Show Off Your E36 (post Pics) - Page 593 - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 02-04-2013, 12:43 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
One dollar.
1998 BMW 328is
1966 Pontiac GTO
Old 02-04-2013, 01:01 PM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
75cents.
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2007 328i DD
Old 02-04-2013, 01:34 PM
MigzE30 MigzE30 is offline
Mein Auto: 1985 BMW E30 325e
Originally Posted by Kdoherty View Post
cool E30, wrong subforum though
Sorry, thought it said "share pics of your E30" ! Thanks though
Old 02-04-2013, 03:23 PM
omp omp is offline
Mein Auto: E36 Touring 328i
Originally Posted by Z33 SHOE View Post
actually 10-12k (edited)
thinking like 7-8 for the car at least 3 for the bag set up and the style 5's are generous at a grand.
wow! for a ball park figure... under 5k USD
Old 02-04-2013, 05:07 PM
TRaV MaNN's Avatar
TRaV MaNN TRaV MaNN is offline
Somebody stop me....
Mein Auto: EW/// 86
Couple pictures from a cruise me and my buddy took.
ID:	360818   Click image for larger version
You canít spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
Old 02-04-2013, 05:35 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
Woah! That first picture is sweet!
-CJ
Old 02-04-2013, 05:37 PM
B_Rad_M3's Avatar
B_Rad_M3 B_Rad_M3 is offline
I6 feels good
Mein Auto: POS
Travis, go lower dude...
Old 02-04-2013, 05:40 PM
TRaV MaNN's Avatar
Mein Auto: EW/// 86
Thanks CJ. Slowly getting better at this camera thing.
I will, I think I need more fender rolling. It rubs pretty bad even if I'm barely going fast and turning
Old 02-04-2013, 06:33 PM
B_Rad_M3's Avatar
I6 feels good
Mein Auto: POS
That is why I'm on 205/40 on the style 5s
Old 02-04-2013, 06:37 PM
TRaV MaNN's Avatar
Mein Auto: EW/// 86
That's an option but not being able to go fast without smelling rubber is a real problem for me. I'm hoping after a smaller spacer and increase in neg camber I'll be able to go lower and not rub as much.
Wish I would have sprung for camber AND caster plates. I feel like a problem is how far forward the wheels are.
Old 02-04-2013, 06:38 PM
cj.surr's Avatar
some kid
What are your tire specs/offset?
-CJ
Old 02-04-2013, 06:40 PM
B_Rad_M3's Avatar
I6 feels good
Mein Auto: POS
This.
Old 02-04-2013, 06:46 PM
TRaV MaNN's Avatar
Mein Auto: EW/// 86
I believe offset is 43 and the tires are 225/40. Also running a 15 mm spacer (I think, there's 2 because one acts as a hubcentric ring and I'm not quite sure on the width).
Old 02-04-2013, 06:50 PM
cj.surr's Avatar
some kid
Why would a hubcentric ring act as a spacer?
I wouldn't run any spacers with that offset. Where exactly is it rubbing?
-CJ
Old 02-04-2013, 06:54 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
caster will not move the wheel itself, as its geometry is set by the structure of the lower control arm and chassis mounting points.
you can increase caster, which will aid in steering return to center and inline high speed stability.
df
Old 02-04-2013, 06:55 PM
TRaV MaNN's Avatar
Mein Auto: EW/// 86
The wheels have an e39 bore.
I believe the rubbing is coming from about 10:30 if you treat the fender as a clock.
Old 02-04-2013, 06:56 PM
TRaV MaNN's Avatar
Mein Auto: EW/// 86
df
Well that makes sense. Guess I never really thought the whole idea of it through.
Now I feel good about the camber plates again.
Old 02-04-2013, 07:10 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
What's the rim width and are those 17" or 18"?
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 02-04-2013, 07:12 PM
TRaV MaNN's Avatar
Mein Auto: EW/// 86
8.5" and 18" wheels.
Thanks for the help guys, this offset crap confuses the hell out of me.
Old 02-04-2013, 07:54 PM
yeah, me too...
df
Old 02-04-2013, 07:56 PM
dc_wright's Avatar
It can be pretty challenging. For your set up you you've got a lot going. I'll try and lay it out in steps.
OEM wheels are 46mm offset and 7 inch width.
Your wheels are 8.5 inches and 43mm offset.
46mm - 43mm gives 3mm offset outward.
The width increase adds 38mm of width over the 7 inch which is divided in half. Half inboard and half outboard or 19mm each way which moves the inner rim in by 19mm.
You already got 3mm out minus 19mm in gives you net 16mm inward increase.
The 15mm spacer moves you outboard again giving you a net inboard offset of 1mm which is nominal.
With the inboard side established back to about the normal, you've also added 19mm outboard (the other half of the 38mm) which closed up the gap between the tire and the fender.
Net of all this, you need the 15mm spacers since you can't go inboard any. Fender roll and pull or dropping in tire width to 215/40 should fix any rub.
Old 02-04-2013, 07:58 PM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
Mein Auto: A redhead E90
this. made my head hurt really bad.
Originally Posted by Los View Post
^He's been drinking beer and destroying pumpkins with brake rotors and sledge hammers.
So, pretty much just doing man stuff.
  • '06 325xi 6MT
Old 02-04-2013, 08:14 PM
TRaV MaNN's Avatar
Mein Auto: EW/// 86
As odd as it may seem. I have a much better understanding of it now. I'm dropping the spacer size. If that doesn't fix it will be more pulling. Really don't want the tire width to go any smaller.
Thanks again
EDIT: Now that I read it again, going to a smaller spacer would result in less inside clearance and I might hit my springs from the coils? When I say reduction in spacer I'm talking less than 5mm drop in size. Would that net inward increase of ~6mm be enough to cause any issues?
Old 02-04-2013, 10:28 PM
ZeGerman's Avatar
Warm Leatherette
Although OEM M3 wheels for '96+ are 17x7.5" et41 (front) and 17x8.5" et41 (rear), and not 7" wide et46.
1998 BMW 328is
1966 Pontiac GTO
Old 02-05-2013, 08:12 AM
bimmer claus's Avatar
bimmer claus bimmer claus is offline
Santa
Mein Auto: 95 M3
I read this whole thing trying to figure out what tyres i need to order for the 42's.... 17x8 ET 20 and i'm still lost
Lots of junk.
-*nga*-, :3
Similar Threads
Stop using http://216.7.191.102 already! alee Off-Topic 27 07-03-2003 04:48 PM
NY International Auto Show pics alee General BMW Questions 32 04-19-2003 07:44 PM
My Pics of new 330i Perf Pkg from LA Show Preview roup1 3 Series & 4 Series 44 01-29-2003 09:47 PM
My Pics of new 330i Perf Pkg from LA Show Preview (2) roup1 3 Series & 4 Series 18 01-05-2003 12:02 AM
