E30 (1982 - 1993)
Old 07-29-2006, 06:10 AM
318i UK 318i UK is offline
Mein Auto: 91 318i
318i Overheating problems...Help
Greetings to all as I'm a newbie...
As you can tell, I have a 91 318i with overheating problems. I've already installed a new t-stat and new waterpump (that was a xitch), radiator and fan clutch (both from my 89 parts car). I'm still running in the red. When first tested out, I had the heater running but only blowed cold air. After I shut the car down, all 3 radiator hoses were hot with pressure, even the ones that lead to the heater core and throttle body. I read something about a heater valve...does any body have information on this???
Any assistence would be greatly appreciated...
BTW, great site!!
Old 07-29-2006, 06:26 AM
bucks bucks is offline
Mein Auto: E30 318iS
Did you bleed the system properly after installing the waterpump and termo?
Any signs of water in the engine oil?
It could be the heater valve as you suggested.
It's located next to the transmission tunnel inside the glovebox area - take the plastic heater trim panel off (drop the glovebox right down by disconnecting the two straps) and you'll see it. On the top is a wire. Pull this off and the heater valve goes to default mode (fully open) and a cold heater can often warm up. If not, it's shagged and you'll need a new one.
A manual will come in handy for this, online one here;
http://dl.bmworg.ru/book/haynes/
Old 07-29-2006, 07:27 AM
Mein Auto: 91 318i
Thanks Buck for the info!!
I'm going to go ahead and drain/flush the system to make sure...Do you know where the Cylinder Block drain plug is located??
Thanks again.
Old 07-29-2006, 07:49 AM
Im nearly sure its under the exhaust manifold.
Not to familar with the M40 block though so it might be best to verify with the Haynes manual.
Old 07-29-2006, 08:24 AM
kenjin_21 kenjin_21 is offline
Mein Auto: BMW
Replacing Water Valve
Take a look at this and see if it will help you.
File Type: pdf RA Replacing water valve for heater.pdf (63.7 KB, 1088 views)
Old 07-31-2006, 02:55 PM
Mein Auto: 91 318i
Thanks for all the info.
I ended up with draining, flushing and refilling the coolant system using Bucks link and it did the trick.
Again, Thanks
Similar Threads
My friend looking for a 318i ! BMW318i_E36 E36 (1991 - 1999) 15 05-13-2006 12:26 AM
1985 318i Fuel injector problems kremer333 E30 (1982 - 1993) 2 04-22-2006 11:40 AM
NJ BMWCCA Round 2 Elwood Motorsports, Racing & Track 75 07-06-2004 05:45 AM
Problems with new 7-series SchwartzBlack General BMW Questions 3 01-14-2002 08:13 PM
