E30 (1982 - 1993)
Old 06-01-2006, 06:25 PM
omw41's Avatar
omw41 omw41 is offline
Mein Auto: 1986 BMW 325 E
ABS Relay Location
I need help finding the ABS main relay. Bentley's says it's under the drivers kick panel. I removed the panel and could not find it; it's not in plain sight. I did see a large computer type control box there. Is that it? Do I have to remove that to get to the relay? This is a good example of where even Bentley's can generalize...and it took me a good 15 minutes of reading to even get, "located under driver's side kick panel." I also did a search here on the site, but all I came up with was more of the same. Thanks.
Old 06-01-2006, 07:15 PM
lordofthewaters's Avatar
lordofthewaters lordofthewaters is offline
Rather Large Member
Mein Auto: 88 325is 04&09 jetta TDi
The metal box is your ABS control unit. The relay is directly on top of the ABS control unit's housing, it's an aluminium cased relay. I had to use a flashlight to see mine.
Sarcasm is a body's natural defense against stupid.
When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's 3.95 per minute.
"My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson
Old age and treachery, will always overcome youth and skill.
Old 06-01-2006, 07:20 PM
omw41's Avatar
Thanks. Yeah...that's the aluminum looking case that sits on the aboveleft side of the steering post, right? I ordered mine from BAV and it's just a black plastic relay that looks similiar to a fuel pump relay or a main relay. Thanks for the help Lord, I'll get back under there tomorrow.
Old 06-01-2006, 09:28 PM
Rather Large Member
Yup that's the one. I just soldered in a new wire in mine (ala swiss, but I did that months ago ) cheap and easy fix.
Old 06-02-2006, 07:10 AM
omw41's Avatar
yeah...I thought about that...but I've never been very good with solder. I figured I'd try replacing the realy, I already did the sensor pads when I did a brake job...it's just a gamble to change the relay, but if it works, I can remove the black tape
Similar Threads
Location of ABS Relay in 318is saloon cianb E36 (1991 - 1999) 1 06-03-2007 09:02 AM
Know where the ABS relay is? eidelweiss E30 (1982 - 1993) 2 01-05-2006 06:38 AM
Starter Relay Location - 89 325i dave collin E30 (1982 - 1993) 0 08-11-2005 09:00 AM
Dolphins fend off Great White attack! Jon Shafer Off-Topic 16 12-02-2004 09:19 PM
