E36 (1991 - 1999)
Old 02-03-2017, 11:31 AM
drummerleo drummerleo is offline
Mein Auto: 1998 328i convertible
Window motor & regulator
My 328i convertible passenger power window started slipping down. The motor wouldn't move it back up (just made a clicking sound or no sound at all). Down works sporadically. I removed the motor and regulator and off the door they work fine. I replaced the sliders, lubricated the slider tracks and glass tracks, reinstalled and nothing change (nothing or clicking from up button, down works kind of). Any suggestions? New motor required?
Old 02-03-2017, 11:35 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x2,E30x1, F150
Welcome to Bimmerfest!
When window motors work fine without a load (like testing them off the car) but won't move the window when installed, it sounds like your regulator gears are stripped. The motor may be OK.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 & New Member Intro Forum Mod/Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426 Which is worse, ignorance or apathy? I don't know, and I don't care!
1995 318is "Bebe"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 02-03-2017, 11:58 AM
window motor and regulator
Thanks you. The gears appear ok but I will check again. But what would make it not work at all when I press the "up" button? It's almost like the motor thinks it's in the max up position.
Old 02-03-2017, 12:43 PM
bmw window motor & regulator
In hindsight, were you referring to the gears that aren't visible, that connect the motor to the gear that drives the scissor mechanism. Is there a foolproof why to check without tearing it all apart?
Thanks.
Old 02-04-2017, 09:06 AM
smithpatrick smithpatrick is offline
Mein Auto: 01 325i, 1990 325i, 320i
brushes
In my case the motor brushes weren't making proper contact.
Solution: Find a coupe door, extract motor replace motor.
Sounds easy, stupid window, up is down, down up stupid window.
4 BMW Motorcycles R75/5, 2 R60/6, and a R90/6
5 E30's 84, 87, 3 90's
3 E36's 95 euro 320, 98 323is, and 99 328is
2 E46's 2001 325i manual, 2000 323i auto
