Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   bimmerfest - BMW Forums > BMW Model Discussions > General BMW
General BMW
Use this forum to talk about general BMW news/stories and to chat with fellow enthusiasts about the direction that BMW is going in for their cars and/or motorcycles!
Old 07-08-2006, 07:32 AM
cong13 cong13 is offline
Mein auto: 04 330 CIC
BMW Acronyms
I am new to the boards and have been experiencing a learning curve when it comes to BMW/automotive specific acronyms. Using the search function on multiple boards, I came up with this list of acronyms. There are still a few I haven't found yet....
I hope this can help other newbies!
4WD = All Wheel Drive
A/C = Air Conditioning
A/D = Analog/Digital
AB = Airbag
ABS = Anti-lock Braking System
AC = Air Conditioning
ACS = AC Schnitzer
ADB = Automatic Differential Braking
AE = Angel Eyes
AFM = Air Flow Meter
AFR = Air to Fuel Ratio
ALC = Automatic Light Control
ARS = Active Roll Stabilization
ASC = Automatic Stability Control
AT = Automatic Transmission
ATF = Automatic Transmission Fluid
BBK = Big Brake Kit
BLS = Brake Light Switch
BST = Battery Safety Terminal
CAB = Control Arm Bushing
CAI = Cold Air Intake
CAS = Car Access System
CBC = Cornering Brake Control
CCFL = Cold Cathode Fluorescent Lighting
CCM = Check Control Module
CD = Control Display
CDC = Compact Disk Changer
CEL = Check Engine Light
CF = Carbon Fiber
CPS = Crank Position Sensor
CSL = Coupe Sport Lightweight
CVT = Constantly Variable Transmission
CWP = Cold Weather Package
DAE = Daytime Angel Eyes
DBC = Dynamic Brake Control
DBS = Dynamic Braking System
DCS = Dealer Communication System
DD = Daily Driver
DDE = Daytime Demon Eyes
DIS = Direct Ignition System
DIY = Do It Yourself
DME = Digital Motor Electronics
DOHC = Double Over Head Camshafts
DRL = Daytime Running Lamps
DSC = Dynamic Stability Control
DTC = Dynamic Traction Control
DTM = Deutsche Tourenwagen Meisterchaft
EAM = Electrostatic Airflow Meter
ECM = Engine Control Module
ECU = Electronic Control Unit
EDFC = Electronic Dampening Force Controller
EDIS = Electronic Distributorless Ignition System
EPROM = Erasable Programmable Read Only Memory
ETM = Electrical Troubleshooting Manual
FI = Forced induction
FTL = For The Loss
FTW = For The Win
FWD = Front Wheel Drive
H/K = Harmon/Kardon
HFM = Hot Film Meter
HID = High Intensity Discharge
HM = Hotwire Meter
HPS = Head Protection System
Hz = Hertz (Cycle)
I-Bus = Information bus
ICM = Idle Control Module
ICV = Idle Control Valve
IKE = Instrument cluster Electronics
IR = Infrared
IRS = Infrared Locking System
ISC = Idle Speed Control
ISIS = Intelligent Safety Integration System
ITB = Individual Throttle Body
LAM = Laser Airflow Meter
LCAB - Lower Control Arm Bushing
LCM = Lamp Check Module
LDP = Leak Diagnosis Pump
LEO = Law Enforcement Officer
LEV = Low Emissions Vehicle
LHD = Left-Hand Drive
LSD = Limited Slip Differential
MAF = Mass Air Flow sensor
MAM = Mass Air Meter
MBC = Maximum Brake Control
MF = Micro Fiber
MMC = Multi-Media Changer
MRS = Multiple Restraint System
MT = Manual Transmission
MV = Magnetic Valve (solenoid Valve)
MoDiC = Mobile Diagnostic Computer
NAVI = Navigation module
NOS = Nitrous Oxide Systems
NOX = Nitrogen Oxides/ exhaust gas recirculation (from ETK)
O2 = Oxygen (sensor)
OBC = On Board Computer
OBD = On Board Diagnostics
OEM = Original Equipment Manufacturer
P-Bus = Periphery bus
P/N = Park/Neutral position
PCV = Positive Crankcase Ventilation valve
PDC = Park Distance Control
PGS = Passive Go System
PM = Power Module
PO = Previous Owner
PP = Premium Package
PSI = Pounds Per Square Inch
PTC = Positive Temperature Coefficient
PWG = Pedal position sensor/ potentiometer
RAM = Random Access Memory
RDC = tire pressure Control
RDS = Radio Data-broadcast System
RHD = Right-Hand Drive
RLS = Rain-Light Sensor
RM = Relay Module
RPS = Rollover Protection System
RSM = Rear Shock Mount
RTAB = Rear Trailing Arm Bushing
RWD = Rear Wheel Drive
S/C = Supercharger
SM = Street Modified
SOHC - Single Overhead Cam
SP = Sport Package
SRS = Supplemental Restraint System
SS = Stainless Steel
SSK = Short Shift Kit
Step = Steptronic transmission
TCS = Traction Control System
TDC = Top Dead Center
TIS = Technische Information System
TME = Transmission Mount Enforcer
TRE = Tie Rod End
VAM = Volumetric Airflow Meter
VANOS = Variable Lift and Timing System
VIN = Vehicle Identification Number
VTEC = Variable Timing and Lift Electronic Control
VVTI = Variable Valve Timing and Lift (With Intelligence)
WOT = Wide Open Throttle
ZCP = BMW Competition Package (M3 Only)
ZCW = BMW Cold Weather Package
ZHP = BMW Performance Package (Available on US-Market 330i/Ci/Cic Only)
ZPP = BMW Premium Package
ZSP = BMW Sport Package
cong13
'04 330 CIC
Old 07-08-2006, 07:41 AM
///M3lissa's Avatar
///M3lissa ///M3lissa is offline
\m/ (>.<) \m/
Mein auto: Duh!
Wow - great list.
You are missing one .. BMW
Old 07-08-2006, 07:51 AM
KrisL's Avatar
KrisL KrisL is online now
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein auto: 330i ZHP & 04 Honda VFR
I believe LCM is actually light control module.
KrisL, San Jose CA
Bay Area Autocross Coordinator
2003 BMW 330i
My Web Page
BMWCCA#170334 [Join]
The E46 Wiki is a knowledge base put together by Bimmerfest members!
Check it out!
I converted from Flickr to SmugMug! If you want to, this link will save you $5
In the Bay Area? It's autocross season! [more info].
Old 07-08-2006, 07:59 AM
vegastrashed's Avatar
vegastrashed vegastrashed is offline
Sung Hi Lee avatar :P
Mein auto: 2007 E63 AMG
I didn't see:
CDV = Clutch Delay valve
LED = Light Emitting Diode
OP = Original Poster
SMG = Sequential Manual Gearbox
2007 E63 AMG, some mods
2005 545i Sport SMG (Gone but not forgotten)
Old 07-08-2006, 08:08 AM
scott3 scott3 is offline
Mein auto: cars & the occasional trk
Or:
DED = Darkness Emitting Diode
Old 07-08-2006, 09:58 AM
mclaren's Avatar
mclaren mclaren is offline
BMW Aficionado
Mein auto: 2008 135i Convertible
CA Comfort Access.
'08 135i Convertible
'09 328i Convertible
Old 07-08-2006, 10:01 AM
chuck92103's Avatar
chuck92103 chuck92103 is offline
Banned
Mein auto: 2005 BMW 645Ci
Headup Display and Active Cruise Control and MID (Something information display)
HUD and ACC, and MID
Old 07-08-2006, 12:05 PM
WildKarrde WildKarrde is offline
Mein auto: '89 BMW 325is
BMW = Bayerische Motoren Werke
Or better yet;
BMW = Bring Me Women.
Old 07-08-2006, 12:25 PM
Vornado's Avatar
Vornado Vornado is offline
Protect your (lug) nuts
Mein auto: Hot air balloon
Or better yet;
Break My Wallet
Bring Mechanic With
Big Mighty Weiner
If you have built castles in the air, your work need not be lost; that is where they should be. Now put the foundations under them.
-- Henry David Thoreau
Old 07-08-2006, 04:34 PM
04bimmer 04bimmer is offline
Mein auto: 325i
4wd Does Not = Awd!!!!!!
Old 07-08-2006, 05:04 PM
DJ_INHALE DJ_INHALE is offline
Banned
Mein auto: higher mile m3
ATM = ass to mouth
Old 07-11-2006, 10:12 AM
I could not edit the original post. I have update the list with a fee more acronyms.
4WD = Four Wheel Drive
AB = Airbag
ACS = AC Schnitzer
AE = Angel Eyes
AWD = All Wheel Drive
BBK = Big Brake Kit
CDV = Clutch Delay Valve
CF = Carbon Fiber
DD = Daily Driver
FTL = For The Loss
FTW = For The Win
H/K = Harmon/Kardon
HM = Hotwire Meter
Hz = Hertz (Cycle)
IR = Infrared
MF = Micro Fiber
PM = Power Module
PO = Previous Owner
RM = Relay Module
S/C = Supercharger
SE = Special Equipment
SP = Sport Package
TRE = Tie Rod End
cong13
'04 330 CIC
Old 07-11-2006, 08:53 PM
Ci2Eye Ci2Eye is offline
Mein auto: 325Ci
FWD is not a BMW acronym. Maybe it is over at MINI but thankfully BMW has never used that one.
BTW, nice car. Is that Orient?
2005 325Ci 5-Speed, Orient Blue/Natural Brown, ZSP, ZPP, Xenon, Nav, Heated Seats, European Delivered.
Old 07-12-2006, 04:54 AM
Thanks... Yes it is.
cong13
'04 330 CIC
Old 04-09-2009, 05:27 PM
MikeLogan's Avatar
MikeLogan MikeLogan is offline
Send a message via AIM to MikeLogan
Mein auto: 09 Le Mans E92 (335) ZMP
3er - 3 series
CPO - Certified Pre Owned
SA - Service Advisor
CA - Customer Advisor
E Codes - Identifiers for BMW vehicles
See a complete list here: http://en.wikipedia.org/wiki/BMW
NWS - Not Work Safe...common in Off Topic
PCD - Performance Center Delivery
ED - European Delivery
RFT - Run-flat Tires
PM - Preventative Maintenance
09 Le Mans Blue E92 335 M-Sport, Loaded
-De-Badged, 30% Tint, Black Kidney's, Rubber BMW Floormats
ED/PCD
BMWCCA Member
Old 04-09-2009, 06:36 PM
rehostman rehostman is offline
Mein auto: 2007 X5 4.8i, 2009 E90 M3
SAV = Sport Activity Vehicle.
X6 = sucks.
Patrice
2009 E90 M3 Melbourne Red on Black Leather
2007 X5 4.8i Monaco Blue on Saddle Brown
Old 04-09-2009, 06:52 PM
Fast Bob's Avatar
Fast Bob Fast Bob is online now
Keeping it surreal
Mein auto: 2004 330Ci ZHP 3 pedals
Nothing like exhuming a long-dead thread....
Don`t forget:
MI (Magnetic Infandibulator)
The road goes ever onward....
Old 05-09-2009, 07:05 AM
TopDownInFL TopDownInFL is online now
Mein auto: '04 645Ci Convertible
There's just too many TLA's... don't you think? (Three Letter Acronyms) ;-)
My dad always said BMW stands for "Bring Money With (you)"
'04 645Ci Convertible - reverse sensors, reverse camera, windscreen (a MUST), retro iPod kit, RDash Angel Eyes
Previous Bimmers:
'05 545i
'03 330Ci Convertible
'01 330Ci Coupe
'98 323i Convertible
'95 318i Sedan
Similar Threads
1998 M3 = 540i = 740i = 20K rumratt General BMW 36 01-12-2007 06:26 PM
The History of the BMW 5 Series WAM 5 Series 5 08-17-2006 08:46 PM
The 2006 Bmw 7 Series tim330i BMW News Articles and Announcements 0 01-27-2005 02:22 PM
BMW Update for S54 Engines vatkens M Series 2 08-13-2003 05:55 PM
A Hit Parade for BMW? (Must-read BusinessWeek Article) Spiderm0n General BMW 10 09-14-2002 11:18 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2001-2009 performanceIX, Inc. All Rights Reserved .: guidelines .:. privacy .:. terms
