[eas] *** DIY TUTORIAL - DICE iPod integration kit in e46 Coupe *** - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Car Navigation, Audio & Electronics by BAVSOUND
BMW navigation, audio upgrades, XM Radio, Sirius, Bluetooth, and Radar Detector discussions here!
Sponsored by BAVSOUND
Old 06-13-2006, 11:54 PM
tom @ eas's Avatar
tom @ eas tom @ eas is offline
european auto source
Mein Auto: BMW
In this DIY, we are going to install a DICE iPod integration kit into a 2005 330Ci with Business CD and rear fold down seats. The vehicle was ordered without a CD Changer.
First, the DICE iPod kit comes with 3 major pieces:
- 4m Trunk interface cable
- DICE iPod integration module
- iPod Dock connector cable
We are going to focus more on the install aspects rather than operation to keep the post length to a minimum. This is a typical glovebox installation, which allows a clean stealth install with no drilling any damage to the vehicle.
Items needed:
DICE iPod Integration Kit for BMW
http://www.europeanautosource.com/pr...roducts_id=268
- Phillips screwdriver
- trim removal tool or similiar device
Let's begin!
1. The needed connections will be in the trunk/boot area.
2. The driver's side rear taillight house will need to be removed. This will unclip or unscrew depending on your specific model year.
3. Access the fuse panel in the glovebox by turning the nylong retaining clips inward 90 degrees until the panel drops down. Remove fuses #7 & #41 to cut power to the radio/navigation tuner. e46 radios will not need a radio code when connected.
4. Remove inner taillight housing and taillight plug.
5. Image of taillight with housing removed.
6. Remove expansion rivet with a trim removal tool or similiar device. There are (2) rivets that will need to be removed to gain access to the wiring.
7. Location of 2nd expansion rivet, this will need to be removed.
8. Move trunk lining out of the way.
9. Locate CD Changer wiring harness. This will be located behind the factory amplifer touching the inner wall of the fender. This will have the needed 3-pin and 6-pin connectors.
10. CD Changer wiring located, wrapped in cloth sheath.
tom @ eas's Avatar
Mein Auto: BMW
[eas] *** DIY TUTORIAL - DICE iPod integration kit in e46 Coupe *** (cont.)
11. Unwrap cloth sheath to expose needed 3-pin and 6-pin CD Changer connectors.
12. Connect 6-pin connector to DICE harness, this is keyed to only go in one direction.
13. Connect remaining 3-pin connector, verify connections are snug. Also note that the connector on the left side (BMW side) has the brown wire in the #1 position on the outside. This verifies this is the correct connector as there may be multiple 3-pin connectors in the vehicle.
14. Unravel trunk cable, and prepare to run to cabin area.
15. Fold down rear seats (if equipped) and run trunk interface cable underneath trunk liner towards back seat area.
16. Cable entering cabin area, next to driver's side rear seat hinge. Position cable towards bottom corner next to the bolster.
17. Remove bottom portion of seat by lifting on bottom cushion and push aside. Seat does not need to be removed from vehicle, but it may simplify the job.
18. Pull slightly on rear seat bolster and tuck the trunk harness cable away from view.
19. Angle with seat bolster pulled back with wiring tucked in.
20. Push seat bolster back into position to conceal wiring.
Old 06-13-2006, 11:55 PM
tom @ eas's Avatar
Mein Auto: BMW
21. Prepare to route wiring underneath rear seat to passenger side of vehicle.
22. Cable being routed to passenger side, clearing seatbelts.
23. Trunk harness on passenger side, preparing to place bottom seat cushion back into place.
24. Seat cushion reinstalled with trunk cable completely hidden.
25. With a trim removal tool or similiar device, pop nylon retaining clip from door sill.
26. Route trunk cable underneath the retaining clip and pop back into place.
27. Trunk cable in place, preparing to route underneath door sill to glovebox.
28. Tuck trunk interface wire underneath door sill by tucking it underneath with your fingers. Don't remove the sill as the retaining clips are very delicate, especially with older models. You will feel a small channel wher the wire can be pushed into. Repeat tucking the cable until you reach the passenger side kickpanel.
29. Trunk harness at passenger side kickpanel, ready to route to glovebox. Note plenty of slack left in harness.
30. Alternate shot of harness at kick panel.
tom @ eas's Avatar
Mein Auto: BMW
31. Time to remove the glovebox, remove bottom phillips screw.
32. Open glovebox to prepare for removal.
33. With your trim removal tool or similar device, remove the plastic pin holding the glovebox dampener strut on left side.
34. Repeat process on right side of glovebox.
35. Remove glovebox door retaining hinges. There are (2) screws.
36. Repeat process on left side.
37. Remove glovebox door and place in a safe area.
38. Remove remaining screws. Staring with step #31, there are a total of (10) screws holding the glovebox door and plastics on. Note that the screws in steps #34 & #35 are shorter than the other screws, these should be set aside.
39. Last screw for removal (#10)
40. Remove glovebox frame and set on floor of vehicle.
Old 06-13-2006, 11:56 PM
tom @ eas's Avatar
Mein Auto: BMW
41. Route trunk harness up kickpanel to very top.
42. There is a pre existing hole in the glovebox, the iPod cable is a perfect canidate for this position. Route the iPod cable through the inside of the glovebox frame and prepare for connection to the DICE module.
43. Connect trunk interface module and iPod Dock connector cable to DICE module. Verify DIP switches are set to the "OFF" position. If you would like to utilize the AUX connection on the module, this would be a great time to connect your interface cable (available seperately).
We also have these on the site:
eas 3.5mm male/female AUX extension cord
http://www.europeanautosource.com/pr...roducts_id=312
44. Connect dock connector to ipod and you're complete!
45. Activate text as outlined in the user's manual
Installation is now complete!
Note: Your iPod must be updated to the minimum firmware requirements in order to be compatible with the DICE
iPod kit.
Supported iPods and Firmwares
IPOD
- 3G: Must have minimum firmware version 2.3. Does not support Albums/Chapters. FF/RW Does not work from radio
- 4G: Must have minimum firmware version 3.1.1
- 4G Photo/Color: Must have minimum firmware version 1.2.1
- 5G Video: Must have minimum firmware version 1.1.1
- nano: Must have minimum firmware version 1.1.1
- mini: Must have minimum firmware version 1.4.1
Updated iPod firmware can be found at Apple's website: http://www.apple.com/ipod/download/
Helpful resources:
DICE owner's manual: http://support.diceelectronics.com/f...al_rev_B01.pdf
Have fun!
Old 06-14-2006, 05:31 AM
Hercules's Avatar
Hercules Hercules is offline
Nick Burns, the Comp Guy
Mein Auto: 2003 Audi A4 3.0
Great DIY!
Recently Played Tracks:
Old 07-04-2006, 04:50 PM
tom @ eas's Avatar
Mein Auto: BMW
[TUTORIAL] - DICE iPod integration kit in e46 Convertible
http://www.europeanautosource.com/su...&root=22&id=39
This will show in detail how to get the DICE integrated into an M3 Cab using the eurotray.
Old 07-05-2006, 12:22 AM
tom @ eas's Avatar
Mein Auto: BMW
[TUTORIAL] - DICE iPod integration kit in e46 Coupe (eurotray or sunglass holder)
http://www.europeanautosource.com/su...&kb_rating=yes
Old 01-14-2007, 05:33 AM
Bandit6d Bandit6d is offline
Mein Auto: E46 M3 Convertible
Tom et al, on the E46 M3 convertible, if you route your DICE cable on the right side of the vehicle you will more then likley end up with some level of alternator whine since that is the side where the battery cable to the engine is routed. I installed on that side, had a loud whine, chaning it to the left side, middle console eliminated the whine completely.
Additionally, you do not have to tear apart your glove box for this install, as you can remove the three top screws, two screws left and right of the glove box (where the strap is and the piston are - if you look straight in you will see their heads. Then one screw underneath on the righ hand side. If you take these out your entire glove box will drop out by pulling out towards the seat and down. It takes about 5 minutes to completely remove it.
Old 01-15-2007, 10:40 AM
tom @ eas's Avatar
Mein Auto: BMW
Thanks for the feedback!
We have not seen engine noise on a vert yet - even with the cable routed on the right side. You are correct on the glovebox issue, we have found this method to be easier in our installs.
Old 01-25-2007, 03:38 AM
upier upier is offline
Mein Auto: 2004 BMW 330Ci
Do you have pics of how you remove the glove box whole? Where behind the glove box do you mount the module?
Old 01-25-2007, 09:17 AM
tom @ eas's Avatar
Mein Auto: BMW
Simply tuck the module behind the glovebox, we have tutorials at this link:
http://www.europeanautosource.com/su...nter/index.php
Old 02-10-2007, 10:04 AM
cpk cpk is offline
Mein Auto: 2003 325i
No folding seats?
How about those of us withough folding seats? Suggestions?
Old 02-11-2007, 06:09 PM
tom @ eas's Avatar
Mein Auto: BMW
Tutorial for non-folding seats can be found here: http://www.europeanautosource.com/su...mod_id=2&id=40
Old 02-20-2007, 05:30 PM
330testyle 330testyle is offline
Mein Auto: 2001 330CI
Great DIY
This DIY is very well done
I have a few questions about the DICE product.
Will it work with the radio in a 2001 330CI?
Can a Sirius satelite radio be pluged into the aux input?
I currently have a CD player with a soundgate adapter. Will it replace this?
What does it cost and where can i get it?
Old 02-20-2007, 05:47 PM
tom @ eas's Avatar
Mein Auto: BMW
This will work with the 330Ci, a portable Sirius/XM unit can be plugged into the AUX port also. This will eplace your current CD Changer, but leave the in-dash unit intact.
We have the kits here on the site:
These are in stock and ready to ship!
Old 06-12-2007, 06:42 PM
jimmelo jimmelo is offline
Mein Auto: 2011 335d
Alternative DIY choice Head Unit Not CD changer in trunk
Hey y'all I decided NOT to go through the trunk and I think this install is much easier! I posted the full DIY here. Install is at the head unit NOT the CD changer.
http://www.bimmerfest.com/forums/sho...151359&page=39
Old 08-16-2007, 01:00 PM
2001 BMW 300ci 2001 BMW 300ci is offline
Paid in Full!
Mein Auto: 2001 330ci
Thumbs up Dice trunk installation
I had to disconnect my 6 disk changer & remove it to get to the wire harness. Thank you for the detailed info it helped tremendously!!!
Old 03-12-2009, 04:16 PM
Iizé Iizé is offline
Mein Auto: //2005 e46 330i ZHP//
Help on some cables
Hi,
Can someone tell me what are those cables? I found that in my trunk. (2005 330i e46 zhp with navigation). What DICE Kit is best for me?
Old 03-12-2009, 04:30 PM
tom @ eas's Avatar
Mein Auto: BMW
Originally Posted by Iizé View Post
Hi,
Those are the telephone cables, the CD Changer cables will be located behind the factory amp.
Old 03-29-2015, 05:48 AM
tdh13 tdh13 is offline
Mein Auto: E46 325i
Hi everyone. I think I've just ruined my kit and just want to be sure of it and what to do next.
1) I didn't disconnect the battery. How serious is that?
2) I've connected 3-pin connector for phone firstly. The one I'm not supposed to but it was too late. How can I be sure that I've damaged my kit permanently? Is wiring ok? If I only change the head unit will it work because all the wiring is done?
Similar Threads
My E36 v. E46 thoughts (very long) JST 1M & M2 49 12-18-2006 11:45 AM
Can anyone verify if these Bluetooth Retrofit Kit Part numbers are available? m3evolution General BMW Questions 25 06-22-2005 08:21 PM
FS: ACS Body Kit for Tit Slvr E46 Coupe iczer34 Classifieds 1 06-10-2004 10:31 AM
I look pics of black bmw e46 coupe with kit MII!!! shelacoste 3 Series & 4 Series 17 11-20-2002 08:17 AM
For Sale: E46 Coupe and Sedan Carbon Fiber Trim Kits vinnymac Classifieds 0 07-19-2002 01:58 PM
