Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today! |
E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
1994 325ic Parts Replacement Questions
Hi there... First post, and I have a couple questions.
Mechanic says I need the Valve Cover Gasket, Spark Plugs and ignition coils replaced because the gasket is leaking oil into the spark plugs and shorting them out, which is why the car intermittently won't start, and then miraculously does later on without anything being done to it. The valve cover gasket and plugs were replaced about 4 years/45,000 miles ago by the previous owner. Same thing with my rear shocks-- replaced about the same time, and according to the mechanic, they're gone and that's why when I hit a bump in the road it feels like the car is fishtailing. Should any or all of these need to be replaced so soon? My concern is just that it's an expensive project, and being a woman I'm always paranoid when I'm told that something big needs to be done. I know something is definitely leaking (and I did think it was oil), because I see it in my driveway.... Thanks for the help, and I've already learned a lot over the last year or so reading all your posts! |
As a fellow '94 325ic owner...
Not sure I accept your mechanic's diagnosis on the starting problem. Virtually all E36's leak around the valve cover gasket, and you find oil around the plugs. I'll probably do the gasket this fall, but mine only leaks a very small bit.
However, if they are leaking enough to fill up around the plugs and run over, then definitely, get the gasket done ASAP. While he's in there, obviously replace the plugs. As to the coils, my first instinct, especially given the cost, is the clean them and use the old ones. If the problems persist, and he still thinks it's the coils, they are very easy to test and replace. Now, on to the rear shocks. I think he's dead on with his diagnosis there. The convertibles carry a lot of weight in the rear, so I'm not terribly surprised yours are going already. I just replaced mine with Bilstein Touring shocks (NOT the Heavy Duty ones). You can probably get them at or below the cost of OEM and they give a very comfortable ride that's just a slight tad firmer than stock. My $0.02 Hope it helps. Matt Last edited by SouthernBoy; 05-12-2006 at 10:19 AM. |
Vert Parts
You can replace the valve cover gaskets yourself as it takes no special tools. It just takes some time and you save a lot of labor. The rear shocks will wear out but most likely the rear shock mounts or the rear trailing arm bushings might be bad too. I run Bilstein sport shocks on my vert because I have sport suspension. If you have stock suspension I recommend the Bilstein HD shocks which will not ride harsher but will last a long time and have a lifetime warranty...
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| BMW,NA Offering Free Pixel Replacement Parts | jcarlosfox | 7 & 8 Series | 20 | 03-29-2008 10:34 PM |
| Replacement parts? | Nabbidy | 5 Series | 2 | 06-17-2003 12:31 PM |
| BMW,NA Offering Free Pixel Replacement Parts | jcarlosfox | 5 Series | 8 | 05-27-2003 04:56 PM |
| BMW,NA Offering Free Pixel Replacement Parts | jcarlosfox | 7 & 8 Series | 0 | 05-17-2003 10:34 PM |
| BMW parts vendors to avoid | Nat Brown | General BMW | 0 | 04-05-2002 08:12 AM |
