Driver-side window problem - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 03-28-2006, 08:44 PM
sillybilly5015 sillybilly5015 is offline
Mein Auto: 1994 BMW 325is
Hi, i have a 94 BMW 325is. A week ago the driver side window started "bouncing" when i drive. I call it "bouncing" because when i drive the window goes up and down very fast. You know when you get out of the car how the window drops a little and then goes up when closed to seal the window. When i drive it moves that little bit, but for along time and rapidly. the only way i can get it to stop is if i hold the window up for a few second. If i hit a bump or something it starts up again. It is very anoying!!! I have no idea why it started or what to do to fix it. Is there an adjustment i can make on the window motor to fix it? Any advice/help would be much appreciated!! Thanks.
-Ian Kantor
Old 03-29-2006, 06:55 AM
BLAMAR BLAMAR is offline
Mein Auto: 325is
you can try to adjust the latch striker, but most likely you need to replace it.
it is #6 on this diagram
http://www.realoem.com/bmw/showparts...1&fg=40&hl=217
I dont know if the link will work so goto www.realoem.com & do a serch for Part#51218105511.
I paid something like $20 at pelican parts. easy fix
Old 03-29-2006, 02:36 PM
PhilipWOT's Avatar
PhilipWOT PhilipWOT is offline
Turn Burglar
Location: Atl: Come for the pollution, stay for the traffic
Mein Auto: Red Assless Chaps
Your door may not be properly closing.
Similar Threads
Driver side electric window SilverX3 X3 E83 (2004 - 2010) 3 01-06-2006 11:38 AM
problem w/ rear psg power window... plz help ProV1 E46 (1999 - 2006) 1 10-18-2005 06:47 PM
Help. Driver's side window one-touch function not working properly betaphase E36 (1991 - 1999) 6 06-23-2005 09:16 AM
Driver Side Door AlexE46 E46 (1999 - 2006) 9 02-25-2005 12:48 PM
Driver's side door handle problem bluetree211 E46 (1999 - 2006) 0 02-17-2005 08:55 AM
