E46 (1999 - 2006)
Old 03-10-2006, 02:11 AM
Charemyes Charemyes is offline
Mein Auto: 2003 325ci
Exclamation Violent Shaking!!!!!2003 e46 happened to you?
I am a proud owner of a 2003 325 Ci 39k miles until recently. One cold January morning the car decided it didn't want to start. After a few attempts I managed to get the car running, only to be met with an extremely rough idle. Dealer diagnosed the 4th coil needed replacing. With the coil replaced the car seemed to drive better, but the problem wasn't solved, so I took it back. Three days later, after I called to check on the progress, I was told the car was ready. When I went to pick it up I found they had not touched my car(they forgot they had my car). We rescheduled and this time they had my car for one week, but they were unable to find a problem. Two days later the car died out on me, so I took the car in again. This time they said they read a fault on the mass airflow sensor and replaced it. So far it seems that the problem with the rough idle and the misfires have gone. Then, I was driving on the expressway about 60mph and I began feeling shaking, without fear I continued on to higher speeds as I reached 80mph the shaking began getting violent. I then let off the throttle and allowed the car to slow back down to around 60mph, as the car was slowing the shaking became more violent(it was soo bad I began thinking the wheels were coming loose). The car also pulls to the left slighlty, then all of a sudden it will steer to the right, then pull left again. I did extensive searching on this site, but found nothing on this subject. I have also heard those wierd noises coming from my front drivers and passengers suspension area(dealer claims everything is normal). Any suggestions? SOMEONE PLEASE HELP!!!!!!!
Old 03-10-2006, 05:33 AM
Plaz's Avatar
Plaz Plaz is offline
Mein Auto: '11 1M;'08 MCS;'02 325iT
Control arms/bushings?
2011 1M
2008 MCS
2002 325iT
Old 03-10-2006, 06:25 AM
Artslinger's Avatar
Artslinger Artslinger is offline
BMW + twisty road = fun
Mein Auto: Car
It could be many things control arms, bent rim, loose wheel bolts, whatever it is its dangerous take it to the dealer for a look over ASAP.
If it was my car I wouldn't drive anywhere but to the service center.
Old 03-10-2006, 06:28 AM
Artslinger's Avatar
Mein Auto: Car
Do you feel the voilent shaking in the steering wheel or does it seem to be that the engine is misfiring?
Old 03-10-2006, 06:35 AM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
Gosh, your car starts noticeably shaking at 60 mph and you speed up to 80...? Hmmm...
I would be tempted to get the car up on jacks at once.
First, remove the wheels. Check for loose lug nuts. If found, re-torque to specifications.
After wheels are removed, inspect all suspension bolts and attachment points for obvious loose or failed or missing items e.g. shiny wear spots, rusted holes with no obvious bolts, loose or unattached Important Looking metal bars etc.
Failing anything turning up I would have the car flat-bedded to a BMW garage to get with a professional.
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 03-10-2006, 11:20 AM
I pulled off the expressway promptly and checked the tires and lug nuts. Everything checked out ok.
Old 03-10-2006, 11:21 AM
yes i do feel it in the steering wheel, although I also feel it in the entire cabin. The coins in the coin tray were jumping around....
Old 03-10-2006, 11:36 AM
Getsmmr Getsmmr is offline
Mein Auto: '03 330i
I once had an out of balance tire do that to me. The weight got caught either in a car wash or on a lift and the car developed a slight vibration at 60 that got worse at certain speeds (and even worse on deceleration). Funny thing was that it took the dealer a week to figure that one out...
Old 03-10-2006, 04:39 PM
Not to be stupid, but you mean you checked the torque of each lug nut with a torque wrench?
I like the theory of a wheel weight falling off.
This could be confirmed by a simple spin balance; either at the BMW Dealer or at your favorite independant shop.
- J.C. Watts Jr.
Old 03-10-2006, 06:01 PM
jryguyi's Avatar
jryguyi jryguyi is offline
BMWCCA #417796
Mein Auto: e46
Something similar happened to me. It turned out to be that the brake fluid was leeking out on the brake pads and when they got hot enough (after about 20 minutes of driving) it caused the car to shake. They had to replace the caliper, disc, sensor, brake pad and fluid.
Ryan
Orient Blue Metallic 328i
For Sale: Wahler Thermostat
Old 03-10-2006, 08:03 PM
Rogago Rogago is offline
Mein Auto: '08 335i Sedan
it happened to me once exactly as to you
it turned out to be the fuel pump
Old 03-10-2006, 08:18 PM
Oh wow you guys are overwhelming me with the possibilities, but i like it. I checked the wheels with the wrench in the trunk, but all the lug nuts were as tight as can be. I thought it might me the wheels out of balance, but after a visual inspection by myself I noticed all the weights on the front wheels were still intact. Can the wheels be out of balance and still have the weights in place? The brake fluid experience has me a bit intrigued, because the dealer recently changed the rotors and brake pads(supposedly the noise I was hearing coming from my suspension was actually the brakes). I do not agree with my dealer though. I appreciate the suggestions keep them coming.
Old 03-11-2006, 06:00 AM
Reference the wheel weights, sure, it absolutely can be a problem if the weights that remain on the wheel are still on the car. If one has fallen off you may notice evidence it was not there (marks etc.)
Best get the wheels off and spin balanced I'd say.
The brakes can be inspected with the car up on jacks (safely, of course) as well. Look for leaks, shiny spots, etc. Although for the life of me I'm not sure I can work out how brake fluid on the suspension components might induce a mechanical resonance that translates to vibration.
- J.C. Watts Jr.
Similar Threads
2003 325i 15K miles - control arm bushing gone - anyone else? chrischeung 3 Series & 4 Series 9 10-19-2004 03:47 PM
Is Lemförder (the owl) the OEM Control arms supplier? Fifty_Cent 3 Series & 4 Series 1 09-18-2004 08:56 AM
What Is The Last Model Year For E46 M3? InspireSiR 1M & M2 3 08-30-2004 06:07 PM
lip spoiler for E46 sedan and silver trim for E46 frenchym3 Classifieds 0 02-18-2003 01:02 AM
E46 Titanium Headlight Trim Kit FalconGuy 3 Series & 4 Series 9 02-16-2003 03:20 PM
