Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > The MINI Board
The MINI Board
The Mini Cooper Forum
Old 06-20-2006, 07:00 PM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
Ruh-Ro: Stuck brake drum...
Well well I wonder what I will find this weekend...
Took the beast (the Mini, '67 Austin Cooper S 1275) out for a fun run this weekend.
Drawing up to a stop, I felt some lock-up of the left rear. Hmm.
Tonight I was backing it out of the garage and the rear drums kind of "locked" on, had to break it loose in order to move the car.
I left it in the open part of the garage tonight; I guess I'll be pulling the drums off the rear to see wtf is going on...
Fortunately, a single circuit rear-drum/front disk system is within my ability to work on, I think it has about 7 working parts .
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 06-21-2006, 12:52 AM
Clarke's Avatar
Clarke Clarke is offline
Astigmatic Visionary
Mein Auto: 325Cic-Topaz-Sand
Was it the one thai had leaking issues gefore? Seems early for for cylinder rust/rehoning.Maybe a seal shifted or?? keep us posted and good luck.The British always seemed to enjoy time spent puttering in the garden and tinkering on cars.
Don't Forget to Have Fun! 325Cic Topaz,Sand;Sport,Premium. X5 3.0 Topaz,Sand;Sport,Premium,Xenon,Nav,HK,PDC.
Old 06-21-2006, 03:49 PM
Hey Clarke.
No, I did these three years ago, all the way from the master cyl to each of the slave cylinders at the wheels, plus new drums, plus new shoes, springs, flush and fill.
I only kept the backing plate, wedges and adjuster because they all looked ok/unworn.
I'll hopefully be able to take a few minutes this weekend to get him up on the jackstands and pull the drums off to see what's going on.
Might as well flush and bleed the system too for good measure.
- J.C. Watts Jr.
Old 07-02-2006, 11:03 AM
Well, got the drums off and found the following.
Left side (the one that was grabbing) had a slight wheel cylinder leak, with fluid dropped off the bottom and spun onto the shoes. Right hand side ok, but perhaps too much copper grease (my fault) was used on lubing the adjustor pin.
Also on both sides, the hand brake quadrant clevis pin and joint has siezed solid as a rock. Not a big deal until the handbrake is engaged; but still a problem to deal with.
I'll be making my shopping list for minispares.com:
- Set of stainless steel flexible Goodridge brake lines (might as well)
- Wheel cylinder repair kit (might just get a new set if cheap enough; not sure)
- I'm going to clean/deglaze the shoes (they're virtually new)
- Handbrake clevis pin
- New brake springs (again, virtually new, but what the heck, they're cheap to replace, I'm not )
And of course new fluid throughout.
Oh well, another few weeks waiting for parts. Its good to do this in the summertime when its too hot to drive. A black roof, no A/C, a hotted-up motor, and a tiny radiator is not a great combination.
- J.C. Watts Jr.
Similar Threads
left rear wheel is stuck, any ideas? areif E46 (1999 - 2006) 6 07-17-2006 09:32 AM
Stuck Brake Caliper Paul Klein X5 E53 (1999 - 2006) 0 12-28-2005 06:41 AM
New cure for songs stuck in your head ... TeamM3 Off-Topic 7 10-21-2003 07:16 PM
DSC, ABS and Brake lights on after getting stuck in snow gek330i 3 Series & 4 Series 0 02-18-2003 10:57 AM
Did you know our E brake is a drum ? silroc General BMW Questions 8 12-27-2001 10:38 AM
