E36 (1991 - 1999)
Old 05-02-2006, 09:22 AM
M3XTC M3XTC is offline
Mein Auto: 1995 M3 01 540I 03 M5
Oil Filter Canister Leak? Pictures
Looking for a little help. I cannot identify what this is or if I'm missing a cover or something. I just bought this 1995 M3 3.0L Coupe and it has a terrible oil leak coming from behind the oil filter canister. Any help in identifying the part or how to stop the leak is appreciated. I am attaching two pictures (one further away and one close up). There is a mirror in place so you can see the "nipple" like bolt or plug where the leak is coming from. When the car is running and the system is pressurized it can leak up to a quart in an hour to two.
Name:	oil leak 5.jpg
ID:	74826   Click image for larger version
Name:	oil leak 6.jpg
Old 05-08-2006, 12:24 AM
Please need some help
I have attached another picture so you can see where the leak is coming from and where you see that nipple looking thing is where I have the red arrow pointing at. Please help.
Name:	oil filter housing2.JPG
Old 05-08-2006, 03:06 PM
motor_werke motor_werke is offline
Mein Auto: 2008 335 coupe
No idea's here, but you could also post in the e36 M3 forum as well. Good luck.
Old 05-09-2006, 02:41 PM
fun2drive's Avatar
BMWCCA 149159
Oil Leak
Look here to find a good exploded view of the parts there in.
Realoem.com
Hope this gets you in the ballpark as to what should be there...
Old 05-09-2006, 11:24 PM
Thanks Guys. Kind of the same answer I get from BavAuto and others. Looking at the realoem is the same pic I have seen a few times. They don't list that part as a seperate piece so I've been told it's part of the whole oil filter assembly/housing. I just bought a new housing so when it gets hear and I can tear into it I will post a follow up if I learn anything. In mean time if anyone knows anything else I would appreciate the post.
Old 05-10-2006, 08:13 PM
fun2drive's Avatar
BMWCCA 149159
North Dakota
I just saw you are from North Dakota. I was born in Grand Forks and there are so few of us from North Dakota I had to say hello...
Old 09-28-2006, 02:00 PM
Issue Resolved
Finally... all fixed by a $.60 cent o-ring. I have come to find out there are two different types of oil filter housings on 95 M3's. One uses the screw in bolt like the pic I posted with the arrow and the other with the nipple thing like the pic with the mirror. Pretty much a snap ring holds back the nipple cover and there is small o-ring behind that. In the interim I tried different sealants,etc and the pressure is too high for almost anything so you must do it right with the o-ring. All is fixed and hope the follow up posts helps someone else.
Similar Threads
Oil Change Burakfb General BMW Questions 54 07-31-2013 11:23 AM
Is my 4.8is a lemon??! ZenX5 X5 E53 (1999 - 2006) 68 09-15-2007 08:08 AM
M52 Leaking oil around oil filter canister momo328is E36 (1991 - 1999) 0 11-20-2005 03:50 PM
oil change, 325 rikdee E90/E91/E92/E93 (2006 - 2013) 6 11-09-2005 10:19 PM
