#51
The inability to LOCK the car is one of the first indicators that the key's battery is failing...see the instruction for the old style key below...and take note of the 3 major things that can occur when the key's battery is dying. You don't have to have all 3 symptoms...you can have 1 or any combination:
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) Last edited by QSilver7; 01-24-2010 at 01:26 PM. |
#52
seems like there is a bunch of us where the fuel cap door does lock when we manually lock the car.. (me being one of them)
- I checked my fuses and they all look fine - I tried re-programming the keys and still doesnt work.. I might take it to a dealer and see what they say..
03 525i - e60 M5 18" wheels | M5 front grill | HIDS | Front Strut | Koni adjustables with Eibach springs Modified stock intake / CF Heat Shield | AUX IN | Focal coax | Focal power sub | Tinted Windows |
#53
chiefwej 2003 540i ///m-tech 6-speed Black Sapphire Metallic w/gray
#54
by manually i'm talking about sticking the key into the door to lock it
#55
Yes - Manually - Putting the key in the door and locking it.
So I have a done the intialization procedures for both types of keys.. old and new. I will replace the battery and try again. I just didnt think the battery was the issue since I can unlock the car from a long way away. But cant hurt to change it.
1999 540i/6 Titanium Silver w/Black interiour Winter Package Sports Package K40 hidden radar detector 235/45ZR-17 General Exclaim UHP 255/40ZR-17 General Exclaim UHP 225/55R16 Bridgestone Blizzak WS-60 - Winter Tires and Rims Redline Fluids - Diff and Tranny Axxis Deluxe Advanced brake pads |
#56
And what type of key do you have? Do you have the 3 button RF (radio frequency) key? Or do you have the 2 button IR (infrared) key? If you have the IR key...you've been following the wrong instructions...there's a slightly different procedure for the IR key...see the image below: These are instructions for those e39 owners who may live in a market where BMW uses the IR system and the key only has TWO buttons on it: ![]()
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) |
#57
Just finished replacing the battery in one of my keys and it works like a dream!!! I used a slightly different and easier technique than the other DIYs in order to get perfect battery contact and security.
Now I just have to do the other key Now to figure out what the heck is wrong with my trunk (the trunk button on the key doesn't do anything either )
#58
Ditto - I replaced my battery and I can now lock my car via the remote! Why I could unlock my car from 1000 feet away still amazes me that the battery would cause an issue locking it.
#59
Thank you guys. Sure enough, this forum just saved me a trip to the dealership, a tank of gas and probably an hour worth of labor @$88/hour.
Fuse #53 was the culprit for my remote not to work, and upon reading the manual there was a spare #53 in the glove box. Replaced it, program the remote and Voila!! Thanks a bunch you guys!! |
#60
I have a 2003 540i sport with the new style key.
I have two keys and both do the same thing. The unlock/lock on both keys do not work. However, the trunk open works on both remotes. I am assuming, based upon the fact that the trunk opens, that the batteries in both remotes are still good. After manually locking the car, sticking the key in the door and turning to the right, the gas cap door does lock. I checked through all the fuses and none appear to be burned. Ideas? Should I start by replacing all central locking system fuses? |
#61
And if the fuel filler door does NOT lock...when you wrote you checked ALL the fuses...does that include the fuses in the trunk? Especially the one that is for the CENTRAL LOCKING SYSTEM.
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) Last edited by QSilver7; 07-14-2010 at 07:17 PM. |
#62
I checked all the fuses both in the trunk and glove box. Ideas? |
#63
I went ahead and replaced all the central locking system fuses and the same problem exists.
I can pop the trunk with the remote but the unlock/lock does not work. Anyone else have any ideas? Also the lock/unlock button inside the car no longer works. Last edited by FusionZ06; 07-15-2010 at 06:32 PM. |
#64
fuse 53
I had been stuck for a while trying the reset to no avail. But then I dug deeper, saw this thread and it was the fuse 53 in the trunk. It was blown, changed it and then the key reset worked first time with 2 keys, no problems.
Thanks so much for this thread! Rick 2001 540i 1995 540i previously |
#65
Successful reprogram of 320 E46 key
![]() Thank you so much for your guidance folks. When I remembered to close the driver's door I followed the rest of the instructions and...it works! |
#66
FYI for everyone...
I had to program my remote on my 3-button key again and was having a very difficult time doing so. I realized the mistake I was making every time and is not documented... When holding the Home button (button 1) - You MUST hold it for at least 2 seconds before pressing the big center button 3 times. I kept removing the key from the ignition, holding button 1 then immediatly press the big center button three times. Does not work this way! Hopefully saves someone some grief!
#68
Any other ideas? Still having this issue...
#69
I have a 2001 530i with the diamond key, I believe my problem is my car is not charging my key. The last couple times my clicker worked I had to be closer and closer to the vehicle. I can manually lock and unlock the car with the key in the door. I can also fully unlock and lock the car from the inside button. When the car is locked the fuel door stays unlocked, I have checked all fuses and they are all good. I have also been noticing that my car does not automatically lock when I start driving. I would like to throw in that I have noticed my radio stations come in fuzzy when my fog lights are on( not the headlights). The factory security system works as well. If anyone can help me in anyway I would appreciate it.
#70
#71
i've looked thru all those pages they all talk about replacing the battary in the key, and reprogram the key. Is there a way to check the charging system in the car to see if its working? and what would cause the automatic locking system to stop working?
#72
When you say you "checked all the fuses"...that doesn't do it for us because just about everyone in your situation says that and about 90% of them did NOT check the fuse in the trunk. Also check to see if the fuel filler door actuator is plugged in, and PULL it's fuse (in the trunk) and replace it with an equivalent good fuse (should be a spare up front in the glovebox) then lock the car WITH THE KEY, then check if the fuel filler door is locked.
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) Last edited by QSilver7; 12-28-2010 at 07:14 AM. |
#73
i looked at all fuses in the trunk and the glove box all were good. I changed the fuse for central locking system with a spare 7.5a from the glove box. locked car with the key in the door, still no change car locks and arms it self, but the fuel door stays unlocked. i know the ignition charges the key, but is there a way to check the charging system for the key?
#74
ok tried reprogramming the keys, the key i was using still doesn't work, but the other key started working, and the central locking system started working again too. the fuel door lock still doesn't lock but i used a pick and pulled the lock pin out to the lock position and pressed the unlock button on the key, did this a few times and started getting some movement but only to the unlock position, i put some penetrating oil in there and i'm letting sit. i'm still curious if there is a way of checking the key charging system in the ignition.
#75
Thank you SO much. I have been fooling with the locks for some time and all I was doing was chasing my tail. I tried locking the doors with the key and the fuel door was unlocked. I replaced the 7.5 A fuse and hit the locks. It locked and would not unlock. It is 2 in the morning and when I unlocked the trunk the alarm went off. I almost dirtied my pants trying to get the alarm off. I looked at your diagram for the actuator and unplugged the connector with the blue wire going into the rear of the actuator. The locks work fine now. ![]() I can't thank you enoughNow I have to find out why I have water coming into the car in the rear. Ed |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Trunk Remote Not Working | Sheffer | E46 (1999 - 2006) | 7 | 09-29-2005 03:57 PM |
| Key initialization not working - car won't start | cpv204 | General BMW | 11 | 09-02-2005 05:31 PM |
| Key Remote - Intermittant | x3drive | X3 E83 (2004 - 2010) | 5 | 08-11-2005 09:22 PM |
| Remote key won't open door - HELP | mdavenport | E46 (1999 - 2006) | 4 | 02-13-2005 12:45 PM |
| Key stopped working (keyless entry) | mjames | 3 Series / 4 Series | 3 | 06-19-2004 12:40 PM |
