E36 (1991 - 1999)
Old 02-05-2013, 08:17 AM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
Depends how much you want to drop the car.
Sent from my SCH-I405 using Bimmer App
-CJ
Old 02-05-2013, 08:46 AM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
Nice shots Trav!!!
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2001 330i DD
Old 02-05-2013, 09:46 AM
Hellawut??
Mein Auto: who knows?
derek when you figure out how low you want to go talk to me.
im pretty good with tires offsets widths and lowness
-Franklyn
Old 02-05-2013, 09:51 AM
cj.surr's Avatar
some kid
Don't listen to Franklyn. He'll tell you to cut lowering springs and run 195s
-CJ
Old 02-05-2013, 10:05 AM
Hellawut??
depends how low he wants to go
-Franklyn
Old 02-05-2013, 10:10 AM
bimmer claus's Avatar
bimmer claus bimmer claus is offline
Santa
Mein Auto: 95 M3
Buying CJ's 42's hopefully and matching those with rokkor coilys is what its looking like. Just trying to figure what I'd need spacer /tire size wise.....But i dunno what the 17's are gonna put me at for front and rear wheel gap don't wanna go super low just tucked a little no 4" drops for me
Lots of junk.
Old 02-05-2013, 10:15 AM
Hellawut??
drop the car 3 inches.
and run 215 40 17 all around
and you wont need a spacer.
offsets are 20 right? your perfect with that.
After spacers i was at et 16 front and et 21 rear. which was perfect with a HUGE fcuking drop.
only differance is if you go lower you will need newer smaller tires.
how low do you really want to go?
-Franklyn
Old 02-05-2013, 10:17 AM
Santa
Mein Auto: 95 M3
Truthfully id sit the thing on the ground if I could.... Worried about camber issues when its dumped that much.. No fender rolling or anything if I go 215 40 17's all around or spacers This too easy to be true
Lots of junk.
Old 02-05-2013, 11:09 AM
Hellawut??
no camber issues with my ride height.... and im going lower in the spring.
tuck rears.
-Franklyn
Old 02-05-2013, 11:23 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
I know camber isn't what kills tires the fastest (although it doesn't help), but don't you also go through a set of tires every 4 months or something? I don't know that I'd use your car as an example of successful alignment when low.
1998 BMW 328is
1966 Pontiac GTO
Old 02-05-2013, 11:26 AM
Santa
Mein Auto: 95 M3
tuck rears.
I'll take your word then... see how low I can go when it's all together. Just go from there after that I guess just wondering how low I'll have to go for the rims to clear the suspension
Lots of junk.
Old 02-05-2013, 11:38 AM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
bimmerfest Supporting Member
Mein Auto: A redhead E90
toe has been the arch nemesis of my front tires but negative camber is certainly what ails my rear tires, even wear on the outermost edge of the tread block, it got exponentially better when i raised the rear back up an inch.
Originally Posted by Los View Post
^He's been drinking beer and destroying pumpkins with brake rotors and sledge hammers.
So, pretty much just doing man stuff.
  • '06 325xi 6MT
Old 02-05-2013, 03:38 PM
Santa
Mein Auto: 95 M3
Hey Franklyn could i run these tyres with my oem setup suspension wise with those specs alright for a while if I had to? Whatever you suggested 215 40 17x8 ET 20?
Lots of junk.
Old 02-05-2013, 04:23 PM
TRaV MaNN's Avatar
TRaV MaNN TRaV MaNN is offline
Somebody stop me....
Mein Auto: EW/// 86
Originally Posted by B1MM3R View Post
Nice shots Trav!!!
You canít spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
Old 02-05-2013, 04:25 PM
cj.surr's Avatar
some kid
Yeah, no doubt. You'll have more trouble when you try to lower it. 2 inches, you might be ok. If you want to tuck tire, I think you'll need 205s. I would go with 215s, though. No reason to neuter your car over a couple inches of low. Get tires and adjustable coils and go from there.
-CJ
Old 02-05-2013, 07:08 PM
dc_wright's Avatar
dc_wright dc_wright is offline
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Originally Posted by TRaV MaNN View Post
As odd as it may seem. I have a much better understanding of it now. I'm dropping the spacer size. If that doesn't fix it will be more pulling. Really don't want the tire width to go any smaller.
Thanks again
EDIT: Now that I read it again, going to a smaller spacer would result in less inside clearance and I might hit my springs from the coils? When I say reduction in spacer I'm talking less than 5mm drop in size. Would that net inward increase of ~6mm be enough to cause any issues?
if you can reach up over the top of the tire and fit your fingers in between the tire and the coil you can go down 5mm on your spacers for certain. If not it's a toss up as to whether you'll get rub or not.
This^ I could have run 215/40s without any rub on 17 x 8 ET20 Style 5's. I foolishly went with 225/45 and did the fender roll and pull thingy. I've got some Style 42's in work and I think they'll get 215/40 when I throw some rubber on them.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 02-05-2013, 08:58 PM
Santa
Mein Auto: 95 M3
Thanks CJ . Cant wait to get these badboys setup
DC got any more pictures of your setup please
Lots of junk.
Old 02-06-2013, 04:06 PM
///Mysild ///Mysild is offline
Mein Auto: BMW E36
Some updated pictures of my car :-)
Before:
IMG_8755 by SBOfoto, on Flickr
After
BMW2x by SBOfoto, on Flickr
IMG_7795x by SBOfoto, on Flickr
Still have the white rims, and some other purple ones for track use :-)
Old 02-06-2013, 06:35 PM
Shigeta's Avatar
Shigeta Shigeta is offline
Old Soul
Mein Auto: '96 328is
Holy large image.
Old 02-06-2013, 06:53 PM
Kdoherty's Avatar
that's what i wanted to say. i don't see how those throwing stars that are painted purple are "track wheels" there are lighter stronger better suited wheels for track abuse than those.
  • '06 325xi 6MT
Old 02-07-2013, 06:14 AM
B1MM3R's Avatar
Jesse Moon Bayne
I dont see how people run below 235/245s in rear and can drive "fun" at all. I have issues occasionally on dry pavement with 245's in rear, let alone in the rain (all over the place)
Jesse
2001 330i DD
Old 02-07-2013, 06:54 AM
Hellawut??
sideways is fun....
205 in the back for me
-Franklyn
Old 02-07-2013, 07:18 AM
B1MM3R's Avatar
Jesse Moon Bayne
Dude if I ran 205's in back id be all over the place all the time...no traction at all.
Jesse
2001 330i DD
Old 02-07-2013, 07:19 AM
Kdoherty's Avatar
that's me... and i don't even have full M power.
  • '06 325xi 6MT
Old 02-07-2013, 07:26 AM
Hellawut??
im all over the place too..
-Franklyn
-*nga*-, :3
Similar Threads
Stop using http://216.7.191.102 already! alee Off-Topic 27 07-03-2003 04:48 PM
NY International Auto Show pics alee General BMW Questions 32 04-19-2003 07:44 PM
My Pics of new 330i Perf Pkg from LA Show Preview roup1 3 Series & 4 Series 44 01-29-2003 09:47 PM
My Pics of new 330i Perf Pkg from LA Show Preview (2) roup1 3 Series & 4 Series 18 01-05-2003 12:02 AM
