly on the throttle". Come on now, give the new SMG guy a break!
Old 03-07-2006, 06:53 PM
Mein Auto: For fun
Break Let me clear this up some. I was lifting but not coming off the throttle completely. I must have either done something correct or I fooled the computer because everthing was very smoth. IMHO the SMG is very easy to drive. I remember reading the posts about how jerky and horrible the SMG was. This drive has convinced me to consider SMG in the future.
550i Blk/Blk
M3 Imola/Blk
Mike
Old 03-07-2006, 10:26 PM
Mein Auto: M3
most of the Jerky stuff is one of two things.
the drive by wire throttle, or driving with the sport mode on.
sometimes it can be a combo of the two.
the throttle is very sensitive and if you don't brace your foot on the tunnel it can "micor-fluctuate" the throttle and that will caose the bucking brono effect.
e36mer, I was not tryinf to split hairs or criticize what he was doing, just making sure that he was not lifting completely off the throttle... hard to tell from his decsription whether he was or not.
Old 03-08-2006, 09:11 AM
e36M3r's Avatar
Mein Auto: e46 M3
CB: Good points.
The main thing I've found is as stated: "the SMG was very easy to drive like a regular manual...pull lever, lift than back on throttle"
Two key points here: First you must drive it "like a regular manual" so initial throttle application from a standstill must be smooth and progressive, like a manual, and not just mash the throttle like you might do with an automatic. The best thing to do is just imagine the clutch being released as it would be by your foot. (Same with switching from/to reverse)
Second, there was a very perceptive subtlety there... "pull lever, lift" very well said. It is the reverse of driving with a clutch pedal and some new timing one should learn, the lift comes after initiating the switching of gears (pulling the lever) rather than before pulling the lever in a clutch pedal car.
Of course as CB said, we don’t always need to lift, especially when driving spiritedly, just leave your foot in it and click…great fun.
Love SMG and would be very hard pressed to go back. And this is my first car ever without a clutch pedal.
M3 05 Imola/Black, ZCP, ZPP, SMG, Xenon, Nav, Heated, Lumbar, HK -- Euro Delivery Pictures
Old 03-08-2006, 12:29 PM
rruiter rruiter is offline
Mein Auto: 04 M3 Coupe SMG
Originally Posted by e36M3r
CB: Good points.
I've always wanted the regular 6 speed, but now you guys make me curious. what happens it you floor it and shift without lifting ?
04 BMW M3 Coupe SMG-II Carbon Black
Old 03-08-2006, 06:05 PM
Mein Auto: For fun
My best guess is that it will be damn fast without the worry of missing a shift
550i Blk/Blk
M3 Imola/Blk
Mike
Old 03-08-2006, 09:46 PM
Mein Auto: M3
depends on what Drive logic program you are in.
In S6 it will snap your neck back with the brutality of the shifts.
In any other S mode it will be less severe shifts, but it will not be as pleasurable either.
if you do not lift in other modes (s4 and lower) the extended time between shifts in the other S modes causes drivetrain lag, then drivetrain abuse as it strugles to figure out WTF you are trying to do.
Old 03-08-2006, 09:54 PM
e36M3r's Avatar
Mein Auto: e46 M3
If in S6, chirp the tires in first -> third! S5 + S6 give fairly brutal / fast shifts if anywhere near redline. I always see Ferrari advertising how fast the Enzo shifts at 150ms the M3 is almost twice as fast at 80ms on its fastest program.
Normally around town though, if you are driving quickly, with reasonable exceleration, just leave your foot in it and you get quick smooth enough shifts. If you are tooling around with your gf, just give a click and slight lift, and it can be like butter!
Old 03-12-2006, 06:51 AM
English Teacher English Teacher is offline
Banned
Mein Auto:
the throttle is very sensitive and if you don't brace your foot on the tunnel it can "micor-fluctuate" the throttle and that will caose the bucking bronco effect.run on sentence
Now really, can't you spell at all? I am suprised you got whether right!
Old 03-12-2006, 07:42 AM
happy new smg owner
Well, I went to go look at this 04 with smg and I loved it. I bought the car. Even at normal to a little faster driving I lift the throttle a bit when shifting. I noticed it works great when I lift and shift at the same time pretty much ! no jerks or anything. I have not driven it to full extent so this might be a premature finding.
Absolutely love the car though.
Old 03-12-2006, 08:46 AM
chuck92103's Avatar
chuck92103 chuck92103 is offline
Banned
Mein Auto: 2005 BMW 645Ci
The SMG on the newer cars E60/90/63 allows you to shift up/down using either paddle. A really nice feature and a big improvement.
Old 03-13-2006, 08:59 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
SMG on the non-M E46 is the same as on the E60, E90 etc. And it is a TOTALLY different system than the M version. SMG III on the Mnew M5/M6 and upcomng M3 will have the same paddle arrangement as the current M3. Just like the one on Ferrari, and F1 cars, and WRC cars, etc.
On the track one for up, one for down is much better. It is much easier to deal with right hand upshift, left hand downshift than whether to push or pull or rotate or whatever. There is a reason teh true performance cars use the system they use.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 03-13-2006, 10:25 AM
chuck92103's Avatar
Banned
Not sure why they would do this. Why not have a choice? There is no reason it can't work both ways and the driver can decide.
Driving on a city street would be better if you could up/down shift with one hand.
Old 03-13-2006, 11:23 AM
bren's Avatar
bren bren is offline
///Mpty pockets
Mein Auto: wankermatic
Why?
Old 03-13-2006, 11:29 AM
chuck92103's Avatar
Banned
Originally Posted by bren
Why?
Well not better, just convenient at times if you are drinking a cup of coffee or on the phone, etc.
I know people will laugh, but it would be funnier seeing someone trying to reach the opposite paddle in the same situation.
Of course I guess you could put the car in auto mode.
It just does not make sense to have two shift styles.
Old 03-19-2006, 02:37 AM
Pinecone's Avatar
M Mad
M3 is a track/race oriented car you can drive it on the street. So the paddles are set up for best rrack use.
If you want a commuter car to drink coffee and talk on a hand held phone, don't buy an M3.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 03-19-2006, 07:05 AM
chuck92103's Avatar
Banned
Most M3's never see a track. They are simply viewed as a 3 series with a sport package to most consumers.
But I see your point.
Old 03-19-2006, 09:21 AM
Mein Auto: M3
if you are drinking a cup-a while driving (not that you would ever drive without both hands on the wheel or anything) you can always use the stick, that's one of the reasons it's there...
Old 03-19-2006, 09:26 AM
chuck92103's Avatar
Banned
I remember that the next time I see an M3 convertible.
Old 03-19-2006, 05:05 PM
Pinecone's Avatar
M Mad
Just because most never see the track doesn't mean that the car is not aimed at that market. If you want a car you can drink your coffee, talk on teh cell phone, read the paper, and shave on the way to work, buy a different car.
Well to ME, an M3 Cab is an aberration and abomination, in about the same league as an automatic one, the sedans are barely tolerable.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 03-19-2006, 05:44 PM
chuck92103's Avatar
Banned
Old 03-19-2006, 05:52 PM
sdbrandon sdbrandon is offline
Mein Auto: 2012 535i
The M3 is a great car in any form IMO. However, even to adequately track the car, it needs a lot of work. The stock M3 is good for running around town but on the track it definately needs some tweaking. i.e. roll cage, tires, suspension, etc.
2012 535i
Similar Threads
A purist review of SMG II nate General BMW Questions 30 03-25-2013 05:47 PM
On autocrossing, club racing, HPDEs and the SCCA ·clyde· Motorsports, Racing & Track 4 04-23-2005 06:11 AM
Is this medical malpractice hts Off-Topic 8 07-10-2002 10:54 AM
