Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 06-13-2013, 07:33 PM
omarphi215 omarphi215 is offline
Mein Auto: 1991 525i Auto
What is this!!! Help!
Can someone tell me what this is dangling from the bottom of my car?
Old 06-13-2013, 07:43 PM
downhiller's Avatar
livin large
looks like a fuse. are any warning lights on?
Old 06-13-2013, 07:49 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
It's either a wheel speed sensor wire quick-disconnect, or a brake pad wear QD.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 06-13-2013, 07:56 PM
downhiller's Avatar
livin large
thought the pad sensors were driver side on the rear and pass side on front
Old 06-14-2013, 12:36 PM
woodenbmw woodenbmw is offline
Mein Auto: 1987 BMW 325
Re: What is this!!! Help!
I have wear sensors on all four corners. Take the wheel off and have a good look at what it used to connect to. If you have wires hanging from the calipers, then it's the pad sensor. If the wires hang from the back side of the rotor, wheel speed sensor.
1987 325e automatic sedan
Old 06-14-2013, 01:17 PM
BMWFatherFigure's Avatar
Old School
That covers it. 4 wheel pad sensors - never seen that.
Current:
Previous:
Old 06-14-2013, 01:30 PM
I don't know what the deal is, but that's what is there. Really through me through a loop when I opened the manual and compared what I was reading to what I was looking at. I dunno ....
Old 06-14-2013, 01:50 PM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 85' 335i
brake pad sensor wires. My 85' had the same thing but I cut all mine off, cause "ain't nobody got time for that!" lol. I also removed the little light bulb on the cluster for the brake lining light so it wouldn't light up.
1985 335i
Black on Black coupe 5spd
Tokico lowering springs, KYB struts and shocks, BavAuto strut bars, SPC adjustable camber plates, Ireland Engineering rear toe and camber kit, Sparco buckets, Rota Torque 16x7 fronts 17x9.5 rear, Hella headlamps with HID conversion, all red taillights, MSD coil,M30B35 swap, Mustang GT Injectors, Port/Polish
Old 06-14-2013, 02:49 PM
Aint nobody got time for that! Lmao!! My brake lights (!) light is on but my brake lining warning light is not. My speedometer jumps up and down but the sensor looks totally detached which makes me think my speedometer should be dead and not read mph at all
Old 06-15-2013, 05:31 AM
Newman271's Avatar
That Guy
Mein Auto: 85' 335i
Your speed sensor is in the differential. If your speedo is bouncing around.. most likely either corroded wires, bad connection behind cluster( this is why my speedo stopped working recently), or your speedo servo is worn out.
1985 335i
Old 06-15-2013, 09:19 AM
Old School
Getting back to the 'hanging down' question. It can only be one of two things. If the ABS light is not on then its a wear sensor. My daughter could fix this one. As for the other problems they have been covered too. Brake light? I thought there were ABS; Hand/Park/Emergency Brake on; Brake fluid level and wear sensor blown. Have I missed one? Would it have Brake Light globe blown warning?
Current:
Previous:
Old 06-15-2013, 09:35 AM
I'm pretty sure the op is refferring to the brake light up by the rear view mirror. I'm almost 98% sure that's his wear sensor quick disconnect hanging down.
Old 06-15-2013, 10:03 AM
Newman271's Avatar
That Guy
Mein Auto: 85' 335i
When I first start my car my brake light warning lamp lights up on the command center but as soon as I touch my brakes it'll go out. Now as I am driving every other light will come on randomally except brake light and oil lol. I just got used to it. Start it up.. hit the check button.. drive 5 min hit it again... 10 min later all the rest follow except the two.. hit the check one last time and keep hoonin' ha.
1985 335i
