E60 (2004 - 2010)
Old 05-10-2006, 04:53 AM
Fantastic Five Fantastic Five is offline
Mein Auto: 2006 BMW 550i
High Speed Dancing
I'm starting to think either the aerodynamics or the run-flats are the cause for wiggling at high speeds . . .
I had the car running yesterday, and it was wiggling. Yeah, it could've been oversensitivity to the pavement, but I'm not sure. Even if it was, could it be that the run-flats are that sensitive?
or is it the aerodynamics?
Anyone have the same problem?
Old 05-10-2006, 06:27 AM
DD694 DD694 is offline
Mein Auto: 2009 335i E92 or E90
I have found some wiggliness when on roads that have been grooved to aid grip in the wet. Otherwise, no problems at speed.
Old 05-10-2006, 07:11 AM
Spartacus_33's Avatar
Spartacus_33 Spartacus_33 is offline
Spartacus_33
Mein Auto: 2008 Black Jeep Wrangler
Depends on what you consider "high speed". I had mine at 120 on the autobahn and didn't notice any wiggling...........perhaps that was because the tires were new.
Thanks,
Spartacus_33
2012 Audi Q5 3.2
2005 Jet Black/Black 545i - Retired
1999 Jet Black/Black 528i - Retired
1996 Jet Black/Black 328i - Retired
Old 05-10-2006, 07:18 AM
merklebob merklebob is offline
Mein Auto: 650, 330xi 545man [sold]
im with Spartacus_33 just had my 545 a little over 100 in montana and it was rock solid. its still got the donlap RF tires with 10,000 miles. its my first bmw the didnt have a little float at over 100mph [328,330i,330cic all with sport ]]
Old 05-10-2006, 10:18 AM
Spartacus_33
As mentioed earlier... I haven't noticed the "speed" affecting the car... but RUTS... that's a different story. These summer performance tires (not necessarily just the RF tires) are really sensitive to ruts in the road. All 3 of my bimmers have thrown me back an forth across the lane when encountering wear ruts in the pavement. This is called tramlining. I've only noticed this with my bimmers, but then again these are the only cars that had/have real performance tires. Is this what your are referring to?
Thanks,
Spartacus_33
2012 Audi Q5 3.2
Old 05-10-2006, 11:16 AM
Ace88 Ace88 is offline
Mein Auto: X5 35d
Does anyones steering wheel turn rapidly to the left when hitting the brakes??
Old 05-10-2006, 07:49 PM
quackbury's Avatar
quackbury quackbury is offline
///Monkeyazz Duck
Mein Auto: 535iX M Sport; X5 35D
Ace, it shouldn't do that. On level pavement you should stop dead straight, even with your hands off the wheel.
Check your air pressure (don't count on the TPM to be accurate, as it may not have been calibrated correctly). I'm willing to bet your left front is low on air. Failing that have the dealer check your alignment.
Let us know what you find.
Current BMW's:
2011 535xi M Sport TiAg / Black, ZPP, ZP2, ZCV, ZCW, ZDA, 2TB, 6NR, 465, 5DL, and a Partridge in a Pear Tree
2011 X5 35D Deep Sea Blue / Oyster, PP, SP, PSP, CWP, Tech, 20" 214's
Prior BMW's
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
2003 540iA M-Sport
Old 05-11-2006, 07:12 AM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator 5-Series
Mein Auto: Trek 6500 MTB
She was solid at this speed!!
Pulling one way or the other can be several things but if it happens when hitting the brakes, I suspect there is an imbalance in the hydraulic fluid pressure feeding the braking system. In other words, the side that the car pulls to has a higher clamping pressure on the discs versus the other side. There could many reasons for this.
2001 530i/5 (E39), Topaz Blue/Stone Green/Black (97k miles)
2005 545i/SMG (E60), ED Order, Titanium Grey/Grey (lease transferred...no longer have)
Old 05-11-2006, 10:15 AM
Me530's Avatar
Me530 Me530 is offline
Happily Driving
Mein Auto: 2011 550i M Sport
Mine was solid up to 125....
Have you checked the inflation of your tires?
2013 X3 35i, Dealer Delivery
2011 550i M Sport, European Delivery
Gone, but not forgotten:
2006 530i
, European Delivery
2008 335i Coupe 6MT, PCD
BMWCCA #350568
Old 05-11-2006, 10:25 AM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
Ditto.Since the Autobahn I've had mine up to 105mph for a good 5 minutes with about 6000 to 7000 miles on the tires with out any problems,( except getting a ticket in SC) IMO the faster you drive the car the better it feels.
cheers
vern
2012 335iA Blk. Sapphire- Sport-Blk. Dakota Leather/Red-Brushed Alum.Trim-DAP-PP-CWP Rear View Camera-BMW Asst w/Enhanced BT&USB-High Gloss Blk.Trim Hghight-PSP-Speed Limit Info-Tech. Pkg-PDC-Rear Manual Sun Shades-SAT-Variable Sport Steering-Wheel Locks- Rubber Matts-Euro Del 5/14/12-Redelivery 7/16/12 2006 X3 3.0iA 4/6 Silver Gray Metallic-Black Leather-Nav-PP-SP-Xenon Headlights-PDC-Heated Front Seats-Privacy Glass-Servotronic Steering-Premium Sound System-R R R- Wheel Locks- Rubber Matts
Old 05-11-2006, 10:28 AM
Mein Auto: X5 35d
Hey guys,
Car is going back in again. The dealer really is awesome and is working with me on this, but from what the dealer tells me of BMW they are not so easy to work with.
My advisor is having a very difficult time getting the "design team" and the "PUMA line" to get back to her. It has been 2 weeks now....nothing.
Here it is in a nutshell:
Constantly making several left and right corrections or twitches to the steering wheel to keep it from wandering one way or another.
Steering wheel WHIPS to the left if you hit the brakes regardless of speed or road conditions i.e. ruts, slant, angle, etc.. Tire pressue is 35psi rear 30psi front cold. That is what is stated on my drivers door jamb for my tire size.
Old 05-11-2006, 11:38 AM
Ågent99's Avatar
Moderator 5-Series
Bump up the pressure all around about 5 psi and see what you think. Can't hurt anything.
Old 05-11-2006, 11:47 AM
quackbury's Avatar
///Monkeyazz Duck
Shouldn't take your SA that long. I don't mean to step on any toes, but the fact the dealer is "awesome" and "working with (you) on this" does not necessarily mean your SA and tech are competent to solve the problem.
I would be inclined to raise this to the next level, by sending a registered letter to the dealership principal and BMWNA stating that :
(A.) In your opinion it is a serious safety defect;
(B.) You have made __ good faith attempts to have the problem corrected;
(C.) Unless you receive a satisfactory response by May __ you intend to pursue relief under your state's lemon law.
I know that the BMWNA folks often read and respond to posts on other forums - I am too new to Bimmerfest to know if that is the same here, but it may not hurt to gripe about your experience on another board or two as well.
(Admin, can I post the term RF here?)
Good luck!
Current BMW's:
Prior BMW's
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
2003 540iA M-Sport
Old 05-11-2006, 12:36 PM
Mein Auto: X5 35d
Hey guys,
Thanks for the input.
We will see what Hendrick BMW in Charlotte can do for my car. One thing for certain is that my car is not right.
Old 05-11-2006, 01:21 PM
Ågent99's Avatar
Moderator 5-Series
Good luck!
BMWNA will occasionally post on here but I haven't seen them in the 5er forum in quite some time.
Ah, which RF term are you thinking about?
Old 05-11-2006, 01:33 PM
Me530's Avatar
Happily Driving
Radio Frequency?
2006 530i
, European Delivery
BMWCCA #350568
Old 05-11-2006, 07:31 PM
quackbury's Avatar
///Monkeyazz Duck
Roadfly.com is where I USED to hang out before I discovered this FAR SUPERIOR site!
Seriously, the E39 board there was great. Can't say the same for the E60 board. But I know BMWNA monitored RF, so it can't hurt to make a post there, then come back to all us vastly more interesting folks on Bimmerfest!
Current BMW's:
Prior BMW's
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
2003 540iA M-Sport
Old 05-11-2006, 08:10 PM
vegastrashed's Avatar
vegastrashed vegastrashed is offline
Sung Hi Lee avatar :P
Mein Auto: 2007 E63 AMG
I read in e60.net about the mass exodus from RF e60 forum back in '04. I go there every now and then, notice it is pretty much a barren wasteland. Not too much of any meaningful content there. I'm not hating on RF, it's just my observation is all.
2007 E63 AMG, some mods
2005 545i Sport SMG (Gone but not forgotten)
Old 05-11-2006, 08:21 PM
DBU's Avatar
DBU DBU is offline
Send a message via Skype™ to DBU
Mein Auto: A rare Mystic Blue 530
Wasn't there another thread with this problem and a solution?
Have them change the Steering Position Sensor Switch. That worked for someone else. The "problem" is that no fault codes are thrown. Let us know. I am speculating that the faulty switch throws off DSC which then send brief brake instructions to individual wheels. It feels like the wind is catching the car, right?
His: 2007 530i - ED
Mystic Blue -- Black Leather -- Anthracite -- Multi-contour Seats -- Premium Package -- Steptronic -- Navigation
Ordered: 4/12/06 -- Production Number: 4/17/06 -- VIN/Start of Production: 5/15/06 -- Completed: 5/20/06
Munich Pick Up: 6/22/06 -- Dingolfing: 6/23/06 -- Drop Off: 7/12/06 -- Aboard M/V "Green Point" with ETA Port Hueneme 8/16/06 - Redelivery: 9/1/06 - De-badged 1/1/07
Hers: 2007 X3 3.0Si
Old 05-12-2006, 08:14 AM
Ågent99's Avatar
Moderator 5-Series
Yes, that thread is stuck near the top of the forum and FF is quite well aware of it. I just hadn't thought it might be related but now I think it could be!
Old 05-12-2006, 04:24 PM
It's not that the car needs correction . . .it's that it feels like it's being hit by severe crosswinds knocking it back and forth at serious speed . . .
It may be the grooves in the road, but I was just making sure it wasn't an aerodynamic phenomenon or a runflat issue.
Old 05-13-2006, 01:32 PM
Charles Charles is offline
Mein Auto: 2x 07 530i
I am having the same problems @ 112 - 125mph once I get up to 130mph it smooths out. I was thinking that maybe I was getting more downforce at higher speeds? It feels real sensitive to the drafts of other vehicles (especially semi's). My little Acura ITR is glued to the autobahn at the same speeds. I do not have the run flats nor the sports package on the 530. I have the allweather conti's that are V rated. I was also thinking that a front chin spoiler might help. Underneath the car is so flat and smooth it probably creates lift like a plane wing.
Old 05-13-2006, 01:36 PM
So if I turn of the DSC, I shouldn't experience the problem at these speeds?
Old 05-14-2006, 01:17 PM
DBU's Avatar
DBU DBU is offline
Worth a try, eh? Let us know if you feel any difference.
Please understand that my assertion is nothing but an unproven theory at this time. I experienced "the wind catching the car" syndrome at 60 MPH on a calm day test driving a 2006 530 with sports package, incl. RF tires. The feeling I experienced was consistent with the car applying small periodic brake pulses to individual wheels, which is what DSC can do.
His: 2007 530i - ED
Hers: 2007 X3 3.0Si
Old 05-15-2006, 06:14 PM
sdriver's Avatar
sdriver sdriver is offline
Mein Auto: 2004 530i/SMG
I've cruised at 150MPH in my '04 530i (Between Los Angeles and San Jose on interstate 5)... had none of these problems. The car would just go straight.
Should definately have it checked out...
Similar Threads
Those videos of idiots taping their high speed racing.... Guest84 Off-Topic 6 03-16-2006 01:49 PM
X5 4.4 squeeling noise in dash at high speed? mikef X5 E53 (1999 - 2006) 2 09-27-2005 04:45 AM
W00t: Speed limit in West Texas raised TeamM3 Off-Topic 3 08-29-2005 08:55 PM
Cable High Speed Internet piku Off-Topic 26 08-19-2003 11:43 AM
Do those of you w/o high speed (cable modem, DSL, T-1, etc.) hts Off-Topic 4 12-24-2001 07:55 AM
