E36 (1991 - 1999)
Old 03-20-2012, 12:09 PM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
bimmerfest Supporting Member
Mein Auto: A redhead E90
My E36 from earlier today. 3/20/12
Dat ass.
Originally Posted by Los View Post
^He's been drinking beer and destroying pumpkins with brake rotors and sledge hammers.
So, pretty much just doing man stuff.
  • '06 325xi 6MT
Old 03-20-2012, 02:17 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
On the whole I'm a'liking Ken. The only thing I'm not certain of is those tail lights. They may grow on me, or I may take a Louisville Slugger to 'em at BF.e...
Edit:
Maybe a hockey stick keeping in character...
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 03-20-2012, 02:26 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
I agree with needing OEM style tails. Two other things jump out to me:
1) You gotta stop washing your car with steel wool, and
2) Tow hoops on street cars are for poseurs
Just a little constructive criticism.
1998 BMW 328is
1966 Pontiac GTO
Old 03-20-2012, 03:25 PM
TRaV MaNN's Avatar
TRaV MaNN TRaV MaNN is offline
Somebody stop me....
Mein Auto: EW/// 86
I pretty much have the same tails. They're bad, but not bad enough that I want to jump up and spend $90 on new lights. I tinted them so you can't see the clear on top.
You canít spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
Old 03-20-2012, 03:37 PM
DenKare DenKare is offline
darksilver
Mein Auto: 1995 325is
that reinforcement plate is thicker than the original shock tower by a bit
I like the colour No Bias.
1995 325is 5spd
Old 03-20-2012, 03:42 PM
ZeGerman's Avatar
Warm Leatherette
I am confuzzeled. The front strut (not shock) tower reinforcement plates go between the underside of the strut tower and the strut mount. They're less than 1/16th of an inch thick. Your terminology is off, and I'm telling you, front strut tower reinforcement plates do not raise your ride height in any perceptible way. By installing the front reinforcement plates, all you are doing is placing a very thin round piece of metal on top of the strut mounts, and then bolting everything to the car as you normally would. Like so:
1998 BMW 328is
1966 Pontiac GTO
Old 03-20-2012, 03:51 PM
jonesin's Avatar
The Canadian Prick.
Karl, I'm thinking he may well mean camber plates. Though they wouldn't affect ride height either...
Old 03-20-2012, 03:52 PM
TRaV MaNN's Avatar
Mein Auto: EW/// 86
iPhone shot, I know
ZeGerman's Avatar
Warm Leatherette
That's what I'm saying. Neither reinforcement plates nor camber plates will raise ride height.
1998 BMW 328is
1966 Pontiac GTO
Old 03-20-2012, 03:55 PM
darksilver
yea those are the plates it raised it by a noticable ammount for me - maybe cause i changed wheels at the same time (looks taller) than the way my ds2s sat
1995 325is 5spd
Old 03-20-2012, 04:03 PM
ZeGerman's Avatar
Warm Leatherette
Well, if you went with an incorrect aspect ratio tire, that could be the reason your car was raised. But if you do things correctly, there will be no difference in ride height (aka: outside diameter) between a 15" wheel/tire package and an 18" wheel/tire package, let alone 17" DSIIs and 17" D-Force LTW5s.
If you need more proof that the strut tower reinforcement plates do not raise the car noticeably, take a photo of your car on a flat surface, and then drive your car's front wheels onto something that is less than 1/16th of an inch and take another photo. You won't be able to notice any difference.
Did you use the same tire specs between your DSIIs and LTW5s?
1998 BMW 328is
1966 Pontiac GTO
Old 03-20-2012, 04:22 PM
Kdoherty's Avatar
Edit:
Oh I only put the hoop on for the photos
also Ed, you may take a hockey stick to them if you bring me fully functional OEM replacements
and the paint has always looked that sh!tty haha not my fault
  • '06 325xi 6MT
Old 03-20-2012, 06:23 PM
darksilver
well front is much wider i went from 225/45/17 to 245/40/17
1995 325is 5spd
Old 03-20-2012, 07:35 PM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
Ken bring that to my house before BFE and I'll take care of the paint for you.
Turbo Build Here
Old 03-20-2012, 07:42 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
2 for 1 deal?
I haz front end that needs paint, too.
-CJ
Old 03-20-2012, 07:58 PM
Needs Boost
Mein Auto: Red Sled
Sure CJ! But I thought you couldn't stay long?
Turbo Build Here
Old 03-20-2012, 08:14 PM
wag-zhp's Avatar
wag-zhp wag-zhp is offline
Mein Auto: 97 White 328iC
You must need an alignment. Excess camber will cause uneven wear, but the real killer of tires is toe angle. If you've only driven 3k miles on your tires and you're seeing serious wear, I'd suspect the toe being off more than I'd suspect your camber settings.
Originally Posted by cj.surr View Post
Get your toe pulled out to 0 in the front. And have just a little bit of toe-in for the rear.
That's what I got and it has great response without wandering too bad on the highway.
Bingo. Dial out all or almost all front toe, and take rear toe down to 1 degree.
Set your suspension to the desired height (if it's adjustable) and get it on an alignment rack. By doing so, you may be able to get a little more life outta your current tires, but most importantly the car should drive much better.
When it absolutely, positively, has to be destroyed overnight! OohRaah!!!
U. S. M. C.
Semper Fidelis
Old 03-20-2012, 08:38 PM
cj.surr's Avatar
some kid
Oh, I thought you just meant some day before BFE. I'm still not sure what my plans are. It's smack in the middle of college move-ins. I might be coming down the day before if I'm in Rochester. Way too long of a drive to make in the morning.
-CJ
Old 03-20-2012, 08:45 PM
Needs Boost
Mein Auto: Red Sled
Oh yea that's cool.
Turbo Build Here
Old 03-20-2012, 08:49 PM
cj.surr's Avatar
some kid
Sweet, hopefully I'll be able to figure out the plans soon enough.
-CJ
Old 03-21-2012, 10:26 AM
akibo's Avatar
akibo akibo is offline
henri
Mein Auto: 323i (M52B28) Touring
Trav, what lip is that?
Spritmonitor.de
323iAT M-Tech (M52B28 swap) on 16" Style 42's & H&R Race w. yellow Konis + 270' tints.
Old 03-21-2012, 10:56 AM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
Teaser....
DSC_4927 by Chadley.36, on Flickr
RIP Ben "Jever" Doebele, we wont forget you
Please, call me Chadley
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates... I sure do miss you
1990-somethin Chevy K3500... Twin turbo Cummins swapped Chevy, dana 60 front axle swap, 4 link rear, air ride, custom everything. 600+ hp, 1296 ft lbs tq
Old 03-21-2012, 12:24 PM
cj.surr's Avatar
some kid
Finally, Chad!
I have some ugly pictures of my car while experimenting with ride heights. Joey, this applies to you. I can take a picture of the spring pads if you wanna see what I mean.
The rear of the car sat too high with the adjusters in, so I pulled them out. But then it sat too low, and the exhaust scrapes on stuff, and it was practically tucking rim. So I took a spare rubber spring pad and cut out part of the middle, so it would sit nicely on another spring pad. Put them both on the top together, and it raised the car perfectly. I've only done one side so far, so you can see the difference.
I also rolled the fender in front just a little bit and fit the 235 in there. Looks like a good fit, so I can get the other two 235s mounted soon and have all four. By the way, the Dunlop SP-01's in the rear grip great.
Parts car forgot to smile for the picture :/
-CJ
Old 03-21-2012, 12:41 PM
SlimKlim's Avatar
SlimKlim SlimKlim is offline
Speed is Zen
Mein Auto: Bavarian Bombshell
Nice dude! I just ordered the 15mm pads from bimmerworld this morning. If they don't raise it enough I have two extras for each side that I can cut the center out of until I get it perfectly to the top of the tire.
Old 03-21-2012, 12:57 PM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
Good work cj.
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2001 330i DD
-*nga*-, :3
Similar Threads
Stop using http://216.7.191.102 already! alee Off-Topic 27 07-03-2003 04:48 PM
NY International Auto Show pics alee General BMW Questions 32 04-19-2003 07:44 PM
My Pics of new 330i Perf Pkg from LA Show Preview roup1 3 Series & 4 Series 44 01-29-2003 09:47 PM
My Pics of new 330i Perf Pkg from LA Show Preview (2) roup1 3 Series & 4 Series 18 01-05-2003 12:02 AM
