Old 01-18-2003, 01:47 PM
Ron Stygar's Avatar
19,585 Miles
Originally posted by scottn2retro
Ron -
I know someone that is curious if any of those would be a good fit for an e36 M3?
The lever I use short shifting a E36 M3 is mainly the M-Z3 one. I have used others. The top of the shift knob is 3/4 inch lower than stock which is the ideal height in my opinion. I have done some M-Z3 levers for the E36 M3 shortened from above 1 inch, which is 1 3/4 inch lower than stock. This lever has to be bent to duplicate the stock neutral postion. I also custom bend.
You could aslo use the Z4-3.0 lever. The top of the shift knob is 1 3/8 inch lower than stock. It also has to be bent.
Old 01-18-2003, 02:49 PM
Ron Stygar's Avatar
19,585 Miles
Re: No Z3 3.0?
Originally posted by bk3104
Ron, how does the Z3 3.0 shift lever stack up against all these others?
The lever labeled Z3-2.8 is the same lever used in the Z3-3.0.
The Z4-3.0 shift lever in your car would give you a 18% reduction in shifting throw.
Old 01-18-2003, 05:27 PM
scottn2retro's Avatar
scottn2retro scottn2retro is offline
into things retro
Mein Auto: '02 M3 SMG & '08 135i
Ron, thanks for the info. I sent him a link to this thread.
facebook.com/sctsracing
02 M3 SMG Coupe - prepared class BMW Club racer
08 135i 6sp - stock class BMW Club racer
Photo gallery
Old 01-19-2003, 02:07 PM
Ron Stygar's Avatar
19,585 Miles
Z4 ones added to the ratio chart
Old 01-19-2003, 08:53 PM
Ron Stygar's Avatar
19,585 Miles
Originally posted by RS2
Any chance the new E46 330P shift lever will fit E46 M3?
/RS2
Don't know yet. I assume that it's ratio will be less than the E46 328/30's 4.74:1.
I've done a couple of E46 M3's using the Z3-2.8/3.0 shift lever (4.0:1 ratio) which has to be bent. Since the E46 330P is already bent (I assume) it may work well on the E46 328/30, M3 and the E36 328/M3. Probably too much to hope for. Will post a pic of one which some other levers when I receive one. Not on the 01/03 EPC. It should be on the 02/03 one.
Old 03-20-2003, 06:08 PM
Ron Stygar's Avatar
19,585 Miles
Re: E46 330 Performance
Will be interesting to see what the E46 330 performance shift lever looks like. The stock E46 330 shift lever has a ratio of 4.74:1. The E46 330 performance, claims a shorter shift. I assume that it will have a lower ratio similar to the M-Z3 shift lever. What's different here, is that the M-Z3 shift lever is not bent. The E46 330 performance shift lever is. Will post pics of it when it comes in. If it is what I think it is, it will open up a lot of short shifting possibilities using BMW stuff.
Not what I expected. Length above the pivot ball is the same as the regular 330 lever. Length below is a little bit more. Front to back bend is less. A 7% reduction in shifting throw.
Old 03-20-2003, 06:17 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Mein Auto: 01 325iT, 88 M6
Hmm, not exactly what I predicted. From the 330HP (pre-production) I checked out in January, it felt like a shorter knob, nothing else.
Looks like this minimal change in ratio is used on top of the shorter knob to meet BMWNA's claims of a 'short shifter.'
Old 03-20-2003, 08:18 PM
Ron Stygar's Avatar
19,585 Miles
Wasn't aware of it having a shorter shift knob. Was it shaped like the ones in the following pic?
Old 03-20-2003, 08:31 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
There were several pics taken at the LA auto show and posted here, but IIRC it was a lot like 'H' but with a normal-looking (not metallic) 6sp insert.
Old 03-20-2003, 08:39 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Argh, I can't insert the pic for some reason.
http://www.bimmerfest.com/forums/sho...threadid=18589
