E30 (1982 - 1993)
Old 04-12-2006, 08:52 PM
eurotuner90 eurotuner90 is offline
Mein Auto: 1990 BMW 325i
MY car sometimes wants to rev by itself
Ill be driving my car and sometimes when i stop at a red light my car will sometimes rev by itself as if i was pressing the gas. It only does is sometimes anyone have an idea on what might it be
Old 04-13-2006, 07:07 AM
NC318 NC318 is offline
Mein Auto: 1991 318is
My guess, and it's only that, is that your idle control valve is either clogged with crap or defective.
Old 04-13-2006, 05:26 PM
omw41's Avatar
omw41 omw41 is offline
Mein Auto: 1986 BMW 325 E
Idle control valve /and or the idle control module that goes with it gets my vote as well. if you don't have a manual, go to EBAY to view one. changing it is sas simple if not easier than pulling a spark plug. The idel control mod is a differnt animal though.
On an 86 325ES, that module/box is located under/around the glove box area. It's green and has a number of wires that are color coded and plug into it. They fall out easily, and you've got to pay attention. But try to just change the valve first. You can get a used one on EBAY for around 20.00 dollars. Or, go top the boneyard and pull one for about ten. I feel boneyard parts are ok for the most part, if the car looks like it was taken care of and it was wrecked. I got mine from the junkyard for 10.00 and my car displayed the eact symptoms yours does. I put it in, it cleared up. Of course, a week later the fuel pump went, but that's another story.
Good Luck
Old 04-13-2006, 07:27 PM
guest1216 guest1216 is offline
Account closed at users request
Mein Auto: bike
I'm not sure but, is it possible if there is a problem with the idle control valve that your RPM would lag/twitch rather than work smoothly?
thanks.
Old 04-14-2006, 12:33 PM
omw41's Avatar
Well, I can't speak for every car, but in my 86 325 ES it did do that. I would stop at a light and it would just rev, up and down. It cleared up after I changed it. Maybe I was just lucky, but it's worth a try at under 20 bucks for a used one.
Old 04-16-2006, 03:55 AM
DominguesE30's Avatar
DominguesE30 DominguesE30 is offline
BMW FETISH!!!
Send a message via MSN to DominguesE30
Mein Auto: `97 BMW 318is
i tried everything and nothing worked. If u have tried everything and it still revs like my 325e everytime i came to a stop then get ur computers checked. Because it happened to be that mine was finished. I had it repaired and it never did it again. I would suggest talking to ur mechanic some time soon as reving at hi revs on a cold engine may damage it. I think that damaged mine a bit. No need to warry as im getting a rebuild with 325i head and cams. It could be something else. Try cleaning ur throttle and all that crap with carby cleaner. Clean the TPS (throttle positioning sensor) bye letting it soak in metholated spiritrs then letting it dry. If all these and some of the suggestions the guys gave ya check that computer HAPPY EASTER EVERYBODY
MADEINDEUTSCHLAND
`00 BMW e46 330i
`97 BMW e36 318is
Beeeeeeeee Eeeeem Double-YOU!!!!
Similar Threads
VOB BMW of Maryland has the worst service cynicalwry BMW Dealer Ratings and Feedback Forum 68 09-29-2010 01:25 AM
Test drive: BMW vs. AUDI jim2201 7 Series & 8 Series 9 09-30-2005 05:47 PM
ricer rules parts 1 & 2 ·clyde· General Automotive Forum 9 08-06-2005 08:21 PM
WTF, I need to be on the Geo Metro board instead ... TeamM3 Off-Topic 27 12-08-2003 07:51 AM
"Selling cars in the USA -- the inside scoop" alee Off-Topic 16 08-05-2003 12:48 PM
