E46 (1999 - 2006)
Old 05-02-2006, 12:37 PM
gthoman gthoman is offline
Mein Auto: 323I
Car starts, then dies immediatly..HELP!!
I have a 1999 BMW 323i. While I was out of town my wife drove my car and forgot to turn off the lights.....It seemed the next day the battery was dead, so she had the battery replaced...Now, the car will start(turnover), but cuts off immediatlely...sometimes it will stay on for a couple of seconds then cut off. I can keep the car on by pushing the gas pedal and holding it at like 3k rpm...........I have a Peake OBDII reader and the code showed Air mass sensor....Is there anything else this could be, or a way to verify it?? I have checked and a new air mass meter is around $350..... Thanks for any advice....
Old 05-02-2006, 01:51 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
Did you replace it with the correct battery? The E46 requires a pretty specialized battery.
If so, I'd go to an auto parts store that can test your alternator for free (most Kragens around me will). Sometimes a bad battery can kill the alternator...
Old 05-02-2006, 02:44 PM
ahspao ahspao is offline
Mein Auto: 2012 535i
My bet would be either on the MAF Mass Airflow Sensor or the ICV Idle Control Valve. Sometimes the valve gets stuck (hence the car staying on while you push the accelerator). I think you can try unplugging the MAF and see if anything changes.
Old 05-02-2006, 05:42 PM
Mein Auto: 323I
I did unplug the MAF and the same thing happened....Would this tell me anything??
Old 05-03-2006, 07:14 AM
Mein Auto: 323I
Also...I did check the battery and it was a vented battery that is suppose to be used for a E46. I haven't been able to get a volt meter to check the alternator, but I would supose this code would have been thrown if that is the problem...but who knows.....I guess I need to go with the OBDII reader..........Hopefully its right.....
Old 05-04-2006, 09:56 AM
Mein Auto: 323I
Well, unfortunately that was not the problem....or at least not the ONLY problem...I replaced the MAF and the same problem....I drove it around the neighborhood just to make sure I could take it to the mechanic if needed and check the codes again.....It added another code, Ignition Control Valve mechanically stuck.......So, I've removed that and am ordering the part.......Hopefully the computer is right this time....There was alot of build up, so hopefully that will fix it.....I might also try to clean it with some WD-40 or carb cleaner, I've seen some other posts that people just cleaned it.......
Old 05-04-2006, 09:57 AM
Mein Auto: 323I
Oooopss....I meant Idle Control Valve....
Old 05-04-2006, 10:29 AM
gil4saturn gil4saturn is offline
Mein Auto: 323 i
let a pro look at it i have the same car
Old 05-09-2006, 07:48 AM
Mein Auto: 323I
Well, the problem was the Idle Control Valve....replaced it and now its fine....
Similar Threads
How to Save Money Doing Euro Delivery Nat Brown Ask-A-BMW-Dealer 142 11-07-2014 08:23 PM
Would you keep your E65/E66 once the maint/warranty expires (really long) klm187 7 Series - E65 / E66 (2002 - 2008) 10 10-26-2013 11:28 PM
VOB BMW of Maryland has the worst service cynicalwry BMW Dealer Ratings and Feedback Forum 68 09-29-2010 01:25 AM
The $95k E46 M3 BlackChrome General Automotive Forum 19 06-01-2006 05:32 PM
Car starts but won't stay running!! rb25ds14 Do-It-Yourself H.Q. 4 11-01-2003 03:52 AM
