E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
#26
![]() Shouldnt you be chasing genetic throwbacks? Or something?
#27
#28
I've got a helpful one on windows
none of mine worked when I got it remove the handle trim (slides towards back of car) remove lock button.roll down window manually. Unscrew armrests slowly remove door panel. now slowly peel back inside plastic and if its already torn someone else already jacked with your car. Watch for black mold here to. now wd-40 window lifting mechanism and roll window up. Wd-40 mechanism again. Roll window down. Repeat 5 times then try the switch. In the back the door switch has to be plugged in to complete the circuit. if no luck from switch then disassemble switch and scrape off corrosion with flat head screw driver. Wd-40 reassemble reinstall I saved my self $125 per assmebly plus $25 switch per window. That's $600!!!This is a good time to move around the snaps on the door panel and move some from the back or less used door to the driver side as to help it stick on better Last edited by CAGRacing; 04-06-2008 at 11:37 AM. |
#29
Another relatively easy fix is the electric antenna
if it does not extend/retract fully then undo the bolt outside the car holding down the antenna Pull apart antenna and wd-40 everything very well and work antenna back and forth until it will collapse and open under its own pressure now to the "collar" this needs to be wd-40 also and bend back the tabs jus barely enough to let the antenna drop down under its own weight reinstall |
#30
Loose E-brake fix
Remove e brake boot. Remove surrounding console (bolt under ashtray) there are 2 bolt that secure the e brake line. One for each side. release e brake and see how much the bolts move forward with slack now tighten bolt til there is a tiny amount of tension then back off til there's 1mm of slack. Reinstall everything. Then end If you cannot sufficiently tighten fromthis point the you need to life the rear of the car on jacks. Remove one lugnut from each side. Rotate rim until empty hole aligns with star opening behind hole. You will need to insert a screwdriver and twist til there is tension and the brake is partially engaged. Then back off quarter to half a turn all done The e brake should be fully engaged at 6 clicks and should not be lifted past 8 clicks mine went to 14 and some and I was able to cure mine with just the adjuster bolts under the boot Last edited by CAGRacing; 04-06-2008 at 10:59 AM. Reason: added reference |
#31
Radio Swap
I saw the thread, but the link wasn't available any longer. Any where else to look?
E30 Specifications:
Model, HP, 0-100 (Km/h), Topspeed (Km/h) 1983 318i - 102hp 11,2s 183km/h 320i - 125hp 10,4s 196km/h 323i - 139hp 9,2s 202km/h 1984 318i - 102hp 11,2s 184Km/h 320i - 125hp 10,4s 196km/h 323i - 139hp 9,2 202km/h 1985 318i - 105hp 11,2s 184km/h 320i - 125hp 10,4s 196km/h 323i - 143hp 9,1s 202km/h 1986 318i - 105hp 11,2s 184km/h 320i - 125hp 10,4s 196km/h 323i - 143hp 9,1s 202km/h Alpina B6 - 210hp 7,0s 230Km/h 1987 318i - 105hp 11,8s 184km/h 320i - 129hp 10,2s 195km/h 325i - 170hp 8,3s 215km/h 325iX - 170hp 9,2s 210km/h 325iC - 170hp 8,7s 214km/h M3 - 195 6,9s 230km/h 1988 318i - 105hp 12,1s 182km/h 318iS - 113hp 10,8s 188km/h 320i - 129hp 10,6s 197km/h 325i - 170hp 8,3s 218km/h 325iX - 170hp 9,2s 212km/h 325iC - 170hp 8,7s 216km/h M3 - 195hp 6,9s 230km/h 1989 316i - 100hp 12,1s 182km/h 318i - 113hp 10,8s 188km/h 320i - 129hp 10,6s 197km/h 320iC - 129hp 11,5s 195km/h 320iT - 129hp 11,5s 196km/h 325i - 170hp 8,3s 218km/h 325iX - 170hp 9,2s 212km/h 325iC - 170hp 8,7s 216km/h 325iT - 170hp 8,8s 214km/h 325iXT - 170hp 9,7s 208km/h M3 - 195hp 6,9s 230km/h Alpina B6 - 254hp 6,6s 246km/h 1990 316i - 100hp 12,1s 182km/h 318i - 113hp 10,8s 188km/h 318iT - 113hp 11,7s 188km/h 318is 16V - 136hp 9,9s 202km/h 320i - 129hp 10,6s 197km/h 320iC - 129hp 11,0s 195Km/h 320iT - 129hp 11,5s 196km/h 325i - 170hp 8,3s 218km/h 325iX - 170hp 9,2s 212km/h 325iC - 170hp 8,7s 216km/h 325iT - 170hp 8,8s 214km/h 325iXT - 170hp 9,7s 208km/h M3 - 215hp 6,7s 241km/h M3 SE - 254hp 6,7s 248km/h 1991 318iT - 113hp 11,7s 188km/h 318is 16V - 136hp 9,9s 202km/h 320iT - 129hp 11,5s 196km/h 320iC - 129hp 11,5s 195km/h 325iT - 170hp 8,8s 214km/h 325iC - 170hp 8,7s 216km/h 1992 316iT - 100hp 13,9s 179km/h 318iT - 113hp 11,7s 188km/h 318iC - 113hp 12,0s 187km/h 1993 316iT - 100hp 13,9s 179km/h 318iC - 113hp 12,0s 187km/h Hope thats readable =) Last edited by Gurra; 04-16-2008 at 12:49 PM. |
#33
how about a walk trough on oil pan replacement?
#34
Maybe how to get the shift knob off in the first place?
#35
Pull on it directly up.
Seriously. |
#36
hmmm... service light reset?
I know there was a DIY writeup around here somewhere. Edit: found it: http://www.unofficialbmw.com/repair_faqs/sil.html#reset Last edited by Qbrozen; 07-17-2008 at 05:45 AM. |
#37
Good thread. I hate to admit that a few years ago when I was sorta green on vacuum leaks, I was looking all over for one with no luck. Later a fellow came by to buy something I had on Craigslist, he was there before me and he heard my engine on the way up. Turns out he and his dad are E-30 o'philes, we got to talking and he said "why-oncha pop that hood and start it up again." I got out the carb cleaner and it was the biggest possible source of vacuum leak -- the intake manifold gasket!
Oopsie. Idles just fine now.
cmac As I know more of mankind I expect less of them, and am ready now to call a man a good man upon easier terms than I was formerly. - Samuel Johnson |
#38
remove radiator, loosen motor mounts, buy 10mm ratcheting wrench with flex head, spend 1.5-2 hours taking out tons of 10mm bolts. If you have an auto there is a plate to remove on the trans bellhousing to get the last few bolts. those are T7 torx bolts but a 7 or 8mm socket will get them off. Reinstallation is reverse of removal.
ahhhhhhh hahahahahahahahah.
eh hem... hahaha.
2000 Z3M-Current 2001 Z3 3.0i Roady-Sold 1986 325eS M50-Sold 1988 325i-Sold |
#40
Leaks in the vaccum lines under the intake are very common. Mine were just plain falling apart. Also the vaccum hose from the valve cover is prone to cracks from old age and valve adjustments. Hope this helps.
#41
Link for timing belt replacement does not work. Anybody have instuctions?
#42
Also, a Bently manual is invaluable and pretty cheap nowadays. |
#43
Thanks for the help
#44
I've got an '83 UK 323i here in the states. The 6 cylinder.
Where can I find information on the fuel pump, fuel relay, or fuel injection system for that model? Or do you know how to troubleshoot those so I can figure out how to get it running again? |
#45
E30 DIY Links
Everything from dashboard swaps to timing belt replacement
![]() A big THANK YOU to the folks who documented the processes and procedures necessary to keep our E30's on the road and looking good Pelican Parts Technical Articles Bimmer DIY E30 BMW DIY BMW Tech Tips Please add links and grow this thread into a comprehensive E30 DIY source
WTB: Minty Seat Belt Receptacles - Front |
#46
I just paid to have mine done, but here is a good link on rear subframe bushings.
http://www.unofficialbmw.com/repair_faqs/subframe.html Even tells you how to make a homemade tool for the job. |
#47
Here's another.
http://e30world.com/ |
#48
#49
http://www.e30clubsa.co.za/forum/ind...showtopic=4594
Here's one to remove your cluster. I'll probably do this sometime in the very near future.
#50
So my cars got some miles on her around about 500k
but hey shes still stock and ran great til i hopped in and she didnt want to idle and after i revved her up to 3 grand she cleared up now its a constant miss Anyways heres a few things going on.......in 5th gear at 2500 rpms i can let out of it and see the economy gage go near 40mpg and it sounds like shes cuttin out I dunno the only thing i can figure is a vacuum leak to happen in one night
| Bookmarks |
| Tags |
| bmw diy, bmw do it yourself, e30 diy, e30 do it yourself, m50 e30 |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| The official "alee sucks thread" sucks thread | nate | Off-Topic | 22 | 06-03-2004 03:37 PM |
| Official Count @ Bimmerfest? | manik///m3 | General BMW | 3 | 04-22-2002 02:23 PM |
| official party hotel for bimmerfest ???? | jAb | General BMW | 5 | 04-18-2002 04:26 PM |
| It's official, Bimmerfest is no longer utopia | Spiderm0n | Off-Topic | 32 | 04-17-2002 06:06 PM |
