5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with! |
#126
Those are the symptoms that I had, well the dead batt part. I went through 2 batteries.
Devroots.....did the FSU fix the problem?
#128
Great pics. I am on my second E39. on both this item has blown out leaving me without AC.
just did this in the parking lot. GBP 52 + VAT .. 20 minutes. The dealer was quoting 45 minutes of repair time and even mentioned the car may need to be recoded for the new part. .... i mention to him that it is just a resistor ... he replied you are right .... usefull post.
texbid@e39540.com |
#130
Thank you
This directions are great. I called my dealer and he asked for $ 400 to replace this part. I purchased it online for 68 and ended up replacing it in less than 30 mins.
Thank you all |
#131
FSU problems
Can you guys help me out! I cant seem to be able to pull FSU out, i cannot manage to push on the part and pull on the same time, no room for my fingers.. is there an easier way to pull it ..
thanks u |
#132
I need help guys, i cant seem to pull the FSU out and pushing on that piece at the same time> anyone have easier way. I TRIED everything.. my fingers all all bloody and broosed.. its seems like it doesnt want to come out!!
thanks |
#133
Elvis thanks a bunch. These directions are the best especially since they include pics.
#134
I shed some blood changing my FSU too. It really helped when I took the plastic panel off that is under the glove box. After that came off I was done in ten minutes. Had some problems getting the new FSU to snap into place but it finally went and now I have no heater problems at all.
#135
The instructions for replacing the Blower Resistor / Final Stage Unit were perfect. Job took 10 minutes and saved bundles of money. I'm sure the shop would have quoted for removing the dash etc. However, the spaces are tight, and you need to be careful not to pull wires or force things. Best to park the car with bright sunlight streaming thru the passenger side door, and augment with the best shop light you can find. After removing the plug it's probably best to tie the wiring loom carefully up and out of harm's way, so that you have a freer hand, as there's only space for a few fingers. When re-installing the FSU, the aluminum rods seem to catch on the side of the opening, so it may be necessary to remove and try again. It took 3 - 4 tries until the unit seated on its foam gasket and clicked home. Thanks!!!
#136
Elvis thanks a bunch. These directions are the best especially since they include picstures ,took me a while to find the information but it was worth it,it save me some money...
#137
thanks for the great post about the resistor,it was driving me crazy...bought the part and installed myself
#138
Is there a diagnostic procedure for determining why the interior fan stops working?
Right after my very first bimmerfest brake job, the interior fan stopped working altogether. I was told in that brake DIY to check over here regarding the cause (http://www.bimmerfest.com/forums/sho...=1#post3124559).
After reading this post, I see the fan motor problem could be the porcupine FSU or it could be the fuses apparently hidden deeply behind the glovebox. I'll definitely check the glovebox fuses; but, before I go out and get a FSU, may I ask if there is a diagnostic procedure for determining why a fan suddenly stops working? Or, is replacing the fuses and FSU the only diagnostic that is available? |
#139
I just wanted to say thanks a lot for posting this. I'm sure it saved us a bunch of money. I just ordered also the part for about $70 at bav auto, followed your instructions and it's done. My A/C is working again
Thanks to you it took me about 25 minutes and it's all done! Thanks for the great writeup Thanks again! |
#140
Difference between the old and new FSU in your hands
For all those folks who replaced their FSU, besides the obvious physical difference ...
- What was the electrical difference between the old and new FSU? Rather than run out and replace hundred-dollar parts without even knowing, ahead of time, if they're actually good or bad, would it not be prudent to first test pin-to-pin resistance (or something electrical) before willy nilly putting new parts in to replace the old? Luckily, the FSU seems eminently testable, if it's indeed just a bank of heat-sunk resistors ... a simple ohm meter might work fine if an open or short or extreme change in resistance value is the actual cause of the apparently common problem ... - Do we have a pin-to-pin spec or wiring diagram for the FSU? If, in the unlikely event, nobody has already done this, would the next person (who reads this after buying a new FSU) please report back to us the delta between an old and a new FSU with respect to pin-to-pin electrical values? Last edited by bluebee; 04-14-2008 at 12:06 PM. |
#142
Since I started this thread, I've never heard of anyone having come across such data, so it would need to be gathered.
I suppose it would be a good thing to add to the thread, but in practice, this is such a common problem with such obvious and distinctive symptoms, that replacing the FSU doesn't really qualify as "willy-nilly" in my book. That said, I would be interested in seeing exactly what the differences are between a new and faulty units.
2002 530i | Black/sand | Rondell Style 81s: 18x8.5 Front 18x10 Rear | Koni FSD | Eibach Pro-Kit | Zimmerman X-Drilled Rotors | Axxis Deluxe+ Brake Pads | StopTech SS Brake Lines | 50w 6000k Xenon Lows/LED Fogs/Phillips Luxeon LED DRLs | Angel i Brights v3.0 | Solaris Invisibulbs | Shadowline Trim | ///M5 Trunk Lip Spoiler | 35% Madico Tint | Dynavin D99+ ///M3Evolution | Backup camera | Intake Muffler, Front Plate, Badge & Cup/Coinholder Delete | Klasse AIO+SG |
#143
The next person with a replacement FSU... please compare the old and new electrically
I understand that almost everyone in this thread and elsewhere replaced their FSU whenever anything went wrong, e.g., http://www.540i6.com/finalstagereplacement.html However, some replaced the FSU and the problems persisted, e.g., http://www.dtmpower.net/forum/e36-3-...stor-help.html Some said it was the blower motor itself; others implicated the control unit; while none implicated the two sensors in the circuit. So, it's, uh, well, it's as clear as not very clear. Seems to me, the FSU can't hurt, and, it doesn't cost a lot but, it just goes against my grain to replace without testing first. If I have to buy equipment (within reason) to test the thing, well then, so be it. The question becomes what to test once the FSU is in our hands. Do we have a WIRING DIAGRAM? Oh well ... If I end up getting a new FSU (I'll wait to see if it goes out AGAIN), you can rest assured I'll ohmmeter it while both are in my hands! If the FSU is merely a bank of resistors, we'll see a short or open; if it's a bunch of power transistors, I'm not sure what we'll see ... as we might have to bias the transistors to get it to show it's mettle ... either way ... let's begin to gather the data starting with the very next person who has a bad and good BMW FSU and/or blower motor in their hands!!!!! Thanks, Donna Here, by the way, is what a BMW blower motor looks like ... Last edited by bluebee; 04-15-2008 at 03:04 PM. |
#144
Do I need to replace the FSU?
Hello all,
I have a 525TDS-1996. Symptoms: Battery goes flat so replaced it with a new one but still the same issue. My temperature needle sometimes goes up to quarter mark and other times to two thirds whereas it used to be at halfway point all the time. I have not seen any problems with my blower unit as many have reported on here. Please advise if its FSU that I need to replace or need to investigate further? Thanks in advance for any help or tips. ps. My first ever post on this forum. |
#145
Doesn't sound like the FSU, if you're not seeing blower issues.
#146
Dodgy FSU again
I finally started to see the classic blower symptoms so I went ahead and swapped out the FSU unit following Elvis's excellent detailed instructions. The issue has now been resolved.
Thanks for your help and good work Elvis. FSU costs £63 incl VAT from BMW dealer. |
#147
Thank you Elvis!!!
Just want to say big thanks.Recently had the same problem and my mechanic sent me to a main dealer.Lucky me..found your post and fixed by my self..New part coust me £63 pounds..Thank You!
#148
Here's the FSU wiring diagram from Bentley: Unfortunately, it is full of transistors, and these intermittent problems are tough to troubleshoot. F76 - Fuse 76 15 - Ignition power (RUN & START) 30 - Batt positive (+) 31 - Batt negative/gnd (-) Last edited by riro424; 04-24-2008 at 02:35 PM. |
#149
#150
The BMW FSU can be tested but it will require an EE to tell us how
But I did send your BMW FSU wiring diagram to an electrical engineer friend in the silicon valley who wrote back the following that might help the next DIY. > Does this electrical BMW FSU thingey look easy to debug? Well, if you have access to the wires in the car, I guess it shouldn't be too bad. You can see that the terminals are: 1,5) blower 2) +12 3) control input (in spite of being drawn as the collector of a bipolar transistor!) 4) ground So I would: A) spray WD40 on the contacts B) check terminal 2 for voltage C) put a two channel scope on terminals 3 and 1, and then 3 and 5 Now the question is, is that much effort worth more than the $100 or so to just replace the unit? Consider your options. Either the unit is bad, so replacing it is required. Or, the control unit is bad. That's going to cost a bundle. So maybe spending $100 is a reasonable thing to do. Last edited by bluebee; 04-30-2008 at 04:47 PM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Final Stage Resistor Instructions | texlnghorn | E46 (1999 - 2006) | 14 | 08-27-2012 05:06 PM |
| How to remove plastic bracket holding Final Stage Unit? | drkongt | E39 (1997 - 2003) | 2 | 07-30-2009 09:16 AM |
| final stage resistor install | Jdogg | E46 (1999 - 2006) | 9 | 06-01-2008 05:52 AM |
| Another Final Stage Resistor Bites The Dust | EdCT | 3 Series / 4 Series | 16 | 12-21-2004 10:11 PM |
| I just fixed my 96 328i's blower motor final stage resistor | erguy63 | 3 Series / 4 Series | 0 | 09-12-2004 01:56 AM |
