Old 04-26-2006, 02:35 PM
jpettit's Avatar
jpettit jpettit is offline
keep those wagons rolling
Mein Auto: 1999 BMW 540i Touring
Air Conditioner/Heater Blower Replacement?
My heater and air conditioner blower makes a 'chirping' noise, not unlike a fan belt slipping from time to time. Seems to be more evident when the blower is at a lower speed. I'm thinking that it needs replacing. A couple questions:
1. What part do I need? I found this blower (part # 64118372493) at realoem (http://www.realoem.com/bmw/showparts...29&hg=64&fg=40)
2. Does anyone know of a write up to replace this part? I'm guessing I have to remove the dash?
My car is a 03/1999 540iT. Thanks.
Old 04-26-2006, 06:49 PM
jwkde jwkde is offline
Mein Auto: 525i
I had mine replaced by the dealer (under warranty) They had it for 2 days, though the service ticket showed 3.38 hours.
The SA said it was a major job, Top of the dash had to come off as well as a fair number of other things
Good luck
Jim
2002 525i
Old 04-27-2006, 09:44 AM
Ryan525i Ryan525i is offline
Send a message via AIM to Ryan525i
Mein Auto: Bmw 525i
Well looking at the page you listed the unit is $202.. I would jump on that!!!! I went to bavauto.com to see if i could find you part but they dont have it listed. they have the Blower Resisto on there for $71.95 thats all thier showing for your car. But having a 03
540i @ $202 isnt bad at all. My 92 525i blower motor runs $220. Mine is out as well. Plus I need a Heater Valve aswell that runs $140... I doubt your car is still under warranty though. But if you bought that extended that bmw offers get it fixed before it goes away
92 525i
01 330i
99 Trans Am WS6 (Just Sold)
Old 04-27-2006, 01:07 PM
mdimbler mdimbler is offline
Mein Auto: 1997 540i
Mine does the same thing every once on a while, though I have not had the time, money, nor the ambition to tear apart the dash and do something about it. Autohausaz.com lists the part for $116. I believe I have a write-up at home on how to replace it (or at least how to get the dash apart). Willl look for it later and repost.
Old 04-27-2006, 01:31 PM
hmr's Avatar
hmr hmr is offline
.oo=||=oo.
Mein Auto: Bimmers
Originally Posted by jpettit
...Does anyone know of a write up to replace this part? I'm guessing I have to remove the dash...
I replaced the blower motor on my E46 for the exact same symptoms.
Replacement was done via the engine bay; the dash was left intact. As per the Bentley manual:
1. Remove housing for interior ventillation microfilter...
2. Remove heater bulkhead cover...
3. Remove intake manifold cover...
4. Working inside right side of cowl, pull up on lever and detach right intake air flap from blower housing.
5. Pry off blower cover retaining clips...
6. Remove blower retaining screws. Lift off cover.
7. Detach electrical harness connector.
8. Pry off blower motor retaining strap. Pull blower motor forward to remove...
I'd expect E39 and E46 designs to be similar in this regard. But, I could be grossly mistaken. Oh, and the cheapest price I found for my blower motor was ~$280 from Pacific BMW, including shipping, I believe.
Old 12-12-2008, 02:08 PM
mgianetto's Avatar
mgianetto mgianetto is offline
Mein Auto: 2003 540 Sport
Bring an old thread back to life. I was just told that this is the cricket sound I am hearing in my car. They said it will be $1250.00 on the light side. I wanted to tackle this my self but it looks pretty involved. I didn't see any other comments on the turnout from the OP.
Has anybody tackled this beast?
Go Blackhawks
DABEARS
I have learned that you shouldn't compare yourself to others..
they are more screwed up than you think.
RIP: 2000 540 Sport
Old 07-05-2010, 05:23 AM
Plumb Plumb is offline
Banned
Mein Auto: gfdsa
Thank you Sir, I was going to remove the console, and drop the glove box to remove the blower motor. My wife got some debris in there, and the thing was buzzing like crazy.
I followed your way and had the blower motor out and cleaned in less than 10 minutes. I sure didn't want to waste hours going to the dealer for warranty work.
Old 07-14-2011, 01:38 PM
Randy Fancher Randy Fancher is offline
Send a message via Yahoo to Randy Fancher
Mein Auto: 1997 BMW Z3
it says to pry off the fan retaining strap, can anyone give me a little more specific on that, i have been prying on mine and it appears i am only bending it?
Randy under the shade tree
Old 07-14-2011, 06:12 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Doing a /blower F3 in the bestlinks nets this which may help (see bold references first):
- What is the canonical thread on the BMW E39 FSU/FSR/Blower Motor Resistor (1) and what is the right brand FSR to purchase (1) (2) when your interior heating & air conditioning HVAC/IHKA blower motor goes haywire (1) (2) (3) (4) (5) (6) (7) (8) & how to repair your own final stage resistor including an autopsy & wiring diagram schematic (1) (2) and why a bad final stage unit will cause the battery to drain overnight (1) (2) (3) & how to isolate and replace the E39 blower motor (1) (2) (3) (4) (5) & how not to replace the FSU (1)
Old 05-14-2012, 12:01 AM
turbotrana turbotrana is offline
Mein Auto: bmw
I did this job a few days ago and would like to relay my experience.
1.I thought I could put new brushes in the mtr. In my case the armature was completely worn so no point. Guys are selling brushes on ebay but you just need a complete new mtr
2. The BEHR mtr that I got sent from USA does not appear to be a balanced mtr. It vibrates too much to the point I would consider a OEM mtr. The mtr works OK but it definately needed a balance at the factory. Not good enough for a BMW. At lower speed it wont annoy you but at higher speed it does. Luckily a female drives the car so it wont bother her. But for guys you will notice it straight away.
3. Doing this job is quite easy but I got stuck on a couple of things. In the pictures you will see this rod. You have to slide it to the left to allow you to remove one of the covers. Just clip it with a screwdriver.
4. The cover where this rod goes into is a PITA to get off (for me it was). It can require a bit of manipulation but I still dont know of the right way to clip it off. The front clips are obvious but on the rear there a no clips but the plastic is moulded so it clips on in two places. I just found it hard.
5 Markers are your friend. Put different coloured marks on all screws and components and lines on the bits that need to be lined up. It will save you time.
6. There are two screw above the glovebox that are a bit hard to remove, I bent the lower dash down to get these screws out at an angle without having to go crazy undoing everything.
Its not as hard as you think.
ID:	324984   Click image for larger version
ID:	324985   Click image for larger version
Old 12-05-2013, 04:09 PM
mnmink88 mnmink88 is offline
Mein Auto: bmw 525i
blower motor
I just replaced my blower motor on my bmw 525i 1990 i got a blower for $123 brand new from auto zone. but now my blower works and no heat idk why. just paid alot of money to get it fixed now just blowing cold air!! anyone know what is wrong now?
Old 12-05-2013, 04:11 PM
Mein Auto: bmw 525i
autozone $125
Old 12-05-2013, 04:13 PM
Burning2nd's Avatar
Under the lift arms
Do your self a favor.. and deal with the sound until it stops working...
These bmw fans do this..
you can get years and years out of it still...
15486372<-----
Similar Threads
Hamann Engine Upgrade SmoothCruise E63 / E64 6 Series (2004 - 2010) 21 10-25-2007 09:18 PM
Air Conditioning Math Question..can u help? yamato Off-Topic 28 08-10-2005 06:32 AM
Cool Air Intake Upgrade for M 3s Riuster 1M & M2 31 02-11-2004 11:33 AM
ESIS (modified stock air box) mini update 31st330i 3 Series & 4 Series 6 05-16-2002 12:55 PM
comments on the Purolator replacement air filter... 31st330i General BMW Questions 1 03-23-2002 06:42 PM
