Old 06-19-2006, 11:40 PM
bokonnon bokonnon is offline
Mein Auto: 2001 E39 540iT
Question Transmission Rebuild
My tranny just died and now I'm weighing my options for replacement. I have the Bently manuals but they don't cover anything internal to the transmission except the filter replacement.
Does anyone know where I might find schematics and procedures for teardown and rebuild of the transmission?
2001 E39 540i Touring w/ Sport Steptronic
Old 06-20-2006, 01:23 PM
Rsavory Rsavory is offline
Mein Auto: 98 528i, 2000 528iT Sport
I'm fascinated. Are you really contemplating a DIY auto tranny rebuild? I have read accounts of rebuilds from experienced tranny shops only lasting 2 years.
Old 06-20-2006, 05:06 PM
Man I hope you're wrong about the longevity of rebuilt BMW transmissions. The estimate from the dealership had the parts price around $3400.00 for a REBUILT transmission. There is an outfit in Phoenix that has the transmission for $1950.00 and they'll include a four year warranty for like $450.00. It sounds like that would be 450 well spent if you're right.
Transmissions are easy (once they're out). I know the electrohydrolic BMW transmission are a lot more complex, but it's basically the same beast. I would just like to see some schematics before I open the case. I'll let you know what I find out.
Old 06-20-2006, 05:35 PM
I have heard that the factory rebuilt transmissions are fine. The mixed reviews I've seen relate to ones rebuilt at local tranny shops.
You must have just a little mechanical experience in this area. Keep us posted.
Old 06-20-2006, 05:38 PM
chuck92103's Avatar
chuck92103 chuck92103 is offline
Banned
Mein Auto: 2005 BMW 645Ci
How many miles on your car?
Old 06-20-2006, 07:14 PM
Just went over 64,000 miles. I'm very surprised at how short the life was, and it went FAST! I noticed the first noise and then not more then maybe 10 miles later no more go
Old 06-20-2006, 07:52 PM
chuck92103's Avatar
Banned
wow, that is not much mileage. My neighbors 330 vert (2004) lost its tranny after two weeks. It was a brand new car when he bought it.
Old 11-25-2008, 11:13 PM
refatb refatb is offline
Send a message via AIM to refatb
Mein Auto: 1998 528i
i took automatic transmission class at Lincoln Tech and tore down and assembled trannys, i kno ur gonna bust up ur knuckles trying to take out and putting in the clutch packs inside and they have to go in a certain way, and certain order and then there are rings that take a while to get into a tiny groove, you also have to replace shift selenoids. you will also need to replace rubber seals and gaskets. as you dissamble take pictures of everything and notes to make sure u can reassemble in reverse order. if you make the slightest mistake, everything will be wrong wit the tranny. you will need a torque wrench/ratchet, because the bolts on the tranny have to be torqued to a certain number of pounds and in a certain order and then retorqued to make sure. do not use silicone gasket sealers, it will break up and get clogged in the filter and wind up inside. dont forget to change the filter and ATF fluid.
Old 11-25-2008, 11:18 PM
im having problems with my 98 528i automatic transmission and im thinking of doing a rebuild myself....my transmission shifts automatically from 1st to 2nd but doesnt shift to 3rd automatically unless i take the shift knob back from "D" to "3" and then push it quickly back to "D" then it shifts to 3rd gear and then it shift to 4th automatically if i dont pull the shift knob from "D" to "3" and back to "D" while on the high way it stays at 2nd gear and the car goes 30MPH while the engine RPM goes to 4000RPM, iam guessing the 3rd gear shift selenoid is bad and needs to be replaced, but since the tranny needs to be opened might as well do a full rebuild and change everything out.
Old 03-27-2009, 05:18 AM
hoss-conn hoss-conn is offline
Mein Auto: 1995 BMW 5 series 525i
I have seen the scematics on the bmw tranny, I was also thinking of rebuilding my own but there is ALOT to it .
Old 03-27-2009, 09:00 AM
scott0357 scott0357 is offline
Mein Auto: 2003 530i
It was dead at 64k mi???!!! I would go to the BMW dealer and ask to speak to the service manager and ask him nicely for a good well repair, either for free or a big discount. It's not acceptable to have a BMW tranny failing at 64k mi on a $50k car (when new). BMW recommends the lifetime fluid for those cars, and i assume no one has ever worked on that tranny. I think the chances of getting a good well repair from BMW is fairly high.
Old 03-27-2009, 09:01 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
If yours is the ZF 5HP24 tranny, here is the catalog.
If this is not your tranny, let me know and I will post for you.
Good luck
Old 03-27-2009, 03:43 PM
tomibriggs's Avatar
tomibriggs tomibriggs is offline
Mein Auto: 1997 BMW 528i
Does the manual atleast cover the clutch replacement procedure?
Old 11-10-2009, 01:39 PM
SPORTSTER 94 SPORTSTER 94 is offline
Mein Auto: 1999 528i
Does anyone know where the tcc solenoid is? Can it be replaced just by dropping the pan while the trans is still in the car? I have a p0740 fault code. How deadly is that? I also have a tinny rattling noise comming from under the car but nothing seems loose. Could it be coming from inside the trans?
Old 11-10-2009, 04:12 PM
poolman poolman is offline
Mein Auto: 525i station wagon
There's a company out in Cali. called Dose something that's the sh--t for these BMW trannies--they are the ZF experts and will give the warrenty along with the rebuild--cost I belive is around 1500 plus shipping.
Old 11-10-2009, 04:23 PM
doru's Avatar
Here's a reference website with reputable BMW tranny repair shops.
Here is the automatic tranny catalog for v8 (ZF 5HP24)
Here is the automatic tranny catalog for i6 (ZF 5HP19)
Old 11-11-2009, 07:56 AM
Est1974's Avatar
Est1974 Est1974 is offline
Mein Auto: 1999 E39 Touring
are you sure its the Tranny? IF the computer module goes bad the codes read that the tranny needs to be replaced!! I know this because I replaced my transmission with the dealer and they still had the code!! They ordered a new computer and presto! Transmission was fine.
BTW: 3 BMW dealers and 2 Indy shops ALL said "i need a new transmission" so unless you buy a new module and install to make sure first there is NO WAY for them to tell
In summary the dealership felt so bad I got a new transmission for 3k with a 100k warranty on parts and labor. They ate the cost of the computer and got the 100k warranty on that as well
so in the end I got a new tranny on a car with 91k and a new computer module at the same time. So im good for a while
[SIGPIC] "yoda is my co pilot"
87' 318, 91' 525i, 95' 325iA (SOLD), 95' 318iA 96 M3 Sedan (Sold), 97 528i Sedan, 99' M5, 00 740iL, 00 323i wagon:
Current 99 528iT
Old 11-11-2009, 10:28 AM
rtanov rtanov is offline
Mein Auto: 2014 i3 REx; 00 540iA
These might help. It's a 7-series but it looks like it's the same tranny - ZF 5HP24
http://www.bimmerboard.com/forums/posts/474000/
http://www.bimmerboard.com/forums/posts/482057
Good luck, and keep us posted.
Old 11-11-2009, 07:14 PM
lild's Avatar
lild lild is offline
livin the 'Fest
Mein Auto: 97' 528i, 06 ninja
you need a sensor or selinod that's located on the tranny. when they go bad, you get what your getting.
The more you complain, the longer God makes you live. SPHOBA #00002
Old 11-11-2009, 08:26 PM
washburn33 washburn33 is offline
www.e39enthusiast.com
Mein Auto: 2001 E39 540IA Sport
I would advise not attempting to rebuild your transmission unless you are an experienced transmission rebuilder. From what I've been told there are various special tools that are required to do it properly. In addition, there are updates that ZF releases that should improve/fix the performance/longevity of the transmission.
Old 11-11-2009, 08:31 PM
Neil1138's Avatar
Neil1138 Neil1138 is offline
say something useful
Mein Auto: 2000 328Ci
I see that this thread is very old but someone might still find this useful down the line...
Hi guys! Kinda might help you, dunno. You can look at my auto tear down thread on fanatics, might give you an idea of whats involved. Let me just say that rebuilding an auto really isn't as hard as people make it out to be. We went back after the first time and completely rebuilt it within 90 minutes. It wasn't built in a clean environment but if it was I'm sure it would work again
http://forum.e46fanatics.com/showthread.php?t=713780
Old 11-11-2009, 08:48 PM
I don't think that you taking apart your GM trans and taking pictures of it and putting it back together again with no intention of putting it back in the car should be taken as proof that it is easy to properly rebuild their transmission. Very cool none the less.
Old 11-11-2009, 09:42 PM
Neil1138's Avatar
Thanks for the opinion
JW, have you ever torn into an automatic transmission? It's not complicated at all to put back together, everything is very straightforward when you get in there. There were no parts that needed "special tools" to put back or align properly. The K2 clutch pack and the massive slip rings were the most difficult part. I used a sib along the way to guide me but nonetheless, it wasn't that hard like people make it out to be. Now if I had to completely rebuild the valve body from scratch that would have been hard, but I didn't have to. I had taken pictures of where the bearings went before hand so I put them back in the right place. I never replaced seals and gaskets but that would have been easy, i just did it to prove that it isn't hard like most people think
I spent tons of time putting a manual in my e46, I would never put that godforsaken automatic back in
Old 11-11-2009, 09:43 PM
Mack's Avatar
Mack Mack is offline
Thebizzy.com
Send a message via AIM to Mack
Mein Auto: '02 525i
Bro that post was 100% awesome!
Mods: Shark Injected | Magnaflow Exhaust + Resonator | H&R Springs | Bilstein SP Shocks + Struts | TMS Power Pulleys
Eibach F+R Sways | BeastPower Brackets | M-Tech bumpers | Predator ICE V3 + HID Fogs | Eurodyne CF Hood | BSW Sub + Dice + spec dock
[---Quote (Originally by Tex330i)---
You can warranty a turd, that way when you have a problem you can exchange it for a new turd.---End Quote---
Old 11-11-2009, 11:03 PM
MatWiz's Avatar
MatWiz MatWiz is offline
Psychology Reversalist
Mein Auto: 528
NICCCEEE...
Neil, do you know the transmission model number?
mw
MatWiz
"The greatest thing about the internet, is that you can quote something and totally make up the source." - George Washington.
Similar Threads
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 08:20 AM
More on the N54 engine/ new transmission mapezzul E90/E91/E92/E93 (2006 - 2013) 5 07-18-2006 09:30 PM
6spd Transmission rebuild e39540i E39 (1997 - 2003) 10 03-12-2006 10:18 PM
323/325 328/330 etc. engine changes Optimus Prime General BMW Questions 15 04-03-2004 07:56 PM
