Old 07-13-2006, 08:33 PM
michaeldauben michaeldauben is offline
Mike X
Mein Auto: 2001 Z3 Roadster, 2004 X5
Z3 differential whining noise
Does anybody have experiences with a whining noise coming from the rear differential of a Z3? You only hear it with the top closed, around 50 mph, then it disappears completely at higher speeds and comes back around 75/80 mph. Mileage of the car is not even 30kmls. The whining noise was not always there. At some point in time it started and gradually increased. A BMW service Rep. claimed this is normal, can not be repaired and may happen again with a brandnew differential. Any thoughts or experiences? THANKS!!!
Old 07-13-2006, 09:04 PM
oxford oxford is offline
Mein Auto: '01 Z3, '03 330i
The diff in my '01 2.5i whines, too. It whines at the point where the car is not quite coasting and not quite accelerating. But I do not hear it when the drivetrain is under load.
I am going to try changing the diff oil to Red Line and see if that helps. My brother, who is a very experienced mechanic, told me not to expect that to fix it, though.
Mine now has 98,000 miles. It has whined ever since I got it at 75,000 miles. Mine hasn't failed yet, so I hope it is just an annoyance and not a potential breakdown coming.
Old 07-14-2006, 05:21 AM
myZ myZ is offline
Mein Auto: 1996 Z3 1.9 roadster
I changed the fluid on my 96 to Red Line, but it didn't help much. This winter I might change the wheel bearings, the right rear sound funny and has a little grease coming out (not sure if that is normal). After that
Old 07-14-2006, 08:39 AM
kostverloren's Avatar
kostverloren kostverloren is offline
Mein Auto: DINAN Z3 3.0,535i,MINI
Differential Whine
I have the same condition @ 50mph, previous post pretty much laid this out as normal and not indicative of some pending catastrophic failure. Another point made in previous post pointed to the fact that we sit almost on top of the differential and the sound is magnified because of this.
Old 07-16-2006, 12:45 PM
Mike X
Thanks for the feedback. Hearing that Red Line did not help much helps me saving some money where it is not needed. Also good to hear that nobody with this whine has exprienced catastrophic failure (yet)... So I guess I have to live with that whining, but other than that the car is a lot of fun!
Old 07-18-2006, 12:14 PM
wernst wernst is offline
Mein Auto: 2000 Z3 2.8
Very common problem. Mine did/does it as you describe.
I originally replaced the diff fluid with Amsoil 75w140 and the noise was greatly subdued at some speeds, and eliminated at other speeds. Recently, the dealer had to replace the diff cover, which meant emptying and refilling of the diff with OEM fluid again.
And within 1000 miles, the whining returned. D'OH!
So when I get some time, I'll be refilling with Amsoil.
-Warr
Old 07-18-2006, 01:04 PM
fpa1974's Avatar
fpa1974 fpa1974 is offline
Learning to drive...
Send a message via AIM to fpa1974
Mein Auto: 02 M Cpe,03 325iT,05 330i
Amsoil diff fluid (75w-90) works great indeed. Also try adding some limited slip additive in there. I use BG LSD with great success.
Florian
2002 M Coupe Estorilblau
2003 325iT Graygreen
2005 330i ZHP Imolarot II
368S/74
Old 10-25-2010, 08:34 AM
BASH82 BASH82 is offline
Mein Auto: z3 2.5
Hey guys, i know this thread dates back to 2006, but i have the exact same problem.
gonna try changing the fluid next week. Hope it works.
_________________
Z3 2.5 2000
Old 10-25-2010, 05:37 PM
ZEEBOY ZEEBOY is offline
The Arkleyologist
Mein Auto: 2001 Z3 Coupe
I've had two previous Z3s, one with 110k and another with 67K and neither one had an issue. I recently purchased a 2000 Z3 Coupe with 102K and it defintely has that exact whine as described in these posts. I will change to the Amsoil differential fluid. What is BG LSD?
Old 10-26-2010, 12:45 AM
Mein Auto: z3 2.5
Mine is over 250.000Km. the sound came up around 180.000Km. BG LSD is a gear fluid additive:
BG LSII
Limited Slip Axle Additive Concentrate
BG LSII is designed to prevent chatter in plate and clutch type Limited Slip Differentials. BG LSII may be used with any GL-5 gear lubricant in limited slip applications. It is also excellent for eliminating chatter in full-time four wheel drive transfer cases. The ingredients in BG LSII smooth and quiet operation of gears in the differential and fortify the additives in the gear lubricant.
http://www.bgprod.com/products/driveline.html
_________________
Z3 2.5 2000
Old 10-27-2010, 08:02 AM
Mein Auto: z3 2.5
One last question if any1 can help,
What shall i use as fluid? the original BMW or Amsoil diff fluid (75w-90) or Swepco oil?
Thx
_________________
Z3 2.5 2000
Old 10-27-2010, 03:31 PM
reidconti reidconti is offline
Officially Weird
Mein Auto: Clownshoe,Miata,WeeStrom
I've noticed the diff whine ever since I put in my IE rear subframe bushings. It's a very subtle noise though.
Old 10-27-2010, 06:42 PM
amancuso's Avatar
amancuso amancuso is offline
Send a message via AIM to amancuso
Mein Auto: Z3 2.3iA/5MT 528iA VW GTI
Mine has done that ever since I bought it with 65K miles on it. It whines when not accelerating, just when coasting at speed. It's not gotten any worse. I had the fluid checked and it's in good shape and at the proper level.
Old 10-28-2010, 12:39 AM
Mein Auto: z3 2.5
Me too since i got mine 3 years ago with 100k it whines when decelerating or accelerating at very low speeds. It's not gotten any worse since. I got used to it but every one who gets with me, directly asks "what is that noise?" it's like riding a Z3 with a jet engine! :P
So I'll try changing the oil since some ppl had posted that it helped or even eliminated that noise, no harm from trying, but still don't know what type is best. I think I'll go for Mobil 1 :s
_________________
Z3 2.5 2000
Old 10-28-2010, 10:02 AM
Mike X
Well, I am the one who started the thread back in 2006. I never ended up trying another differential fluid, since BMW decided to exchange the diff with a brand new one, during the last month of the 4-year-warranty. Worked for me. Still have the car, no whining anymore.
Hope the different fluid will work for you!!!
Old 11-01-2010, 12:32 AM
Daneborough Daneborough is offline
Mein Auto: Z4M Roadster - 335i Conv
Now this really goes back in history!
I bought my first Z3 (1.9) in '97 and it had a diff whine from the very first time I drove it on the highway
First, the Dealer replaced the diff with a new one off the shelf and that didn't fix the problem
Then BMW Aust ordered a new diff from the factory, the Dealer swapped it for the first replacement, it still whined
Then the rear end was completely dismantled and rebuilt including new everything plus stiffening, etc., and it still whined
Then a BMW Aust engineer fitted every sensor known to man to the car and spent almost a day in the car with me driving to accurately map my driving style, etc., had a new diff custom built in the factory, that was swapped for the second replacement, and it still whined
With diff builds and shipping times. etc., that took me to about 11 months after I bought the car and, with no other fix in sight and to keep me happy, the Dealer did a deal to trade up into a '98 2.8 at no cost to me with BMW Aust picking up the lease short-fall
I kept the '98 2.8 for almost 10 years and no diff whine or any other problem at all with that car, and the only reason I sold it was that I moved into a Townhouse with only 2 garages, had 3 cars, and something had to go!
Current:
2008 335i Convertible - Sapphire Black
Not Current:
Z4M Roadster
130i Hatch (wife's drive)
Z4 3.0 (x2)
Mini Cooper S (wife's drive)
Z3 2.8
Z3 1.9
(other marques don't rate a mention!)
Old 11-12-2010, 04:37 PM
The Arkleyologist
I posted a few weeks ago on this thread about the whine in my newly acquired 2000 Z3 coupe with 102K miles. I had my local mechanic swap the rear end with another one with 53K miles. It did not help as the whine was exactly the same. We reinstalled the original rear end, drained it, and put in the Amsoil 75-140. It made a huge positive difference in the noise levels. I can now drive the car without all that irritating noise. A big thumbs up for the Amsoil fix.
Old 11-13-2010, 01:41 AM
Mein Auto: z3 2.5
Glad to hear that ZeeBoy.
I didn't change mine yet, because I can't find Amsoil or redline neither Mobil1 over here :S
All that I can find is the Mobil HD (Not synthetic) and Kraft fluids, I don't think they are good enough. I'll keep on searching...
_________________
Z3 2.5 2000
Old 11-13-2010, 06:25 AM
Bill Oberst Bill Oberst is offline
Mein Auto: 2000 Z3 M Roadster
I'm 72 and serviced radios made before transistors came out. When a customer first noticed low frequency hum they would become fixated on the sound until it almost drove them nuts. From that day on all they listened for was the hum. Diff whine can also get on our nerves. My 2000 Z3 M whines a little.(24,000 miles) Maybe it's kinda like riding a Harley, just get louder mufflers. Harley's with stock factory mufflers clang and bang like an old wheat harvester. Put straight pipes on and she sings to you. Hard on other peoples ears tho. My point is just don't fixate on the noise it will drive you crazy and cost a lot to try to fix a built in defect. Sometimes we tune out our spouses why not diff noise? Bill
Old 11-23-2010, 10:58 AM
mw4 mw4 is offline
Mein Auto: 1997 Z3 & 1997 328ic
my thoughts exactly, turn up the stereo
Old 11-25-2010, 02:35 PM
The Arkleyologist
I think I see your point Bill and MW4, but I do not agree. I can not stand rear axle whine and will not tolerate it. What if Churchhill had decided to just go to the pub when he heard those annoying buzzbombs during WWII? Some problems cannot be ignored and need to be addressed. Bill, I'm just a couple years younger than you, so I guess I'm fortunate to hear anything at all :-)
Old 12-03-2010, 08:34 AM
myZ myZ is offline
If you drain and fill the Diff oil with Amsoil 75-140 and BG LSII what is the mix ratio??
Old 09-21-2013, 08:16 AM
Paul P Paul P is offline
Mein Auto: 1997 Z3
Amsoil 75w140
-Warr
Where do you get Amsoil and the BGLSII & how much does it take to change it. Thanks
Old 09-21-2013, 11:56 AM
vintage42's Avatar
vintage42 vintage42 is offline
BMW CCA 1405
Mein Auto: 1997 BMW Z3 1.9 5MT
AMSOIL is a multi-level marketing organization with no retail stores. You can buy from your local dealer(s) if you can find them. They sell out of their house like I did in the 1980s. But nowadays you can buy direct online:
http://www.amsoil.com/shop/by-produc...?code=SVOQT-EA
I would not think that AMSOIL 75W-140 gear oil can benefit from any mixing. You don't need to add the BG limited slip gear additive. In fact, it may be designed to fortify petroleum GL-5 gear oils, and degrade the synthetic AMSOIL.
http://www.ebay.com/itm/BG-LSII-LS2-...-/270685229753
Old 09-21-2013, 12:23 PM
Mein Auto: 1997 Z3
Differential info
Thank you, I'm new to this forum but am really impressed how helpful everyone is. Really appreciate the info.
Similar Threads
whining engine noise in 05 X5 3.0???? pdxX5 X5 E53 (1999 - 2006) 23 01-03-2017 10:30 AM
3.0L engines..anyone hear a whining noise at acceleration??? pdxX5 E46 (1999 - 2006) 23 12-19-2016 05:09 AM
HELP!! Wheel of fortune noise driving me NUTS! (328i Sport) Bozzie E36 (1991 - 1999) 21 01-12-2007 07:59 AM
BMW Z3 1996-2002 Fuel Pump BRAND NEW FOR SALE oleg_8831 Performance 0 05-26-2006 01:12 PM
Horrible noise, something under the hood is dead! nweibley E39 (1997 - 2003) 3 05-02-2005 03:51 PM
