The X5 SAV Forum
Old 06-04-2006, 07:30 AM
web22tf4 web22tf4 is offline
Mein Auto: x5 bmw
replacing outer cv joint boot on the front of x5
I am replacing the outer boot on the front and have removed the output shaft out of the hub. I am now at the point were I need to remove a retaining clip in order to slid the cv joint off the shaft to slid on the boot, but I can't seem to find a way to get to the clip. The crack in the boot was detected quickly so there is no damage to the bearings (luckly). Anyone have any info.
Jeff
I got it fixed thanks for letting me post. Here is the info on how I got help
http://www.x5world.com/x5-e53-forum/...-front-x5.html
Old 08-01-2007, 11:16 AM
TexasBMW's Avatar
TexasBMW TexasBMW is offline
Mein Auto: 08 X54.8 04X54.4 00E46CiC
I need both of my CV boots replaced...dealer is quoting $762...
Old 08-02-2007, 02:11 PM
UTAHX5 UTAHX5 is offline
Mein Auto: X5
I looked up a 2002 with 4.4 and the clip is a pressure clip you have to hit it with a hammer to release it I use a dead blow hammer so I dont ruin the cv joint put the axle in a vise with the joint facing down and smack that succer hard it should pop off good luck
Old 06-16-2011, 06:53 PM
ledojaime ledojaime is offline
Mein Auto: 2003 X5 4.4i
Replacing outer cv joint boot of an X5 4.4i Left Side
Would you please post this link again. I have tried to find this information by copying & pasting your link and I am not able to connect to it. Thanks
Old 06-17-2011, 03:16 AM
phill20 phill20 is offline
Mein Auto: x5 E53
They changed there name from x5world to xoutpost for BMW legal reasons, anyway here is the link
http://www.xoutpost.com/articles/x5/...mw-x5-e53.html
Phil
2003 E53 4.6is
www.xdrivers.co.uk
Old 06-21-2011, 12:43 PM
Phil,
Thank you so much for your reply.
Jaime
Old 05-09-2016, 10:31 PM
Fixequip Fixequip is offline
Mein Auto: 2001 BMW X5 4.4I
I found this entry extremely well written, as I could follow the process mentally from today's work. My only question was the method of removing the outer CV joint, as both All-Data and MOD assumed that the retainer clip was accessible for release with a screwdriver. I was able to get the joint off without removing the control arms or bearing housing. I pushed the shaft out with a three-leg hub puller and supported the drive shaft with a wood block on the control arms. With the CV joint hanging down, I placed a bronze bloc on the edge of the CV joint spider, and gave it a few whacks with a pneumatic hammer gun. It popped right off for cleaning, re-packing, and boot replacement. Where there's a will, there's a way ---- with patience and experience.
Fixequip
Old 05-11-2016, 06:03 PM
upallnight upallnight is offline
Mein Auto: BMW, Lotus, Porsche
I just use a tool like this to [pop off the cv joint.
Similar Threads
E65 V12 debuts nate General BMW Questions 22 06-09-2016 01:44 AM
Front bumper in bad shape on underside - worth replacing? halsnook 3 Series & 4 Series 1 06-18-2003 12:21 PM
Looking for X5 Front Clear Corner!!! bmwx521 X5 E53 (1999 - 2006) 0 04-15-2003 01:17 PM
replacing front turn signal bulbs jordanLINY Do-It-Yourself H.Q. 6 03-02-2003 05:43 PM
Replacing front BMW hood logo PG 3 Series & 4 Series 8 06-05-2002 12:40 PM
