E36 (1991 - 1999)
Old 08-04-2006, 12:18 AM
diablo2668 diablo2668 is offline
Mein Auto: 93 BMW 318i
Exclamation 318i fuel filter?
Ok I have had a problem that involves my fuel system so I need to check the fuel filter. I know that it is in the line somewhere unfortunately I have yet to be able to find it...maybe I'm just not looking close enough cus I haven't gotten full body under the car yet since the damn thing is sitting on a slope. But any pointers or directions would be great thanx.
318i under major construction
Old 08-04-2006, 01:09 PM
does anyone know?
Old 08-04-2006, 03:58 PM
tom busby tom busby is offline
Mein Auto: 95 318i*01 325i*97 528i
It is hidden by a plastic shield when you look from underneath.
If you had X-ray vision and looked from the top, while driving, at the driver's side floor you would see the filter.
Old 08-04-2006, 04:45 PM
fun2drive's Avatar
BMWCCA 149159
You must get the car up on jack stands or on a lift to get the filter out. I think this model has a large canister type.
One question, have you pulled the injector hose off past the filter to see if fuel is coming out? Might save you the frustration of replacing a filter that is ok.
The fuel system uses 3 things: fuel pump for pressure and volume, filter to keep the fuel clean and the regulator to keep the back pressure up. I think it is around 43-46 psi.
Hope this helps...
Similar Threads
DIY:1997 528i Fuel Pump Replacement(E39) GOKOOLJAPAN 5 Series DIY 15 09-24-2015 06:06 PM
More on the N54 engine/ new transmission mapezzul E90/E91/E92/E93 (2006 - 2013) 5 07-18-2006 08:30 PM
Replacing Fuel Filter - 99 M Coupe sideslip E36/7 Z3 (1996-2002) 3 07-13-2006 08:44 AM
fuel filter help saltyseadog E30 (1982 - 1993) 6 06-26-2006 06:52 PM
does anyone know where the fuel filter is located on a 97 540i? david540i E39 (1997 - 2003) 4 05-04-2005 04:10 PM
