Old 08-05-2006, 09:37 AM
cinnamonstick cinnamonstick is offline
Mein Auto: 2007 X5 4.8 Alpine/black
2006 325I--how to reset the "low tiire pressure" warning??
Hello! I had my first flat (darn screws!!) and got my "run flats" changed at Mr Tire. The nearest BMW dealer is quite far.....they changed the tire--but my "warning sensor" is still telling me my tire is flat. I know how to re-set the sensor in our 1995 (for other reason such as oil change)..
Anybody know if you can "do it yourself" on the 2006?
Thanks for your help!
Miss....
Old 08-05-2006, 10:02 AM
Got it--guess it helps to look in the manual. Just didnt think it was that easy since with our 1995 we needed to "make" this device out of paper clips and tap into certain numbered slots.
Thanks.....glad they made it easy! Those darn run flats--- $350 each? DARN!
Old 08-05-2006, 06:23 PM
jelliotlevy jelliotlevy is offline
Mein Auto: 2011BMW 335i, Honda S2000
There are instructions in the owner's manual. You need to use the end of the directional signal lever to control the computer to reset the Flat Tire Monitor. The important trick, which is not stated clearly, is that you must perform this process while the car is standing still. The computer will not present the flat tire monitor display if you are in motion. So, you must do the set up before you go driving away. Then it finishes the calibration job automatically. This calibration should be repeated any time you adjust the tire pressures.
Old 08-05-2006, 06:54 PM
mscamp's Avatar
mscamp mscamp is offline
Bimmer Dreamer
Mein Auto: 2011 X3
$350 ? Wow! I paid $260 tax and labor at my BMW dealer. Bridgestone Turanza EL42 255/45.
2011 X3 - Purchased BMW of Peoria, IL October 6, 2012 - Deep Sea Blue/Oyster/Sienna - CWP1, CWP2, TP, PP, CP, PDC.
2006 X3 - Purchased BMW of Peoria, IL September 10, 2007 - Black/Black (Retired)
2006 330i Purchased BMW of Peoria, IL October 12, 2005 Arctic Met/Beige (Retired)
Old 09-01-2009, 08:35 PM
GKCI GKCI is offline
Mein Auto: 2006 325i sedan
Unhappy Lost my Manual
I have tried pressing the button on the end of the turn signal and the arrow pointing at the word Reset goes out. What am I supposed to do next? I have tried driving off but the warning just reappears.
Old 09-01-2009, 08:53 PM
KentW's Avatar
KentW KentW is offline
Hang up and drive.
Mein Auto: 2009 328i (E90)
You have to hold the button in for a few seconds.
Old 09-02-2009, 06:37 AM
madlaxkeeper1 madlaxkeeper1 is offline
Mein Auto: 2007 335i 6MT Coupe
Ever get this fixed? I'm taking my 335 into Merchants in a few days (damn sidewall bubbles!) and want to make sure the sensor doesn't stay on and annoy me.
2007 E92 335i 6MT
Black Sapphire Metallic, Black Dakota Leather, Sport, Premium, Cold Weather, M Spoiler
Go Hokies!
Old 09-02-2009, 08:53 AM
BMW_GAL BMW_GAL is offline
Mein Auto: 2009 335i Coupe
You would just reset the tpm system.
Sig by Solidjake
2009 335i Coupe, Titanium Silver Metallic, Coral Red Dakota Leather, Gray Poplar trim, Premium package and Sports package with 19s.
Previously Owned: 2006 Audi A4 S-Line Quattro with all the belles and whistles and a B5 Imola Yellow Audi S4
Old 09-02-2009, 02:22 PM
yeah just curious as to if there is in fact an amount of time requird to depress the button. I've attempted a reset before and just pressed down momentarily and had the same issue, ie the lamp came back on immediately when I drove off.
2007 E92 335i 6MT
Go Hokies!
Old 09-03-2009, 06:57 AM
Lilalleykatt's Avatar
Lilalleykatt Lilalleykatt is offline
SECOND IS NOT A GEAR
Mein Auto: 335d,Supercharged Maraudr
Its possible whom ever did your tire work damaged the TPM. I just paid $49 for a new one @ Tire Rack because one of mine was damaged by tire personel.
Old 09-15-2009, 07:46 AM
Yeah just got it back over the weekend. Did the reset after driving away and the warning lamp is now yellow instead of red, ie its saying the sensor itself is malfunctioning. Probably gonna take it back up to Merchants to see if they simply forgot to recalibrate it or what.
Anybody run into this same issue before?
2007 E92 335i 6MT
Go Hokies!
Old 10-09-2009, 03:25 PM
KBLa KBLa is offline
I'm actually having the same problem- the reset wont calibrate so I might be taking my car in as well.. Just wanted to add about the tires. I recently bought four new michelin primacy hp tires for only 140/each @ tirerack. worth checking them out.
Similar Threads
How to Reset IDrive Information Warning Messages joea9146 Do-It-Yourself H.Q. 48 02-14-2017 10:26 AM
Breaking in Engine for New 2006 325i and Bluetooth sonicsguru E90/E91/E92/E93 (2006 - 2013) 3 01-31-2006 03:23 PM
M3 WHEELS ON 325i 2006 devenirmusic E90/E91/E92/E93 (2006 - 2013) 6 01-27-2006 08:02 AM
NJ BMWCCA Round 2 Elwood Motorsports, Racing & Track 75 07-06-2004 05:45 AM
