Old 06-22-2006, 07:35 PM
moesonex moesonex is offline
Beamerlover
Mein Auto: 2000 540i Sport
EML light
I have a 2000 528i and recently I have a light that comes on that reads EML and when it lights on, my car loses power and seconds later when the light goes out, the car resumes power. for about a month, the error light for the airbag has also been lit. It has been on since I got the car back from the body shop...Can someone help?
Old 06-22-2006, 07:40 PM
Rsavory Rsavory is offline
Mein Auto: 98 528i, 2000 528iT Sport
Why was the car at the bodyshop and what did they do to it?
Old 06-25-2006, 07:29 PM
Beamerlover
Just a little body work..not a collision. It's just ironic that since then, The EML light turns on occassionaly and also the ABS light has been on without goung out. When the light goes on for the EML, the car loses significant power. I've owned the car for about 2 months and it has about 189000 miles on it.
Old 06-25-2006, 08:45 PM
re EML, Have the codes read so that you know what you're dealing with. This can be done by an independent bmw shop or at Autozone, or another auto parts shop with the capability. A good bmw shop will have a gt-1 computer that will get right to the heart of the problem.
On the airbag, if this was not a problem before you took it to the bodyshop I would take it back and see if they can correct it for free.
Good luck.
Old 06-26-2006, 07:46 AM
Beamerlover
The codes I got from Autozone are
P1580 Electronic Throttle monitor PCM override
P430 Catalyst System Efficiency below Threshold Bank2
As per the airbag light, do you think that when the body shop heated up the rear bumper to fix and patch, they burnt or ruined something? I also had the drivers seat out for repair, Do you think that may have caused a proble?
I appologize for all the questions but I appreciate you taking the time to help me.
Old 06-26-2006, 07:47 AM
Beamerlover
Autozone also told me that the P430 code means that the Cat is blocked..are the right?
Old 06-26-2006, 10:43 AM
I don't think the cat would be affected by heating the bumper. In the 2000 models I believe it is located close to the exhaust manifold. At 189k miles you might need a cat if it has never been changed.
Sounds like you have multiple issues that cry out for a good bmw mechanic. Good luck.
Old 09-08-2006, 05:18 PM
batotski batotski is offline
Mein Auto: BMW M3 2002
Angry Bmw Eml 2002 M3
Hi, My BMW m3 2002 EML light came on and went to Limp mode. It would only run up to 40 miles an hour and when i turn off the engine, it would reset and i will be able to drive normally but not push the gas pedal to its limits or the EML light would come on again.
I brought it to the dealership and they said after two days that it could be my throttle or catalytic converter. They are not sure. The service rep said the converters are bad and would cost me 3000+ dollars and they are still going to look at the throttle which who knows how much they are going to charge me.
It seems they are not sure. My car has 91K miles.
Any ideas? What should i do? thanks in advance for your help guys.
Old 09-08-2006, 06:00 PM
Hotswimmer Hotswimmer is offline
Mein Auto: '98 BMW 540iA
The throttle position sensor is not a huge deal - I've had that happen exactly the way you did. Not too expensive.
The deal with the catalytics is exactly what he's telling you. The OEM cats run right around $3000 installed. I believe that everywhere except California, you can put in aftermarket cats. If you have the work done PROPERLY, guys have had good success installing the Magnaflow 43005 OBDII compliant aftermarket cats, and the whole thing shouldn't cost you more than about $600 with installation.
Old 09-08-2006, 06:20 PM
Thanks Hotswimmer
thanks Hotswimmer. you just made my day. i will let you know what i did. My friend was telling me to buy the borla and see if it comes with the catalyctic converter.
Hey, thanks again and really appreciate it.
Old 08-06-2007, 04:55 PM
pdlo12 pdlo12 is offline
Mein Auto: 525
EML Light
I have a 2001 525I. Every week or so, my EML light will come on and I will lose power. My ASC(DSC) comes on a stays on until I stop and turn my engine off. Power resumes after this as normal. Any help would be appreciated....
Old 02-14-2011, 01:25 AM
david ayon david ayon is offline
Mein Auto: 528i 2000
same thing is happening to me on my 2000 528i please let me know if you figure it out
Old 02-14-2011, 01:27 AM
did changing the catalyc converter fix the problem please let me know cuz ive got the same thing happening with my 2000 528i
Old 01-09-2014, 08:38 AM
Bull City BMW Bull City BMW is offline
Mein Auto: 1999 528I
Was this issue ever resolved?
I am having the same thing, EML comes on along with ASC, then loss of power but then the lights shuts off and car drives fine. I am having this issue on take offs only, not while driving.
1999 528I 5 Speed
Old 01-09-2014, 09:49 AM
timarnold timarnold is offline
TA
Mein Auto: 2003 bmw 525i 2005 X3
If the battery was not disconnected before the seat was removed, the airbag light will come on. Not a big deal, but the light needs to be reset.
Old 01-20-2014, 09:00 PM
Alika808 Alika808 is offline
Mein Auto: X5/330/Range Rover HSE
I am trying to buy this 2000 323i (automatic) with the same EML illuminated. At first, the car won't start but when the car start, the EML illuminates and no power at all and it shut off the engine when I put into reverse gear. Does anybody of you guys figure out what is the cause of this. I appreciate for the input. Thank you all.
Old 03-03-2014, 10:44 PM
EML light was resolved with getting the throttle body a good cleaning
1999 528I 5 Speed
Similar Threads
'1 Brake Light Failure' Weird Situation hunt1200 E36 (1991 - 1999) 20 05-20-2011 05:54 PM
2000 528i Brake Light Problem via Console rsh E39 (1997 - 2003) 8 09-15-2008 02:15 PM
SES light comes on after cold start and hard acceleration (2001 740i) emmsys 7 Series & 8 Series 7 03-14-2006 07:25 PM
Door Locks, Brake Light, Climate Control - Connected? spentcase X5 E53 (1999 - 2006) 1 02-14-2006 06:15 AM
Tail light replacement shayser E36 (1991 - 1999) 1 03-29-2005 05:30 PM
