Old 10-29-2002, 09:02 AM
Tomo Tomo is offline
Mein Auto: '01 M Coupe
Alignment Specs
Hi guys,
Well, I had a small incident at Watkins Glen this past weekend where I spun the car and went sideways into the gravel pit. Anyhow, I am going to be going to my guy to have the alignment checked, but he needs to know what the specs are. My car is a 2001 M Coupe with no suspension mods.
Also, in the 01/02 M Coupes, for the rear diff, what are the torque specs on the drain and fill plugs? As well as the part # for the crush washer that goes there?
On a side note, out of curiousity, does anyone think BMWNA will void the rear diff warranty, if I use the SAF-XJ with FM Booster that Atylcb posted earlier? The output shaft on the driver side popped out of its lock ring and its pouring out diff oil. Anyhow, many thanks again to Randy Forbes for giving me the fix info on that.
And many thanks in advance for the information.
Cheers,
Tomo
Old 10-29-2002, 09:16 AM
Ron Stygar's Avatar
19,585 Miles
Re: Alignment Specs
http://www.unofficialbmw.com/e36/dri...id_change.html
Old 10-29-2002, 11:08 AM
Ron Stygar's Avatar
19,585 Miles
Re: Alignment Specs
Old 10-29-2002, 02:52 PM
Many thanks for the quick and good information Ron!
Cheers,
Tomo
