Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M Series > E46 M3 (2001-2006)
E46 M3 (2001-2006)
Old 04-14-2006, 04:34 PM
SofaKing SofaKing is offline
Mein Auto: 04 M3
check engine light soon
13000 miles and the light turned on any ideas why?
Old 04-14-2006, 07:11 PM
deilenberger deilenberger is offline
Just another bozo..
Mein Auto: '03 525iTs '02 M3C
There are literally 100 or more reasons the check engine soon light can turn on. Simple ones like a loose gas cap, or starting the engine before replacing the gas cap to complex ones like failure of some vital part of the emissions system.
Best bet - if it persists - see your dealer. At 13,000 miles you are likely still under warranty.
Don Eilenberger
'07 R1200R, '02 M3Cic, '03 525iT
Join the BMW-CCA: https://www.bmwcca.org/members/am/te...&ref_id=104316
Old 04-14-2006, 07:17 PM
///M3lissa's Avatar
///M3lissa ///M3lissa is offline
\m/ (>.<) \m/
Mein Auto: Duh!
If you want to avoid the dealership I believe you can go to Autozone, or some similar chain and borrow a code reader to obtain the fault code.
Code explainations are listed in a Bentley manual, or you can find them online at E46 Fanatics: http://forum.e46fanatics.com/showthread.php?t=303141
Good Luck
Old 04-15-2006, 07:00 PM
Mein Auto: 04 M3
the light has now turned off i have a appointment with dealer monday i will update.
Similar Threads
Check Engine Light Comes On and Then the Car Accelerates Slowly ltran E36 (1991 - 1999) 22 05-20-2011 06:31 PM
How To Initiate Sequence For The Check Engine Light Codes? e36bmw328 E46 (1999 - 2006) 2 02-08-2009 07:14 AM
55k miles what should be done??? Vodka G E46 (1999 - 2006) 16 02-21-2006 06:42 AM
check engine light on alddie620 E36 (1991 - 1999) 0 02-16-2006 11:10 PM
