Old 11-13-2002, 01:26 PM
Adam12Hicks's Avatar
Adam12Hicks Adam12Hicks is offline
Send a message via AIM to Adam12Hicks Send a message via Yahoo to Adam12Hicks
Mein Auto: 06 Sapph Blk M Roadster
Inspection I oil type? Help please!
So the dealer insists on using Mineral Oil 15w40 in my M Coupe (2000 S52) for inspections and services.
Many of the folks at another message board to remain nameless say that their dealer uses synthetic for these applications.
Can someone here (almighty Ron?) clear this up. It's frustrating having a BMW paid service performed only to have to come home and change it again.
Adam
2000 M Coupe
www.golilm.com
2006 Z4 M Roadster
2005 X5 Kid Truckster
1991 318is e30 Play Car
Old 11-13-2002, 01:44 PM
Ron Stygar's Avatar
19,585 Miles
My 2000 M coupe came with 15w40 and I continued using it.
Old 11-13-2002, 04:58 PM
bob lindquist's Avatar
bob lindquist bob lindquist is offline
A Clean Windshield
Mein Auto: 2000 Imola M Coupe
s52 oil
Oh boy did I churn and burn this one!
Called lots'o bmw people. Factory,tech support,ron,dealer's etc.
Final answer is BOTH are OK. Mine also came with mineral oil.
I have since filled with valvoline 5-40w synthetic for about 500 miles, then flushed it and readded more of same to ensure I got out all the mineral oil. (Whats 25$ for a 40K$ car?)
Now after 3000 miles I will fill with BMW 5-30W synthetic (factory recommended). The BMW oil meets specs NO OTHER other does. same goes with the other oils, transmission and differential. Only BMW has the correct oils for our cars. that makes it simple. especially since the cost is no more the discount stores charge for other brands.
2000 Imola Red M Coupe
Dinan suspension, M rotors /Axxis pads
Eurosport Cam Kit 1, touch lane change
Zaino polish, Beach Sand
Garys mirror adapter, S54 Oil Cooler
seat tilt coupling nuts, spare tire
"life's to short to drink cheap beer"
Old 11-13-2002, 05:28 PM
Thanks for the replies..
I still feel that Mobil1 and Redline are both superior oils, but when we're changing them every 3000 miles, I'd trust Castrol with my $40k car for sure.
Adam
2006 Z4 M Roadster
Old 11-13-2002, 06:04 PM
Ron Stygar's Avatar
19,585 Miles
Lightbulb SI 00 01 99 dated June 2000
A piece from the service information bulletin.
Old 11-13-2002, 06:48 PM
Randy Forbes's Avatar
Investigative Tinkerer
Re: Thanks for the replies..
Adam
Adam,
I have been using only Castrol oil in all my cars for the past 24 years and I have never had an oil related failure.
I have had plenty of the engines that I've built apart years later and there has never been any sludge build up. The engines are nearly as clean as when I put them together.
It is only been the last two years with the 99 that I've been using their synthetic formula (I use 10w/40 Syntec).
Changing the mineral oil at 5000 mile intervals, I wouldn't be afraid to leave it in my M (just that it came with synthetic when I got it).
Randy Forbes
2001///M Rdstr Steel Gray
Old 11-13-2002, 08:06 PM
///M Rakete's Avatar
///M Rakete ///M Rakete is offline
Rocket Scientist
Mein Auto: 2010 M3 and 2011 135i
The "old" BMW engine oil was Vavoline repackaged. It met ACEA A3/B3 specs (think I got that acronym right).
The "new" BMW engine oil is Castrol repackaged.
I think that either way you're good. If you use the proper weight for the temperature and it meets the A3 spec you can't go wrong...
...with perhaps one exception, Castrol TWS or RS 10W-60 for the S54.
2010 BMW M3 Coupe M-DCT w/Tech-EDC, BMW M Performance Exhaust, BPM Stage I Tune, Space Gray / Fox Red Extended, and a Trunk Monkey known as "Der Stig",
plus the daily driver...
2011 BMW 135i M Sport DCT, w/BMW Performance Power Kit, Exhaust, and Brake Rotors, Space Gray / Coral Red, known as "Stiggie" with an outlaw F20 "M135i" badge.
Old 11-14-2002, 05:24 AM
As far as repackaged Castrol...
They don't even repackage it for the new 3 and 5 series. (Don't know about 7's) My wife's 2001 3 series says to use Castrol oil on the oil cap. BMW must get a pretty good discount from these guys for this kind of advertising!
But at least they chose a top notch oil!
2006 Z4 M Roadster
Old 11-14-2002, 06:18 AM
A Clean Windshield
s52 oil
The latest servive bulletin my dealer (performance) had
11 0400 dated 10/2001 recommended
BMW Mineral SAE 15w-40 BMW p/n 07 510017868
or
BMW synthetic 5w-30 BMW p/n 07 510017866
This subject always stirs the pot with passions comming our for favorite brands and when to change etc. Love it! I think changing whatever oil you have often is really the key for the less exotic (read S54 types) engines.
The only problem I have had with oil over the years was a 2002 engine I built and ran on kendall. That one started burning bad and when I tore it down found the oil had dry grey gum on the rings from the additive in their oil.
Old 11-14-2002, 06:28 AM
///M-Bark's Avatar
///M-Bark ///M-Bark is offline
Metalsmith
Mein Auto: '00 M Coupe, '04 Kubota
One more data point...
My M Coupe (took delivery in 6/2000) came with the synthetic sticker under the hood. I never had the oil analyzed to verify that it was indeed synthetic, but that's all I've put in it since I've had it.
Old 11-14-2002, 06:30 AM
Gus Gus is offline
Mein Auto: 99 Euro M Coupe
Red face
My 99 Euro spec M Coupe with the S50B32 motor uses Castrol Formula RS 10W60. Local thief, I mean dealer, charges me $17.50 per bottle I found the local Castrol dealer who will sell them to me at $10 each, but I have to buy a case of 12! Oh well, yet another "advantage"
99 Euro ///M Z3 Coupe, Artic Silver/Black, moonroof, 321hp, NO traction control and loving every second of it!
Old 11-14-2002, 05:01 PM
Christian's Avatar
Christian Christian is offline
Project No Budget 1.9
Mein Auto: 1997 Z3 1.9
I don't drive an M, but FWIW my Z3 1.9 had 15W40 mineral oil from the dealer. I switched to 5W30 BMW (Castrol) synthetic after at 20K miles (3K miles since Inspection I) and noticed that the car pulled a bit harder. Even my girlfriend noticed, and she was not at all a "car person". My gas milage improved as well.
Old 01-07-2003, 01:22 PM
caylan caylan is offline
Mein Auto: 2000 M Coupe
Re: Inspection I oil type? Help please!
Adam
2000 M Coupe
www.golilm.com
I was thinking how the dealer f-ed you w/ the regular fossil oil instead of synth.
Ask them how the hell does a regular oil last 9K+ miles on those damn Inspection lights in the dashboard.
I mean, if your oil breaks down & screws your engine cause the dealer was cheap on your oil services WITHIN warranty & gave you regular oil that will break down well be4 the lights tell you next oil change!
does that mean they will give you a new engine ?
Old 01-07-2003, 02:54 PM
01silber's Avatar
01silber 01silber is offline
Im here
Send a message via AIM to 01silber
Mein Auto: 2001 Z3 3.0i
Ron please forgive my ignorance on this but i just want to confirm that going by the "oil bulletin" you posted above ,that since my car is a 2001 3.0i roadster i NEED to use the 5w-30 is this correct?
i realize that the reason you posted the bulletin was to make it clear but im alittle slow
thanks
max
Old 01-07-2003, 05:56 PM
A Clean Windshield
S52
After all the research and opinions I stuck with the factory recommended 5w30 BMW synthetic.
You do have to follow the manual for the climate you are driving in.
I'm sure some of the other oils the knowledgable people have been using for years would be ok also. The BMW oil I understand is Castrol made to BMW spec. I use it and it costs no more the other synthetics. 5w-30 is a pritty common weight to new cars these days.
I ran my first oil change to synthetic for 1500 miles them drained and refilled with fresh to purge the mineral.
Old 01-08-2003, 04:26 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
The Castrol TWS 10W-60 used in S54 engines is a direct replacement for RS. MSRP is $8.95 per LITER, and many dealers give a BMW CCA discount. I get 15% off at one dealer who charges MSRP. I get 20% at another dealer, but they mark up.
Bavarian Autosports now also carries the stuff at $8.95 a liter.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
