E60 (2004 - 2010)
Old 05-21-2006, 02:36 AM
Suraj Suraj is offline
Mein Auto: vw
Engine design, rev limiter, free revving..
I am planning to ED a 530iA soon. This will be my first BMW. I have a set of questions
1) BMW Engine/transmission design really intrigues me and I want to know a lot more about it. Please point me to some good sources (preferably meant for dummies so that content is easy to understand) where I can find detailed information on topics like direct injection, forced induction, engine management maps, automatic transmission science, turbo charging, super charging, torque vs HP concerns etc. The information on bmwusa.com and bmwworld.com are good starting points which I have already read and I want to know more.
2) It is said that BMW I6 engines are free revving. In my test drives I have felt what it means, you just floor and the engine revs without hesistation. But what causes an engine to be free revving? Why isn't some other engine like a Ford free revving?
3) What is the rev limit on a 530iA? Is it dependent on the gear you are in?
4) In Steptronic with manual mode, why doesn't the engine just upshift when you have hit the rev limit?
5) How much is the breakin RPM on a 530iA? I have heard some people say 4K while others have said 5.5K. What is the maximum speed you can attain at such RPMs? I am thinking of reaching close to that speed on the autobahn during ED.
6) What needs to be 'broken-in' in an engine? Engine is mostly metal and oil, so it should be set to perform to the fullest from day 1? Am I missing something basic here?
Old 05-22-2006, 09:59 AM
Mein Auto: vw
Awaiting replies..
Old 05-22-2006, 10:31 AM
revlis240 revlis240 is offline
Mein Auto: SC400, 330Ci, 550i
1) www.howstuffworks.com www.google.com
2) the engine has double VANOS and 4 valves per cylinder, this causes the engine to breathe easier than a fixed timing/valve lift 3 valve per cynilder (example) ford engine
3) 7000 (probably?)
4) because youre in manual mode and you have control. bouncing off revlimit wont break the engine
5) just drive it normal
6) just like brake pads and rotors, the surfaces on the piston rings must mate to the cylinder walls. there are different theories on breakin in procedure, i tend to follow the "drive it normal w/ few spurts to 5k" theory
Abe
Old 05-22-2006, 10:39 AM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator 5-Series
Mein Auto: Trek 6500 MTB
Congrats! You will love it and the trip!
6800 RPM I believe...maybe 7200. The rev limit is the rev limit...doesn't matter what gear you are in...it doesn't change dependent upon the gear in the tranny.
To be sure, ask when you pick up the car and check the manual but it usually is 4500 RPM that you should not go past (speed is irrelevent, it is RPM that you should watch). That kind of room will allow you easily to get past 100 mph in 6th gear.
2001 530i/5 (E39), Topaz Blue/Stone Green/Black (97k miles)
2005 545i/SMG (E60), ED Order, Titanium Grey/Grey (lease transferred...no longer have)
Old 05-23-2006, 11:00 AM
Nickmitbm Nickmitbm is offline
Mein Auto: Audi A4 1.6
What's breakin RPM???
Old 05-23-2006, 11:34 AM
credit777's Avatar
credit777 credit777 is offline
Mein Auto: 750i
Step will do exactly that if you put it in drive sport (DS) mode. Floor it an hold on!!
I've never tried putting it in M(anual) mode and flooring it without shifting - but I think if you don't shift, the computer puts the car in DS mode automatically and shifts accordly.
Again...I could be wrong since I haven't tried that. (nor do I really want to )
[His] 2006 750i Sport - Jet Black, 21" wheels, premium sound, luxury seating, convenience, comfort access, Sirius (Jet)
[Hers] 2008 650i - Metallic Black, Sports, Prem Sound, HUD, HD Radio, Cold Weather, Sirius (Shiloh)
Moved on from:
2005 645Ci (Ava)
2004 545i (Chief)
2002 330i (Kira)
1998 528i (Slick)
1999 540i (Sly)
Old 05-23-2006, 11:38 AM
Ågent99's Avatar
Moderator 5-Series
4500
Old 05-24-2006, 07:39 PM
SteVTEC's Avatar
SteVTEC SteVTEC is offline
Mein Auto: '11 E93/335i
What you're asking for is a more advanced understanding of engine design, but to get that you have to understand the basics first. Somebody mentioned www.howstuffworks.com which is a good source, but also check out AutoZine Technical School. That should keep you busy for awhile. If you want to tinker and see how changing different parameters can affect vehicle performance, try out www.cartestsoftware.com/ There are also a ton of good links to read up on at the Stealth316 Tech Index. Beyond that, I could recommend some good automotive / engine engineering textbooks, but they're rather pricey and would be tough to find used (ebay).
- short and aggressive gearing with prompt downshifts (auto)
- lightweight flywheel (manual)
- low inertia drivetrain with weight optimized components.
- vibration free operation (inherent in the Inline-6 configuration) and low NVH
- good top-end power (4 valve per cylinder engines have the advantage, but 3 and 2 valve engines can have great top-end also)
Steve
2012 E70 X5d (IT'S HERE!) Deep Sea Blue / Sand Beige, Premium, 3rd Row, Multi-Contour
2011 E93 335i Deep Sea Blue / Oyster, Step, Premium, Convenience (PDC & CA), and that's it
more pics here
Similar Threads
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 07:20 AM
BMW's New Six-Cylinder Engines - In Depth sk330i General BMW 7 07-19-2006 04:52 PM
335 news release today => 535 next year klu123 E60 (2004 - 2010) 34 04-26-2006 03:35 PM
BMW Update for S54 Engines BMWNA M Series 2 08-13-2003 05:55 PM
