TRANSMISSION FAIL SAFE mode - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 07-28-2006, 04:50 PM
biotequity biotequity is offline
Mein Auto: X5
my 2001 X5 with 88k miles on it just went into Transmission-fail-safe mode while on the highway - The engine revved up as if the tranny was slipping and WHAM, the tranny went into "fail Safe mode" .
AT the same time-my vent system electrical started cutting in and out and the display lights went dim... then brightened up in a few minutes (flickering).
When restarted, the trans seemed to work "ok" but still feels like it's slipping over 60mph - I cant really tell... it's also trying to shift into too-high gears at low speeds.
It feels like a vaccuum or electrical or both problem.
ANYONE HAVE EXPERIENCE WITH THIS???
I've made an appt with the BMW Dealer for Monday -
Any clue - I'll tell you what they find.
Michael T
Old 08-09-2006, 06:51 PM
JumpMan495 JumpMan495 is offline
Sleeper
Mein Auto: E60 M5/E39 M5
happened to my brothers 00 540ia, dealer told him to replace the automatic neutral switch and it will be fine
Old 12-26-2009, 11:18 AM
johnny2010 johnny2010 is offline
Mein Auto: 1999 740 il
MY 1999 740 il is in safe mode I was told that it is the abs module I replaced it with a used one and still there are no changes now Im thinking it is the tcm got a p1748 code at autozone transmission control unit self check does the car has to be reprogrammed or something Im clueless some help please
Old 12-26-2009, 11:22 AM
Exclamation 1999 740 il in safe mode need help please
My 1999 740 il is in safe mode I was told that it is the abs module I replaced it with a used one and still there are no changes now Im thinking it is the tcm got a p1748 code at autozone transmission control unit self check does the car has to be reprogrammed or something Im clueless some help please
Similar Threads
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 07:20 AM
Transmission Problem BMW says $6k fix I don't think so. crotchrocket25 E46 (1999 - 2006) 3 05-13-2006 06:46 AM
Transmission replacement - 530i 5sp pedrito530 E39 (1997 - 2003) 4 01-03-2006 11:53 AM
SMG Transmission problems... 2nd gear starts. hamrt E46 (1999 - 2006) 4 10-05-2005 08:43 PM
Track transmission mode for automatic?? Prov431 Motorsports, Racing & Track 8 12-16-2004 06:22 AM
