Car Audio & Electronics Forum
Hi-Fi upgrades, XM Radio, Sirius, Bluetooth, and Radar Detector discussions here! |
#2476
Tom G. | european auto source (eas) email: tom@europeanautosource.com web: www.europeanautosource.com tel 866.669.0705 | ca: 714.369.8524 x22 | fax: 714.908.1796 Blog | Facebook | YouTube | Flickr | Twitter |
#2477
Hi there !
Thank you for your time ! I tried with an Iphone and the quality was definitely a lot better ! I reduced the dice base volume to minimum and it was even better ! But still at very high level I can here some interferences... Anyway to completely remove those ? Do you still want me to check the 10pin plug ? Thanks again. |
#2478
#2479
Hi,
So i checked the 10 pin plug and first I didnt find any green dot and second there is no way to plug it in a wrong way as there is a a plastic thing that can be plugged only in one way... So I'm still far from CD quality !!! Thank you. Edit: All sound check and EQ are off... |
#2480
Bump !
Now i figured out that every time I unplug the dice and plug it back, I get decent quality. But when I shut down the radio and the car and turn them back on, the quality is very bad so I have to unplug the dice then plug it back again to have something decent... Any idea ?? Thanks. |
#2481
DICE can be contacted by phone or email at: http://diceelectronics.com/product-support
Tom G. | european auto source (eas) email: tom@europeanautosource.com web: www.europeanautosource.com tel 866.669.0705 | ca: 714.369.8524 x22 | fax: 714.908.1796 Blog | Facebook | YouTube | Flickr | Twitter Last edited by tom @ eas; 02-09-2011 at 10:59 AM. |
#2482
The link isn't working...
#2483
I've been having a problem with mine for a while now. I had it in my E46 and now it is in my E39. It did this in both cars. When I hit a bump in the road or make a sharp turn or the cable that is plugged into the iPod gets "nudged", it will make a horrible ticking sound and the audio will decrease tremendously. If I move the iPod with my hand, it will go back to normal until I hit another bump, etc. It seems like the cable is worn out where it plugs into the iPod. Does anyone sell just the cable from the iPod to the dice other than spec.dock?
#2484
#2485
I have an 01 e38 with DSP and just updated to the bm53 radio with a 3/2005 production date. I assumed that I hooked up my silverline Dice module correctly, as I see it on the dash, but don't get any sound. How exactly do I hook up the wires on the back of the new bm53 radio? I currently have one of the AUX connectors empty, and hooked the other side up as previously attached with the cables I bought through Bimmernav.
Thanks for any help, as I love the new radio but miss the dice connection! HELP?!?! Sent from my iPhone using BimmerApp |
#2486
Do you have a radio or trunk interface kit?
#2487
Hello,
I have the trunk Interface. It's hooked up exactly as described in the install book. The only difference is now the bm53 radio upgrade. Wirh those radios, it seems like I DON'T need the DSP box?? Confused a little, and am a little baffled that nothing comes up on a search, as I can't be the only one who did this upgrade. Bimmernav suggested talking to you guys...... Sent from my iPhone using BimmerApp |
#2488
"DSP interface" I know I need the DSP amp....
#2489
If you have the 3/6 pin connectors connected on the DICE harness and no audio, you will need the DSP adapter.
#2490
I guess I wasn't that clear.
I previously had the Dice installed with the DSP adapter on the original bm43 radio. I simply took my old connections and with the adapter harnesses from Bimmernav, installed the bm53 radio. I plan on updating to the Sirius module soon, but am asking how to hook up the AUX wiring on the back of the radio. Also, I see the Dice module under CD using the Mode button. I do NOT see an AUX Mode. Did I not hook up something correctly and that's why I have no volume through the Dice adapter? ![]() ![]() Sent from my iPhone using BimmerApp |
#2491
#2492
I can't hear anything other than interference like a whine from the Alternator. It increases with speed. I have looked at your site as well, and can't find any wiring diagrams as to what pins are for AUX out on the radio.
#2493
If you were using the DSP adapter before, the new BM53 radio may have changed the DSP to analog instead of Digital. Use the 3/6 pin connectors for the CD Changer instead and remove the DSP adapter from the vehicle to hear if audio is present. If you do not have a 6-pin adapter, you will need to purchase one here: http://www.europeanautosource.com/pr...roducts_id=381 Luckily since you have SatNav - the radio module is in the trunk, eliminating the need from running from the cabin area to the trunk.
Tom G. | european auto source (eas) email: tom@europeanautosource.com web: www.europeanautosource.com tel 866.669.0705 | ca: 714.369.8524 x22 | fax: 714.908.1796 Blog | Facebook | YouTube | Flickr | Twitter Last edited by tom @ eas; 03-04-2011 at 12:12 PM. |
#2494
some help.
Hello.
I have installed Silverline Duo, non DSP version and wanted to ask some howto questions. 1. How to show text on MID instead of instrument cluster? 2. Is it possible to show menu button names instead of digits 1..6 on MID? 3. Browsing / changing songs / albums / playlist takes about 1,5 seconds. is this normal? any tweaks to speed it up? |
#2495
DICE can be contacted by phone at 888-342-3999 or via email at http://diceelectronics.com/product-support
#2496
I have a Dice unit that has been in my 2003 540 for the last 5 or 6 years. It sounds good but the only complaint I have is that when I use the Dice and I turn off the car and don't use it for a long time(like when returning to the car at the end of the day) when I get back to the car and start using the Dice again, it starts playing the very first song; not where I stopped. So, if I have 100 songs in it, I never get to listen the songs at the end of the list. If I turn off the car and get back to it in a short time, the music starts where I left it at.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Want to replace BMW iPod kit with Ice>Link | Ernö | Car Audio & Electronics Forum | 21 | 04-03-2009 09:41 AM |
| The Official when are you going to Munich thread! | e36M3r | European Delivery | 1648 | 03-27-2009 06:53 PM |
| Another Ipod Thread | bmw4ever | E90/E91/E92/E93 (2006 - 2013) | 2 | 11-07-2005 08:58 AM |
| iPod in X3 (BMW Business CD) | simoncpw | Car Audio & Electronics Forum | 6 | 07-05-2005 03:06 PM |
| 2005 EuroPacific Summer Showoff - Floyd Bennett Field - OFFICIAL THREAD | RRRize | NY / NJ / CT | 7 | 05-15-2005 05:31 AM |
