Old 05-08-2006, 02:44 PM
drillbit drillbit is offline
Mein Auto: 2006 550i
How to remove stuck wheels?
Is there a secret to removing BMW wheels? I have removed the bolts, kicked on the wheel and still they to not budge? Am I missing something?
Old 05-08-2006, 03:11 PM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator, 5-Series
Mein Auto: Trek 6500 MTB
Lean back, butt on the floor and brace your back against something and start kicking back and forth alternating with your right/left legs on the outer edge of the tire. Just keep whomping on it hard back and forth...she'll pop free!
There is a tiny lip that the BMW wheel rests upon (aids you in holding the wheel onto the hub as you thread the bolts) and it can get stuck on the lip.
2001 530i/5 (E39), Topaz Blue/Stone Green/Black (sold) *very rare interior/exterior color combo*
2005 545i/SMG (E60), ED Order, Titanium Grey/Grey (lease over)
2014 335i/8-spd, Mineral Grey/Black (lease take over)
Old 05-08-2006, 05:59 PM
mullman's Avatar
mullman mullman is offline
friend of the marque
Send a message via AIM to mullman
Mein Auto: '09 MINI, '09 HD, '67 BMW
Are you removing the tires or the wheels?
If just the wheels I would use a big rubber mallet and wrap on the tires after the lug nuts are out. Sometimes surface rust will hold them tight.
If removing tire, post back and I will reply with detailed instructions.
• BMWCCA VBMWMO BMWVMCA •
'09 MINI S: 'Ronin' '09 H-D Nightster '67 R60/2+'52 Steib sidecar
•previous '95 318i '00 540i6 '61 R50S '69 R69US '98 R1100R '65 R50/2 '64 R50/2 '07 BMW 530i6 ED
Old 05-09-2006, 07:47 PM
quackbury's Avatar
quackbury quackbury is offline
///Monkeyazz Duck
Mein Auto: 535i M Sport; 328i Wagon
I once had mine stuck so badly that the kick-'em hammer-'em routine didn't work. So I VERY slowly and VERY gently let the jack down until the wheel began to take up weight. That broke the seal.
Not for the faint of heart, and probably a really, really bad idea with a floor jack, but worked okay with the stock jack from the trunk. (At 10:00 at night with a 8" dump of snow predicted for the next day, I really didn't have any choice - I needed to get the winter wwheels and tires on RIGHT NOW).
Current BMW's:
2014 535i MSport Space / Black, ZCW, ZDA, ZLP, ZLS, ZPP, H-K and 704
2015 X1 28i xDrive Alpine / Black, xLine, ZCW and Ultimate
2015 X1 35i xDrive Black / Black, ZCW, Ultimate and Xenons
Prior BMW's
2014 328i SportWagon
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
2003 540iA M-Technic
Old 05-09-2006, 10:36 PM
5serius 5serius is offline
Mein Auto: 2006 530i
Does this also apply to run-flats? I had the same problem ealier this year when I wanted to add spacers. Rather than pay someone thirty bones, I decided to do it myself ( I have done before on my G35 and CLK with no problems). For the life of me, I couldn't get the frickin' front wheel off the hub!!!
Given, I didn't kick the thing as I assumed (don't you say it!) a $60K car wouldn't take well to that type of elbow grease. I read the manual and it said something about a special kit needed to remove run-flats. Not sure if the kit is needed to remove tire from wheel or wheet from hub?
Any advice?
Old 05-10-2006, 07:29 AM
DD694 DD694 is offline
Mein Auto: 2009 335i E92 or E90
Any advice?
Run-flats need special treatment to remove tire from wheel. Otherwise no different than any other tire to remove from wheel from hub, except for weight. RFT are very heavy.
Old 05-10-2006, 07:36 AM
Patrick Patrick is offline
Banned
Mein Auto:
WRT to removing the wheels (for example, changing from winter wheels/tyres to the summer set), simply employ extreme violence. They will come off - trust me.
Old 05-10-2006, 09:54 AM
Ågent99's Avatar
Moderator, 5-Series
Envision something on the tire that infuriates you to no end and just pound the living sheeet out of it until you feel better.
I recently had to get the drums off the rear wheels of my old Toyota Pick-Up. One side I practically pulled off with my hands. The other side took SEVERAL swings of a ball-peen hammer...then my neighbor came over and took SEVERAL swings with a ball-peen hammer. Then we dug out my 3 lb mini-sledge hammer and we each had a round with that one. I finally landed the swing that lodged it free. Rust in a snuggly fitting joint can be mighty tough!!
Old 05-10-2006, 10:01 AM
Banned
Mein Auto:
The employment of extreme violence method (after all other rational ideas fail) is something that I learned from my aircooled Volkswagen days. Especially when removing the rear brake drums.
For Volkswagen matters, if even violence failed, then you had to combine that with extreme heat (blow torch).
Old 05-10-2006, 08:43 PM
quackbury's Avatar
///Monkeyazz Duck
If you are like me, it helps to place a photo of your mother-in-law in the target area.
Current BMW's:
Prior BMW's
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
Old 05-11-2006, 08:07 AM
Ågent99's Avatar
Moderator, 5-Series
Old 05-11-2006, 08:12 AM
Banned
Mein Auto:
If I did that, I would probably end up severely damaging my car.
Old 05-11-2006, 08:17 AM
mohrgan mohrgan is offline
Mein Auto: BMW 328i
I usually do this with the lug nuts on but loosened. Sometimes I even drive the vehicle a foot or two!
Usually this occurs with new vehicles only as once I get the wheel off I then apply never-seez or NAPA anti-seize compound to the hub and also to the lug nut threads.
I reapply every 6 months or so.
Old 05-11-2006, 01:24 PM
avalys's Avatar
avalys avalys is offline
Nothing specific
Mein Auto: 03 325Ci 5spd SP
Any advice?
Consider that nothing you do the wheel with your hands (or small hand tools) can even come close to what happens when you hit a pothole while taking an offramp at 60 mph. You're not going to damage anything.
Old 05-11-2006, 01:48 PM
gojira-san's Avatar
gojira-san gojira-san is offline
Happy Trails!
Mein Auto: 330xi
I put some Lubriplate (high-temp lithium grease) on the hub before mounting my winter or summer wheels and have not had a problem yet. A little tiny bit is all you need. if you have some rust on the hub carrier a little fine sandpaper 1st helps too to smooth it down.
04 BMW 330xi 6spd w/Premium,Sport,Winter & Xenon (Sold, sniff)
02 BMW K1200RS moto
06 Pontiac GTO 6MT
RIP '99 BMW 528iT
Old 10-21-2007, 10:56 AM
batmmannn batmmannn is offline
Mein Auto: 93 325i
Sitting here getting ready to kick the crap out of my tire. Came to search for solution. Wish I was mad at someone right now. Scott
Old 10-22-2007, 12:43 PM
bobr2001 bobr2001 is offline
Mein Auto: BMW 525d 2011
A big hammer!
Old 10-22-2007, 04:43 PM
izen2 izen2 is offline
Loosen the bolts about two turns lower the jack and then jack up the oposite side and rock the car.
Lesson learned from the days of the Model T and A.
Old 10-23-2007, 07:01 AM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
Thumbs up
+1
cheers
vern
2012 335iA Blk. Sapphire- Sport-Blk. Dakota Leather/Red-Brushed Alum.Trim-DAP-PP-CWP Rear View Camera-BMW Asst w/Enhanced BT&USB-High Gloss Blk.Trim Hghight-PSP-Speed Limit Info-Tech. Pkg-PDC-Rear Manual Sun Shades-SAT-Variable Sport Steering-Wheel Locks- Rubber Mats-Euro Del 5/14/12-Redelivery 7/16/12 2006 X3 3.0iA 4/6 Silver Gray Metallic-Black Leather-Nav-PP-SP-Xenon Headlights-PDC-Heated Front Seats-Privacy Glass-Servotronic Steering-Premium Sound System-R R R- Wheel Locks- Rubber Mats
Old 10-16-2012, 06:32 AM
DaIceCreaMan DaIceCreaMan is offline
Mein Auto: 2011 BMW 550XI
Apparently my wheel is stuck as i removed the 5 lug nuts and its not budging like there is another nut holding it on.
I have a 550i so i assume I just lower the car and drive a foot? Seems really crazy to me lol
Old 10-16-2012, 07:02 AM
pcy pcy is offline
Mein Auto: '06 530i, '07 C280, ML320
To prevent this situation, I always put little bit of anti-seize compound on the hub and the back of the wheel center where it meets the hub. Wheels come off easily since the anti-seize compound prevents the oxidation and rust.
Old 10-16-2012, 07:13 AM
I got it to come off by banging the spare tire against it. Man!!!
Old 10-16-2012, 12:39 PM
z0lt3c's Avatar
z0lt3c z0lt3c is offline
what does this button do?
Mein Auto: 08 535xit
Another trick is to spray PB blaster into the empty lug holes, and around the hub if needed. Give it about 15 minutes and it should come off much easier. I'd rather make a mess then use violent force.
Old 10-16-2012, 09:03 PM
booyaazaa's Avatar
booyaazaa booyaazaa is offline
Mein Auto: '09 AW 535i, Fiat 500e
Wow that brings back memories of my old Toyota p/u.
2009 AW 535i
-Sport, Premium Package, and Comfort Access
-FBO, custom Cobb E45 map, Fuel_it Stg2 LPFP, Performance Gearing LSD.
Follow on IG: Booyaazaa
Similar Threads
Premium Package or Wheels? .Nikki. E90/E91/E92/E93 (2006 - 2013) 28 08-18-2005 10:10 AM
18" E46 M3 Replica Wheels and Tires FS Driver8 Classifieds 0 09-19-2004 07:01 PM
19" Racing Dynamics RS-2 Wheels with Tires in SoCal Choson1 Classifieds 0 11-06-2003 03:40 PM
BMW Wheels vs. Aftermarket/Replica/Refurb (Which to get?) OBS3SSION General BMW Questions 37 02-24-2003 07:42 AM
330Ci - 17" vs 18" Stock Sport Wheels MikeW 3 Series & 4 Series 34 08-03-2002 01:41 PM
