HMS Rollbar update... - Bimmerfest - BMW Forums
Old 10-20-2002, 07:30 PM
Randy Forbes's Avatar
Investigative Tinkerer
Today was the last autocross to be be held this year by our local chapter of The SCCA.
And as such, the only impression that I would get of any improvement that the HMS rollbar may have contributed to the Sue Forbes Racing Hearing Associates/Leather Z 2001 M Rdstr until next year.
I may be repeating somebody else, but now I have the impression that the tail is following the head.
That is to say that when turning into a corner, there is more continuity from the front to the back.
I have my tire pressures dialed in (pyrometer readings have confirmed this).
The shocks were set at values that I've tried before (separate bump & rebound settings).
But today I experienced less understeer than I would previously get.
My impression is that the handling of the car has improved from a stability standpoint. I feel that the platform is allowing the suspension to do more of the work it is intended to do.
So, how'd we do?
Sue ran exceptionally fast in the first heat, just narrowly missing the fastest time of heat one (taken by an SM2 Fiero 4.3 Ltr V6).
It looked like I was going to have to wear a "white apron" but by the time that I ran in the third heat, the surface had warmed up enough for me to get past her time and ahead of a ZO6 in the process. In all fairness, though I beat the ZO6 by well over two seconds, he was on (freshly ARMOR ALL'd !!) showroom rubber.
Randy Forbes
2001///M Rdstr Steel Gray
Old 10-20-2002, 09:13 PM
phrider's Avatar
phrider phrider is offline
Equine 1/4 miler ancestor
Mein Auto: 2001 M Roadster, 1998 M3
You've removed the Butt Strut and rely on the new rollbar for stiffening the rear of the chassis now, right? Did you test the car with both?
Old 10-20-2002, 10:52 PM
Ron Stygar's Avatar
19,585 Miles
Front Strong Strut is the greatest. Then why do you need a Butt strut? Butt Strut is the greatest. Then why do you need a Body Brace. Body Brace is the greatest. Then why do you need etc...
Purchase a Z4.
Stick a Garmin etrex GPS unit on your dash using the stick on mount and see if you can tell the before and after difference.
On my M coupe it's stable. On a M roadster with a strut brace it's all over the place. Loose as a goose.
My "guess" is that the HMS roll bar will improve the looseness of the Z3 roadster. I look at it as half a roof.
Old 10-20-2002, 11:21 PM
Ron Stygar's Avatar
19,585 Miles
Thinking about it (in respect to cowl shake), I'm not sure if that's the case.
Old 10-21-2002, 05:15 AM
LOL!
You should be in SALES
No, in fact, I did not even test the rollbar while the front strut was in place.
Randy Forbes
Old 10-21-2002, 06:45 AM
phrider's Avatar
So you dumped both the front strut and the Butt Strut when you added the rollbar....?
Old 10-21-2002, 08:05 AM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
Our finite element models and real world defection tests show the load between the shock towers on Z3 coupes never exceeds 150 pounds force.
Still working on roadster data.
Jon Maddux
08 E90 M3 | 06 M Coupe | 01 M coupe | 99 M coupe
http://coupenut.blogspot.com/
http://x5nut.blogspot.com/
Old 10-21-2002, 08:25 AM
The butt strut never worked out with either exhaust system (Super Sprint or Eisenmann), so it has long since fallen by the wayside.
Make you a deal on it...?
And the front strut is an added accessory not recognized in Stock Category SCCA rules, so I take it off at events.
So the rollbar has replaced nothing other than the factory rollhoops. It does however, provide stability that I never felt with the butt strut.
Randy Forbes
Old 10-21-2002, 02:28 PM
mcoupejeff mcoupejeff is offline
Piloto
Send a message via AIM to mcoupejeff
Mein Auto: ///M5, X5D
Does anyone know of a kit for a roll bar for the Mcoupe? I would rather do a premade kit, than have a custom roll bar made. Looking for safety, harness mounting capability, and stiffness. Thanks in advance!!!
JEFF
now-2000 M5
now-2009 X5 D
former-1999 M Coupe
former-2000 TDI Golf
Old 10-21-2002, 06:00 PM
phrider's Avatar
Originally posted by JonM
Our finite element models and real world defection tests show the load between the shock towers on Z3 coupes never exceeds 150 pounds force. Still working on roadster data.
So you've got strain gauges on a calibrated strut brace? I assume that was the easier part (sort of).
Now, where did you get the data to support the finite element modeling? Especially the dynamic data....
Old 10-22-2002, 06:46 AM
JonM's Avatar
Moderator
I will post all of the design data if and when we go to production. A small army of people have been working on this for several months now.
Dynamic data is not required for FEA, only for modal analysis.
Jon Maddux
Old 10-22-2002, 12:09 PM
phrider's Avatar
Jon -- this deserves its very own thread.
Old 10-22-2002, 01:56 PM
JonM's Avatar
Moderator
If and when we start selling them, I will start a new thread.
Jon Maddux
Old 10-22-2002, 04:29 PM
phrider's Avatar
If you don't, we'd like to hear why. And how did you get the structure data...?
Old 10-23-2002, 12:21 AM
Ron Stygar's Avatar
19,585 Miles
Connecting the two strut tower caps with a piece of metal is quite the challenge on a '01 M coupe. This assumes no interference with the hood, hoodliner or engine.
Working on it for over two years starting with my '00 M coupe. Design is done. Have to find someone that is into prototype development stuff with some integrity. Hoping to get a model made that I can send to some 3D CNC folks for quote.
Not counting my time, into it so far for around 2K. Spent $600 additional making just the strut caps. Not happy with the results. Respnse is that he will do it right the next time. Really torn on what to do next.
Once I get my breezeway enclosure project done, we'll look for someone new.
Old 10-23-2002, 10:22 AM
JonM's Avatar
Moderator
Not to mention the hours of engineering time and cpu time at EDS.
Jon Maddux
