Old 06-13-2006, 04:25 PM
mclaren's Avatar
mclaren mclaren is offline
Chairman of the Bored
Mein Auto: 2014 M5
Talking Anyone tried the Brake Caliper Paint Kit ?
I like the way Porsche does it, if I used red they would look like ceramic !
Anyhow, I think it would be neat with the Z4 sport package wheels.
I wonder who makes those wheels ?
Old 06-13-2006, 05:16 PM
Johnz3mc Johnz3mc is offline
C code: 405/3
Mein Auto: 99 Z3 M Coupe
I used Red Spray kit
Like the subject line says, the red spray kit worked really well.
I removed the wheel, then cleaned the beejeebers out of the calipers. I masked everything in sight, including the neighbour's car just in case spray travelled across the road.
5 or 6 coats of paint (it dried quickly) followed by many coats of clearcoat made the job perfect.
They've been painted for over a year now and still look great.
I clean with a sash brush and found a couple of benefits: it gets into all the little nooks and crannies of the wheel and gets through to the caliper also.
Would I do it again? Sure.
-John C.
Old 06-13-2006, 06:03 PM
MysticBlue MysticBlue is offline
They call 'em rigs here
Mein Auto: '09 E92.
I got mine from the TireRack. It's been 2 years and I'm still happy with it. With the kit, after you mix it, you only have about an hour before it hardens, so you have to have everything ready... car up on blocks, all four wheels off, calipers cleaned really well. I didn't remove the calipers, just hand painted them carefully with a small brush.
09 E92, IB, DCT.
Old 06-13-2006, 06:28 PM
Excitmnt94's Avatar
Excitmnt94 Excitmnt94 is offline
Send a message via AIM to Excitmnt94 Send a message via Yahoo to Excitmnt94
Mein Auto: '09 135i coupe
black are standard on some porsche vehicles...
red are on porsche higher performance cars...
and finally yellow is ceramic/composit
i have been toying with the idea of painting the Z's calipers...but i might just leave them stock...who knows
135i coupe - Alpine White // Glacier Silver Aluminum Trim // Heated Coral Red Leather Seats // M-Sport Package // I-pod // PDC // 6-Speed Manual //
Old 06-13-2006, 06:34 PM
conorb's Avatar
conorb conorb is offline
Mein Auto: 96 328is; 06 M Coupe
-John C.
Any pics of the results?
Thanks for the tips.
conorb
Old 06-13-2006, 07:45 PM
mclaren's Avatar
Mein Auto: 2014 M5
You are correct, yellow is ceramic on Porsche.
Old 06-13-2006, 10:51 PM
bimmerZ5 bimmerZ5 is offline
Mein Auto: Z3 3.0i Rdstr, E39 530i
i used VHT brake caliper spray paint. you have to cure it in the oven at 250F for 30min. after it is cured, it becomes solvent/chemical resistant and nice and glossy.
1. removed the calipers
2. cleaned like mad (brake cleaner, steam cleaner, dremel w/ stainless steel brush)
3. masked the piston and screw threads
4. hung them via coat hanger wires, sprayed 2-3 coats
5. cured in oven
6. install them with brass bushings, stainless steel lines, and chromed springs
pictures can be found at:
http://www.sandiegoz.com/forum_cgi/g...brake_calipers
Old 06-14-2006, 03:02 AM
C code: 405/3
conorb
I'll try a few pics over the next few days,
-John C.
Old 06-14-2006, 03:56 AM
SledgeHammer SledgeHammer is offline
Mein Auto: BMW Z3
Painted mine silver. It all depends on what color your car is.
Old 06-14-2006, 10:03 AM
TR6's Avatar
TR6 TR6 is offline
Mein Auto: 1999 M coupe
I removed the wheel, then cleaned the beejeebers out of the calipers. They've been painted for over a year now and still look great.
-John C.
Just to confirm... You can do all of this without removing the calipers??? That has been the main reason I haven't wanted to try it... I didn't want to mess with removing the calipers and rebleeding everything.
Greg H
1999 M Coupe (daily driver)
2002 Spec Miata race car
1993 Porsche 911 RS America
1976 Triumph TR6
2001 Ford F250 crew cab 4x4 diesel (track support/tow vehicle)
Old 06-14-2006, 11:50 AM
Not confirming the message you responded to, but in general, yes, you can do this without taking the calipers off. But to be honest, I don't think that would result in a professional looking job. That is a personal opinion of course.
If you decide to do this without removing the calipers, I would recommend using a non-spray paint kit. No matter how well you mask off the wheel well, it may only take one gust of wind to carry the spray paint to other body panels of your car. I would only do the spray kits if you remove the calipers and do the painting in an isolated area away from anything you don't want to get painted.
Removing the calipers and bleeding the brakes is not hard. The hardest part is cleaning the calipers correctly or risk painting over crusty brake dust and other contamination.
Old 06-14-2006, 01:21 PM
wernst wernst is offline
Mein Auto: 2000 Z3 2.8
Though I like the look of painted calipers, I still have a hard time believing that hot painted brake calipers cool off as fast as bare-metal calipers. I mean, I wouldn't paint any heat-sink with a thick paint, and your calipers are basically heat-sinks when you're driving hard (the Dragon, Autocross, Track-day, etc.)
Yes, I see lots of factory-painted calipers from Porche and other factories, but I sort of assume that they were designed to shed heat with the paint already on them. Were factory-bare calipers designed to shed heat when covered in paint? I dunno.
If someone has some technical evidence either way on this, I'd love to see it. I actually have a set of blue caliper paint in the garage, now 4 years old, that I would love to use...
-Warr
Old 06-14-2006, 05:56 PM
C code: 405/3
Greg,
I didn't take the calipers off but I did remove the wheels/tires and clips. Masking everything in sight took a while but the process worked well. The spray paint dried quickly so I was able to recoat fairly quickly.
The clearcoat spray I used also dried quickly so multiple coats happened fast.
I'm waiting for a sunny day for pictures but the multiday forcast looks gloomy.
Do you have sun in your area? Can I come live in your garage? Do you have beer in your fridge? I still like your TR6.
Enough questions, go and paint your calipers.
-John C.
Old 06-14-2006, 06:11 PM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
Jeff R.
Old 06-14-2006, 06:24 PM
jvr826's Avatar
Is it Trackday yet?
5. cured in oven
You sir do very nice work! I like the finish of the paint, and I like the black color as well. I'm going to do the same to my E46.
Where did you get the chrome anti-rattle springs? Very nice touch!
How many cans of paint did you use? Which VHT product did you buy?
Jeff R.
Old 06-14-2006, 07:22 PM
Thanks! Be happy to help you out if you need; just contact me whenever.
The chrome anti-rattle springs i bought from someone who got them chromed. You can buy new springs for $6/ea (so that they are clean) and get them chromed for $3-$5 a piece.
I bought 2 cans of VHT brake caliper paint in "gloss black". However, I didn't even finish the 1st can. I'll probably use the 2nd can on my E39.
With VHT caliper paint, you have to bake them at 200F for 30min to cure the paint. After that, it becomes solvent & chemical resistant. That way you don't have to worry about dripping brake fluid on it or anything. The cheapest place to buy VHT brake paint I found was Autozone.
Old 06-14-2006, 07:39 PM
jvr826's Avatar
Is it Trackday yet?
Thanks for the follow-up and Autozone recommendation. Next time I swap pads for HPDE I'll paint the calipers.
And if I have some motorcycle parts at the chromer, well, maybe I'll throw those springs in the pile too.
Jeff R.
Old 06-16-2006, 03:36 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
I used VHT in yellow on our Roadster. I have a couple of the kits that Leather Z sells, but haven't used them yet.
I didn't oven cure the VHT. I just drove the car hard enough to heat up the calipers. As long as I clean them, they look great 3 years later.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 01-07-2012, 07:55 PM
turbo10325 turbo10325 is offline
Mein Auto: Z3M
Just did mine today. THe Pagid brake pads I recently put on were red. And I warmed up to the look. So painted the calipers red today. Didn't use a kit, just some red caliper paint that was rated high on amazon. Didn't do a complete disassemble, pulled the wheels, and the caliper (as if doing a brake job). Pulled the brake pads off, then remounted the caliper. That gave me enough room to properly mask the rotor and other components.
Old 01-08-2012, 01:18 PM
tohbi tohbi is offline
Mein Auto: z3 '97 atlanta blue 2.8
don't need to bake nuthin' in arizona. in summer we fry our eggs on the sidewalk.
i agree with sledgehammer, it depends on your car color. the green car looks good with red calipers. i'm considering orange for my blue car. just try to match the color values.
Old 01-12-2012, 06:01 PM
dominoaz dominoaz is offline
Mein Auto: 07 Z4, 77 Porsche, 11 528
Space Gray '07 Z4 w/ Roundel Blue Calipers
I have been spraying my calipers for many years. Always use high heat engine paint. I found that Ford engine blue is a near perfect match to the blue in the BMW Roundel. One six buck can will easily do 4 coats. No mixing, no primer, no curing, very glossy finish, withstands wheel cleaner and high pressure car wash blasters. Have never experienced chipping or peeling. I'll send a pic when I clean my car.
Similar Threads
UUC Big Brake Kit by SSBC Super Special Deal Bob@BPS Site Sponsors & Bimmerfest Group Buys 1 12-07-2005 06:57 PM
If you buy the body kit, make sure the paint matches! Desertnate General Automotive Forum 4 04-18-2005 12:32 PM
CMA Newsletter 17 (Great read on German Paint) GSR13 The Detail Department 21 12-04-2003 09:12 PM
Paint damage - brake fluid? MR325iT 3 Series & 4 Series 6 10-29-2003 02:33 PM
