Do-It-Yourself H.Q.
Share your DIY projects or ask questions about how to fix something on your own. Help fellow Bimmerfest members improve your wrench turning skills! All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need! |
I've just noticed that all the nut measurement in the Bentley's manual are some bizzare sizes...For example, the self locking nuts that holds the strut towers and the shock mounts are 13mm metric sized, but the manual lists them as M8 nuts. Also, the 17mm nuts that holds the swaybars are listed as M10 nuts.
Anyone have any idea how these units convert into Metric measurement?
You always spec a nut by it's thread, not the size of tool used to work with it... So in this case, the M8 is an 8mm thread and the M10 is a 10mm thread.
In American measurements a 5/16" nut uses a 1/2" wrench... (that's the closes equivalent to your metric M8 / 13mm example)
New Sig SOON!!! Just need to find time to make an 11 MB flashing sig file for my new truck Does anyone rememeber my BMW? Last edited by LilEccentricJ; 10-29-2002 at 09:09 PM. |
If I am not confused, there is a table somewhere way at the beginning of the Bentley which tells you about the M sizing.
'01 330ci |
Thanks doode.
'01 330ci |
Re: M measurement in Bentley's manual...
0wN3d. |
The problem with head size is that the head could be a different size but the bolt could still thread properly. I believe the M system dictates what thread goes with what head size.
I hate how with standard SAE stuff you could easily have 2 bolts with the same head size have totally different thread pitches and make it easy to strip threads. |
![]() '88 M3 Conforti chip, Evo airbox/K&N filter, UUC short shift kit, oil pan baffle, Hella H4 lights, OEM glass sunroof sold: '99 M3 Coupe Cosmos Black Airbox baffle removed, ZKW ellipsoid headlights, UUC short shift kit, BMW x-brace, debadged '96 Jeep Grand Cherokee Laredo V8 (Support Vehicle) |
The M just means Metric.
US sized bolts are also sized by shank or thread size. If you go to the hardware store and buy 1/4 bolts, the threaded portion will be 1/4 diameter. The head take a larger sized wrench. There are standards for head size to bolt size in US, but we have LOTS of different "standards". What you normally get at the hardware store is SAE Coarse thread. There is also SAE Fine thread. And AN (Army/Navy used in aircraft), and don't forget Whitworth on old Brit cars and bikes (the wrench sizes are even different), and ... To properly spec a bolt you should use diameter, thread pitch and standard. So you typically buy a 1/4" x 20 bolt at the hardware store, which means 20 runs per inch of thread. IIRC metric bolts used to be speced the same way, with a diameter and the thread spacing in mm. But the M defines a single thread pitch for each diameter.
Terry Carraway '95 Alpine M3 LTW '00 Dakar M Roadster '02 Topaz M3 Red/White SRF #4 (Chassis 561)
If a bolt is specified with only an Mx where x is the nominal diameter, the the thread pitch is the standard pitch. You can specify a non-standard pitch by adding the pitch to the nominal diameter: M12 = M12X1.75 M12x1.5 Even for metric fasteners, the head size is not necessarily dictated by the thread. There are standards but auto manufacturers love special fasteners. Ed |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
