Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > General BMW Questions
Use this forum to ask general question about the BMW ownership and keep up on the latest BMW news. Direct all model specific questions to model specific forums below.
Old 10-13-2002, 08:00 PM
DrBimmer's Avatar
DrBimmer DrBimmer is offline
BMW Doc Emeritus
Mein Auto: BMW
FYI- BMW criteria for when Full Maint service can be done
Over the past years, there have been countless posts regarding when the dealer is allowed to do Full Maintenance services on a car. Some have been told they have to wait for a service indicator or warning light to come on, and others have had more liberal dealers that let them come in well in advance. I was searching through some BMW service bulletins online, and I read this update regarding the E65/66 servicing. It lays out the intervals for service as well as the tolerances for having it done under warranty. I have not seen a bulletin pertaining to other cars, but I assume it would be similar.
FYI- BMW has also eliminated the standard "Inspection 1" and "Inspection 2" services on the E65, and in their place instituted "Vehicle Checks" that are not as thorough.
CBS SERVICE ITEMS OVERVIEW
Service Items//Service Interval Tolerance (service can be performed within this range before being due)
Engine Oil
Adaptive based on Fuel Consumption and Oil Quality Sensor
15,000 miles//2,000 miles
Front Brakes
Adaptive based on 2 brake lining wear sensors and residual wear algorithm
25,000 miles//4,000 miles
Rear Brakes
37,500 miles//4,000 miles
AC Microfilter
Adaptive based on IHKA algorithm
31,250 miles//4,000 miles
Brake Fluid
Time based
24 months//4 months
Coolant
Time based
48 months//4 months
Vehicle Check
Distance based
30,000 miles//2,000 miles
Spark Plugs
Distance based
100,000 miles//4,000 miles
Automatic Transmission Fluid*
Distance based (same as Spark Plugs interval)
Oxygen Sensor*
Emissions Inspection
Time based on State Regulations
Dealer Programmable
Safety Inspection
Dealer Programmable
Notes: *Neither "Automatic Transmission Fluid" nor "Oxygen Sensor" is shown in the Instrument Cluster Display or in the Control Display. The service schedule of the Automatic Transmission Fluid and Oxygen Sensor replacement is the same as that of the Spark Plug replacement.
Service can be performed for any of the above Service Items which fall within the Service Interval Tolerance.
Maintenance Program only covers Service Items which have values within the above Service Interval Tolerance (denoted as either "Recommended" or "Due" by SAM).
_____________________
For those of you that are going to question my knowledge or my sources (as several of you have done this past week alone), rest assured that this is official BMWNA material. It is an excerpt from a BMW Service Bulletin.
